I have just flashed the new JetPack 5.0 on my Jetson AGX Xavier. And I try to follow those instructions NVIDIA L4T PyTorch | NVIDIA NGC to run PyTorch docker container.
I run docker:
sudo docker run -it --rm --runtime nvidia --network host nvcr.io/nvidia/l4t-pytorch:r32.6.1-pth1.9-py3
And when I run python3 and import torch i get:
>>> import torch
File "<stdin>", line 1, in <module>
File "/usr/local/lib/python3.6/dist-packages/torch/__init__.py", line 195, in <module>
_load_global_deps()
File "/usr/local/lib/python3.6/dist-packages/torch/__init__.py", line 148, in _load_global_deps
ctypes.CDLL(lib_path, mode=ctypes.RTLD_GLOBAL)
File "/usr/lib/python3.6/ctypes/__init__.py", line 348, in __init__
self._handle = _dlopen(self._name, mode)
OSError: libcurand.so.10: cannot open shared object file: No such file or directory
my nvidia-jetpack specification:
Package: nvidia-jetpack
Version: 5.0.1-b118
Architecture: arm64
Maintainer: NVIDIA Corporation
Installed-Size: 194
Depends: nvidia-cuda (= 5.0.1-b118), nvidia-opencv (= 5.0.1-b118), nvidia-cudnn8 (= 5.0.1-b118), nvidia-tensorrt (= 5.0.1-b118), nvidia-container (= 5.0.1-b118), nvidia-vpi (= 5.0.1-b118), nvidia-nsight-sys (= 5.0.1-b118), nvidia-l4t-jetson-multimedia-api (>> 34.1-0), nvidia-l4t-jetson-multimedia-api (<< 34.2-0)
Homepage: http://developer.nvidia.com/jetson
Priority: standard
Section: metapackages
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_5.0.1-b118_arm64.deb
SHA256: d7ff0e4a95cc11c7a5d0b9e347923e8233ab544431d5db49d18c24944902e7a2
SHA1: fcab6ba9d6dca4a8b3e758d6fb1584baed34f7ed
MD5sum: f168d009bf5e3ee36ab14e646ad4b7dc
Description: NVIDIA Jetpack Meta Package
Description-md5: ad1462289bdbc54909ae109d1d32c0a8
Version: 5.0-b114
Architecture: arm64
Installed-Size: 194
Depends: nvidia-cuda (= 5.0-b114), nvidia-opencv (= 5.0-b114), nvidia-cudnn8 (= 5.0-b114), nvidia-tensorrt (= 5.0-b114), nvidia-container (= 5.0-b114), nvidia-vpi (= 5.0-b114), nvidia-nsight-sys (= 5.0-b114), nvidia-l4t-jetson-multimedia-api (>> 34.1-0), nvidia-l4t-jetson-multimedia-api (<< 34.2-0)
Priority: standard
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_5.0-b114_arm64.deb
SHA256: 3b5c14e3ed53cd2517d1a318d056aad3d8b44ff660a489a9b62825d518cf7c5b
SHA1: 608d1f78791a2bdda8bf88443796dfe99f19b199
MD5sum: dbcb9ff116c50b66d5270acd95e05f9a
additional information
/usr/local/cuda/lib64/ inside docker only contain:
libcudadevrt.a libcudart_static.a stubs
/usr/local/cuda/lib64/ on host contain a lot more files
nefault runtime is set to nvidia
ubuntu@ubuntu:~$ docker info
Client:
Context: default
Debug Mode: false
Server:
Containers: 0
Running: 0
Paused: 0
Stopped: 0
Images: 53
Server Version: 20.10.12
Storage Driver: overlay2
Backing Filesystem: extfs
Supports d_type: true
Native Overlay Diff: true
userxattr: false
Logging Driver: json-file
Cgroup Driver: cgroupfs
Cgroup Version: 1
Plugins:
Volume: local
Network: bridge host ipvlan macvlan null overlay
Log: awslogs fluentd gcplogs gelf journald json-file local logentries splunk syslog
Swarm: inactive
Runtimes: io.containerd.runc.v2 io.containerd.runtime.v1.linux nvidia runc
Default Runtime: nvidia
Init Binary: docker-init
containerd version:
runc version: 7cfd3bd
init version:
Security Options:
seccomp
Profile: default
Kernel Version: 5.10.65-tegra
Operating System: Ubuntu 20.04.4 LTS
OSType: linux
Architecture: aarch64
CPUs: 4
Total Memory: 14.56GiB
Docker Root Dir: /mnt/docker
Debug Mode: false
Registry: https://index.docker.io/v1/
Labels:
Experimental: false
Insecure Registries:
127.0.0.0/8
Live Restore Enabled: false
