I am trying to build a docker which includes PyTorch starting from the L4T docker image. The docker build compiles with no problems, but when I try to import PyTorch in python3 I get this error:
File "<stdin>", line 1, in <module>
File "/usr/local/lib/python3.6/dist-packages/torch/__init__.py", line 81, in <module>
from torch._C import *
ImportError: libnvToolsExt.so.1: cannot open shared object file: No such file or directory
We want to reproduce this issue in our environment.
The Dockerfile shared in comment#3 doesn’t support pyTorch.
Do you meet the same issue when running other command?
If yes, could you share which command do you use?
We haven’t heard back from you in a couple weeks, so marking this issue resolved by “accepting” this comment as answer.
Please open a new forum issue when you are ready and we’ll pick it up there.
Hello, I’m geting the same error. Here is the Dockerfile. Can you please look into it? Thanks
FROM nvcr.io/nvidia/l4t-base:r32.3.1
ENV DEBIAN_FRONTEND noninteractive
RUN apt-get update && apt-get install -y \
python3-opencv ca-certificates python3-dev git wget sudo python-setuptools && \
rm -rf /var/lib/apt/lists/*
ENV PATH="/home/appuser/.local/bin:${PATH}"
RUN wget https://bootstrap.pypa.io/get-pip.py && \
python3 get-pip.py && \
rm get-pip.py
RUN wget https://nvidia.box.com/shared/static/phqe92v26cbhqjohwtvxorrwnmrnfx1o.whl -O torch-1.3.0-cp36-cp36m-linux_aarch64.whl
RUN pip3 install numpy torch-1.3.0-cp36-cp36m-linux_aarch64.whl
After that if I do
docker build -t jetson-pytorch:latest .
docker run -it jetson-pytorch:latest bash
root@21592ebf82b0:/# python3
Python 3.6.9 (default, Nov 7 2019, 10:44:02)
[GCC 8.3.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import torch
>>> exit()
root@21592ebf82b0:/# exit
exit
