My Jetpack version is L4T 32.6.1 [JetPack 4.6] and I’m using the image ’ l4t-pytorch:r32.6.1-pth1.9-py3. The problem is that when I’m trying to import torch this error appears:
File "<stdin>", line 1, in <module>
File "/usr/local/lib/python3.6/dist-packages/torch/__init__.py", line 195, in <module>
_load_global_deps()
File "/usr/local/lib/python3.6/dist-packages/torch/__init__.py", line 148, in _load_global_deps
ctypes.CDLL(lib_path, mode=ctypes.RTLD_GLOBAL)
File "/usr/lib/python3.6/ctypes/__init__.py", line 348, in __init__
self._handle = _dlopen(self._name, mode)
OSError: libcurand.so.10: cannot open shared object file: No such file or directory
Hi @gsolsan, on JetPack 4 the CUDA libraries get mounted into the containers dynamically by the NVIDIA runtime - do you have these CSV files on your system under /etc/nvidia-container-runtime/host-files-for-container.d ?
ls -ll /etc/nvidia-container-runtime/host-files-for-container.d/
total 32
-rw-r--r-- 1 root root 26 May 23 2021 cuda.csv
-rw-r--r-- 1 root root 4250 Jul 13 2021 cudnn.csv
-rw-r--r-- 1 root root 12240 Jun 9 2023 l4t.csv
-rw-r--r-- 1 root root 1590 Oct 7 2022 tensorrt.csv
-rw-r--r-- 1 root root 325 Aug 11 2020 visionworks.csv
These files are what specify the libraries to the NVIDIA runtime that it should mount. They should have already been pre-installed on your SD card image from the nvidia-container-csv-* packages.
Checking my docker version on a Jetson running L4T R32.7, it is showing docker version 20.10.7. My guess is that your docker packages got upgraded at some point, and the dynamic mounting mechanism I mentioned above is no longer working for that configuration. I would recommend either downgrading docker, or reflashing your SD card (and docker should be pre-installed with NVIDIA runtime on the fresh SD card image)
