how can i install the pytorch?
for install pytorch, i follow the PyTorch for Jetson - Jetson Nano - NVIDIA Developer Forums.
in python3,
i do import pytorch, the follow error occurs.
Python 3.6.9 (default, Nov 7 2019, 10:44:02)
[GCC 8.3.0] on linux
Type “help”, “copyright”, “credits” or “license” for more information.
import torch
File “”, line 1, in
File “/home/esal/.local/lib/python3.6/site-packages/torch/init.py”, line 81, in
from torch._C import *
ImportError: libnvToolsExt.so.1: cannot open shared object file: No such file or directory
how can i solve this problem?
Hi lee2h, which version of JetPack are you using? Those PyTorch wheels should be installed on JetPack 4.2 or newer.
libnvToolsExt.so should be installed by CUDA toolkit under /usr/local/cuda/lib64 - so either the SDK Manager did not install CUDA toolkit to your TX2, or you should add these lines to the end of your ~/.bashrc file:
export PATH=/usr/local/cuda-10.0/bin${PATH:+:${PATH}}
export LD_LIBRARY_PATH=/usr/local/cuda-10.0/lib64${LD_LIBRARY_PATH:+:${LD_LIBRARY_PATH}}
I ran into the same issue after following the same proccess, then realized these libraries are not included in the nvcr.io/nvidia/l4t-base:r32.3.1 image.
What is the recommended way to include these objects into an image?
Hi willcbaker, I believe those libraries/packages should be pulled or mapped from your Jetson root. But if you try the deepstream-l4t container, does it work then?
https://ngc.nvidia.com/catalog/containers/nvidia:deepstream-l4t
I˙ve tried all these images in Jetson NX ( NVIDIA L4T PyTorch | NVIDIA NGC ) and I˙m getting this error message:
root@6d1b568bfc54:/home/detector# python3
Python 3.6.9 (default, Jul 17 2020, 12:50:27)
[GCC 8.4.0] on linux
import torch
File “”, line 1, in
File “/usr/local/lib/python3.6/dist-packages/torch/init.py”, line 81, in
I˙ve tried to install the pytorch, but the error is the same. All the others libraries are working well (TensorRT, NumPy etc), but the pytorch isnt.
Hi @adriano.santos, are you running the container with --runtime nvidia option?
Inside the container, do you see the file /usr/local/cuda/libnvToolsExt.so.1?
What version of JetPack-L4T are you using?
JetPack
Package: nvidia-jetpack
Version: 4.4-b144
Architecture: arm64
Maintainer: NVIDIA Corporation
Installed-Size: 195
When I add --runtime=nvidia, I got this:
docker: Error response from daemon: OCI runtime create failed: container_linux.go:349: starting container process caused “process_linux.go:449: container init caused "process_linux.go:432: running prestart hook 1 caused \"error running hook: exit status 1, stdout: , stderr: nvidia-container-cli: initialization error: driver error: failed to process request\\n\""”: unknown.
So JetPack 4.4-b144 is the Developer Preview (L4T R32.4.2), so you should try the containers with r32.4.2 tag, like the following:
nvcr.io/nvidia/l4t-pytorch:r32.4.2-pth1.5-py3
You should be able to run it like so:
sudo docker run -it --rm --runtime nvidia --network host nvcr.io/nvidia/l4t-pytorch:r32.4.2-pth1.5-py3
Same issue for me with TensorFlow. It works outside of the container but not inside. Impossible to import tensorflow.
Specs:
NVIDIA Jetson TX2
L4T 32.2.1 [ JetPack 4.2.2 ]
CUDA 10.0.326
CUDNN: 7.5.0.56
@dusty_nv, I’ve solve the problem. I saw that the problem was between the Docker Image and the host. Maybe these process could be useful for you, @alexandremg0jh, as well.
a) reinstall the NVidia Docker dependencies:
  • libnvidia-container0_0.9.0_beta.1_arm64
  • libnvidia-container-tools_0.9.0_beta.1_arm64
  • nvidia-container-csv-cuda_10.2.89-1_arm64
  • nvidia-container-csv-cudnn_8.0.0.180-1+cuda10.2_arm64
  • nvidia-container-csv-tensorrt_7.1.3.0-1+cuda10.2_arm64
  • nvidia-container-csv-visionworks_1.6.0.501_arm64
  • nvidia-container-runtime_3.1.0-1_arm64
  • nvidia-container-toolkit_1.0.1-1_arm64
  • nvidia-docker2_2.2.0-1_all
b) Add the key “default-runtime”: “nvidia” into the /etc/docker/daemon.json file and restart the docker service;
c) Run the command ```
sudo docker run -it nvcr.io/nvidia/l4t-pytorch:r32.4.2-pth1.5-py3 /bin/bash
d) Run python3 command;
e) Import the library (or libraries).
Thats it.
