Python 3.6.9 (default, Apr 18 2020, 01:56:04)
[GCC 8.4.0] on linux
Type “help”, “copyright”, “credits” or “license” for more information.
import torch
File “”, line 1, in
File “/usr/local/lib/python3.6/dist-packages/torch/init.py”, line 188, in
_load_global_deps()
File “/usr/local/lib/python3.6/dist-packages/torch/init.py”, line 141, in _load_global_deps
ctypes.CDLL(lib_path, mode=ctypes.RTLD_GLOBAL)
File “/usr/lib/python3.6/ctypes/init.py”, line 348, in init
self._handle = _dlopen(self._name, mode)
OSError: libcurand.so.10: cannot open shared object file: No such file or directory
I did not add the --runtime nvidia command, it works now with it:
docker run -it --rm --runtime nvidia --network host nvcr.io/nvidia/l4t-ml:r32.4.3-py3
Aha ok, that makes sense - without --runtime nvidia, the CUDA libraries wouldn’t get mounted into the container from your host device. If you’d like to avoid having to set this flag every time you launch a container, you could instead set the default-runtime to nvidia in your Docker daemon configuration file:
