Hi
I’m using JetPack 4.6.
I used the image below.
sudo docker pull nvcr.io/nvidia/l4t-pytorch:r32.6.1-pth1.9-py3
I fail to import PyTorch inside the container!
I added a log to the attachment.
help me! Two days have passed since I was worried. I asked a question because I couldn’t solve it.
I want to run YOLO v5.
Could you try the following command and launch the container again?
$ export LD_LIBRARY_PATH=/usr/local/cuda-10.2/lib64:$LD_LIBRARY_PATH
Hi
Thank you.
I removed the container and then tried your advice.
But it didn’t work.
Help me!
Hi @Heartful-echo , can you please confirm your JetPack-L4T version with cat /etc/nv_tegra_release ?
Do you have CUDA Toolkit installed and can find libcurand.so.10 on your device outside of container?
$ ls -ll /usr/local/cuda/lib64/
total 2259940
lrwxrwxrwx 1 root root 17 Mar 1 2021 libcublasLt.so -> libcublasLt.so.10
lrwxrwxrwx 1 root root 25 Mar 1 2021 libcublasLt.so.10 -> libcublasLt.so.10.2.3.300
-rw-r--r-- 1 root root 33562824 Mar 1 2021 libcublasLt.so.10.2.3.300
-rw-r--r-- 1 root root 36011742 Mar 1 2021 libcublasLt_static.a
lrwxrwxrwx 1 root root 15 Mar 1 2021 libcublas.so -> libcublas.so.10
lrwxrwxrwx 1 root root 23 Mar 1 2021 libcublas.so.10 -> libcublas.so.10.2.3.300
-rw-r--r-- 1 root root 81096256 Mar 1 2021 libcublas.so.10.2.3.300
-rw-r--r-- 1 root root 96903266 Mar 1 2021 libcublas_static.a
-rw-r--r-- 1 root root 679636 Mar 1 2021 libcudadevrt.a
lrwxrwxrwx 1 root root 17 Mar 1 2021 libcudart.so -> libcudart.so.10.2
lrwxrwxrwx 1 root root 21 Mar 1 2021 libcudart.so.10.2 -> libcudart.so.10.2.300
-rw-r--r-- 1 root root 490664 Mar 1 2021 libcudart.so.10.2.300
-rw-r--r-- 1 root root 888074 Mar 1 2021 libcudart_static.a
lrwxrwxrwx 1 root root 14 Mar 1 2021 libcufft.so -> libcufft.so.10
lrwxrwxrwx 1 root root 22 Mar 1 2021 libcufft.so.10 -> libcufft.so.10.1.2.300
-rw-r--r-- 1 root root 201494704 Mar 1 2021 libcufft.so.10.1.2.300
-rw-r--r-- 1 root root 192531512 Mar 1 2021 libcufft_static.a
-rw-r--r-- 1 root root 210524874 Mar 1 2021 libcufft_static_nocallback.a
lrwxrwxrwx 1 root root 15 Mar 1 2021 libcufftw.so -> libcufftw.so.10
lrwxrwxrwx 1 root root 23 Mar 1 2021 libcufftw.so.10 -> libcufftw.so.10.1.2.300
-rw-r--r-- 1 root root 503192 Mar 1 2021 libcufftw.so.10.1.2.300
-rw-r--r-- 1 root root 31970 Mar 1 2021 libcufftw_static.a
lrwxrwxrwx 1 root root 18 Mar 1 2021 libcuinj64.so -> libcuinj64.so.10.2
lrwxrwxrwx 1 root root 22 Mar 1 2021 libcuinj64.so.10.2 -> libcuinj64.so.10.2.300
-rw-r--r-- 1 root root 1535464 Mar 1 2021 libcuinj64.so.10.2.300
-rw-r--r-- 1 root root 33242 Mar 1 2021 libculibos.a
lrwxrwxrwx 1 root root 16 Mar 1 2021 libcupti.so -> libcupti.so.10.2
lrwxrwxrwx 1 root root 20 Mar 1 2021 libcupti.so.10.2 -> libcupti.so.10.2.175
-rw-r--r-- 1 root root 4526616 Mar 1 2021 libcupti.so.10.2.175
lrwxrwxrwx 1 root root 15 Mar 1 2021 libcurand.so -> libcurand.so.10
lrwxrwxrwx 1 root root 23 Mar 1 2021 libcurand.so.10 -> libcurand.so.10.1.2.300
-rw-r--r-- 1 root root 62698584 Mar 1 2021 libcurand.so.10.1.2.300
-rw-r--r-- 1 root root 62767380 Mar 1 2021 libcurand_static.a
lrwxrwxrwx 1 root root 17 Mar 1 2021 libcusolver.so -> libcusolver.so.10
lrwxrwxrwx 1 root root 25 Mar 1 2021 libcusolver.so.10 -> libcusolver.so.10.3.0.300
-rw-r--r-- 1 root root 218927328 Mar 1 2021 libcusolver.so.10.3.0.300
-rw-r--r-- 1 root root 123895098 Mar 1 2021 libcusolver_static.a
lrwxrwxrwx 1 root root 17 Mar 1 2021 libcusparse.so -> libcusparse.so.10
lrwxrwxrwx 1 root root 25 Mar 1 2021 libcusparse.so.10 -> libcusparse.so.10.3.1.300
-rw-r--r-- 1 root root 141252584 Mar 1 2021 libcusparse.so.10.3.1.300
-rw-r--r-- 1 root root 149512102 Mar 1 2021 libcusparse_static.a
-rw-r--r-- 1 root root 8319056 Mar 1 2021 liblapack_static.a
-rw-r--r-- 1 root root 909274 Mar 1 2021 libmetis_static.a
lrwxrwxrwx 1 root root 13 Mar 1 2021 libnppc.so -> libnppc.so.10
lrwxrwxrwx 1 root root 21 Mar 1 2021 libnppc.so.10 -> libnppc.so.10.2.1.300
-rw-r--r-- 1 root root 503184 Mar 1 2021 libnppc.so.10.2.1.300
-rw-r--r-- 1 root root 26846 Mar 1 2021 libnppc_static.a
lrwxrwxrwx 1 root root 15 Mar 1 2021 libnppial.so -> libnppial.so.10
lrwxrwxrwx 1 root root 23 Mar 1 2021 libnppial.so.10 -> libnppial.so.10.2.1.300
-rw-r--r-- 1 root root 11509472 Mar 1 2021 libnppial.so.10.2.1.300
-rw-r--r-- 1 root root 14410930 Mar 1 2021 libnppial_static.a
lrwxrwxrwx 1 root root 15 Mar 1 2021 libnppicc.so -> libnppicc.so.10
lrwxrwxrwx 1 root root 23 Mar 1 2021 libnppicc.so.10 -> libnppicc.so.10.2.1.300
-rw-r--r-- 1 root root 4914920 Mar 1 2021 libnppicc.so.10.2.1.300
-rw-r--r-- 1 root root 5722536 Mar 1 2021 libnppicc_static.a
lrwxrwxrwx 1 root root 16 Mar 1 2021 libnppicom.so -> libnppicom.so.10
lrwxrwxrwx 1 root root 24 Mar 1 2021 libnppicom.so.10 -> libnppicom.so.10.2.1.300
-rw-r--r-- 1 root root 1453728 Mar 1 2021 libnppicom.so.10.2.1.300
-rw-r--r-- 1 root root 1093680 Mar 1 2021 libnppicom_static.a
lrwxrwxrwx 1 root root 16 Mar 1 2021 libnppidei.so -> libnppidei.so.10
lrwxrwxrwx 1 root root 24 Mar 1 2021 libnppidei.so.10 -> libnppidei.so.10.2.1.300
-rw-r--r-- 1 root root 8175688 Mar 1 2021 libnppidei.so.10.2.1.300
-rw-r--r-- 1 root root 10762478 Mar 1 2021 libnppidei_static.a
lrwxrwxrwx 1 root root 14 Mar 1 2021 libnppif.so -> libnppif.so.10
lrwxrwxrwx 1 root root 22 Mar 1 2021 libnppif.so.10 -> libnppif.so.10.2.1.300
-rw-r--r-- 1 root root 54362944 Mar 1 2021 libnppif.so.10.2.1.300
-rw-r--r-- 1 root root 58471042 Mar 1 2021 libnppif_static.a
lrwxrwxrwx 1 root root 14 Mar 1 2021 libnppig.so -> libnppig.so.10
lrwxrwxrwx 1 root root 22 Mar 1 2021 libnppig.so.10 -> libnppig.so.10.2.1.300
-rw-r--r-- 1 root root 28761920 Mar 1 2021 libnppig.so.10.2.1.300
-rw-r--r-- 1 root root 31432462 Mar 1 2021 libnppig_static.a
lrwxrwxrwx 1 root root 14 Mar 1 2021 libnppim.so -> libnppim.so.10
lrwxrwxrwx 1 root root 22 Mar 1 2021 libnppim.so.10 -> libnppim.so.10.2.1.300
-rw-r--r-- 1 root root 7163640 Mar 1 2021 libnppim.so.10.2.1.300
-rw-r--r-- 1 root root 7396476 Mar 1 2021 libnppim_static.a
lrwxrwxrwx 1 root root 15 Mar 1 2021 libnppist.so -> libnppist.so.10
lrwxrwxrwx 1 root root 23 Mar 1 2021 libnppist.so.10 -> libnppist.so.10.2.1.300
-rw-r--r-- 1 root root 20877336 Mar 1 2021 libnppist.so.10.2.1.300
-rw-r--r-- 1 root root 23399160 Mar 1 2021 libnppist_static.a
lrwxrwxrwx 1 root root 15 Mar 1 2021 libnppisu.so -> libnppisu.so.10
lrwxrwxrwx 1 root root 23 Mar 1 2021 libnppisu.so.10 -> libnppisu.so.10.2.1.300
-rw-r--r-- 1 root root 486576 Mar 1 2021 libnppisu.so.10.2.1.300
-rw-r--r-- 1 root root 11458 Mar 1 2021 libnppisu_static.a
lrwxrwxrwx 1 root root 15 Mar 1 2021 libnppitc.so -> libnppitc.so.10
lrwxrwxrwx 1 root root 23 Mar 1 2021 libnppitc.so.10 -> libnppitc.so.10.2.1.300
-rw-r--r-- 1 root root 3112480 Mar 1 2021 libnppitc.so.10.2.1.300
-rw-r--r-- 1 root root 3205362 Mar 1 2021 libnppitc_static.a
lrwxrwxrwx 1 root root 13 Mar 1 2021 libnpps.so -> libnpps.so.10
lrwxrwxrwx 1 root root 21 Mar 1 2021 libnpps.so.10 -> libnpps.so.10.2.1.300
-rw-r--r-- 1 root root 9539760 Mar 1 2021 libnpps.so.10.2.1.300
-rw-r--r-- 1 root root 10690508 Mar 1 2021 libnpps_static.a
lrwxrwxrwx 1 root root 15 Mar 1 2021 libnvblas.so -> libnvblas.so.10
lrwxrwxrwx 1 root root 23 Mar 1 2021 libnvblas.so.10 -> libnvblas.so.10.2.3.300
-rw-r--r-- 1 root root 540232 Mar 1 2021 libnvblas.so.10.2.3.300
lrwxrwxrwx 1 root root 16 Mar 1 2021 libnvgraph.so -> libnvgraph.so.10
lrwxrwxrwx 1 root root 22 Mar 1 2021 libnvgraph.so.10 -> libnvgraph.so.10.2.300
-rw-r--r-- 1 root root 165012616 Mar 1 2021 libnvgraph.so.10.2.300
-rw-r--r-- 1 root root 168141386 Mar 1 2021 libnvgraph_static.a
-rw-r--r-- 1 root root 7430712 Mar 1 2021 libnvperf_host.so
-rw-r--r-- 1 root root 1096016 Mar 1 2021 libnvperf_target.so
lrwxrwxrwx 1 root root 25 Mar 1 2021 libnvrtc-builtins.so -> libnvrtc-builtins.so.10.2
lrwxrwxrwx 1 root root 29 Mar 1 2021 libnvrtc-builtins.so.10.2 -> libnvrtc-builtins.so.10.2.300
-rw-r--r-- 1 root root 4794168 Mar 1 2021 libnvrtc-builtins.so.10.2.300
lrwxrwxrwx 1 root root 16 Mar 1 2021 libnvrtc.so -> libnvrtc.so.10.2
lrwxrwxrwx 1 root root 20 Mar 1 2021 libnvrtc.so.10.2 -> libnvrtc.so.10.2.300
-rw-r--r-- 1 root root 20432800 Mar 1 2021 libnvrtc.so.10.2.300
lrwxrwxrwx 1 root root 18 Mar 1 2021 libnvToolsExt.so -> libnvToolsExt.so.1
lrwxrwxrwx 1 root root 22 Mar 1 2021 libnvToolsExt.so.1 -> libnvToolsExt.so.1.0.0
-rw-r--r-- 1 root root 44088 Mar 1 2021 libnvToolsExt.so.1.0.0
drwxr-xr-x 2 root root 4096 Jul 26 2021 stubs
Similarly, how does this look if you run the same thing inside of container?
There are CSV files on your device which should mount CUDA/cuDNN/TensorRT/ect into the containers:
ls -ll /etc/nvidia-container-runtime/host-files-for-container.d/
total 36
-rw-r--r-- 1 root root 26 May 23 2021 cuda.csv
-rw-r--r-- 1 root root 4250 Jul 13 2021 cudnn.csv
-rw-r--r-- 1 root root 12240 Jul 26 2021 l4t.csv
-rw-r--r-- 1 root root 2653 Jul 21 2021 opencv.csv
-rw-r--r-- 1 root root 1521 Jun 30 2021 tensorrt.csv
-rw-r--r-- 1 root root 325 Aug 11 2020 visionworks.csv
You may need to remove/reinstall the NVIDIA container runtime packages if these mounts are no longer working, or re-flash your device if you continue having issues.
$ apt-cache search nvidia-container*
libnvidia-container-tools - NVIDIA container runtime library (command-line tools)
libnvidia-container0 - NVIDIA container runtime library
nvidia-container-csv-cuda - Jetpack CUDA CSV file
nvidia-container-csv-cudnn - Jetpack CUDNN CSV file
nvidia-container-csv-tensorrt - Jetpack TensorRT CSV file
nvidia-container-csv-visionworks - Jetpack VisionWorks CSV file
nvidia-container-runtime - NVIDIA container runtime
nvidia-container-toolkit - NVIDIA container runtime hook
nvidia-docker2 - nvidia-docker CLI wrapper
nvidia-container - NVIDIA Container Meta Package
nvidia-container-csv-opencv - Jetpack OpenCV CSV file
Hi @dusty_nv
I appreciate your advice.
I ran “cat /etc/nv_tegra_release” .
R32 (release), REVISION: 7.2, GCID: 30192233, … was output.
Jetpack version is 4.6.2-b5
The libcurand.so.10 file will be checked next Monday.
I’m sorry.
Ah okay - for L4T R32.7.x, please run nvcr.io/nvidia/l4t-pytorch:r32.7.1-pth1.9-py3 container instead
Hi
I’m using http://nvcr.io/nvidia/l4t-pytorch:r32.7.1-pth1.9-py3
I found libcurand.so.10.
I tried ls -ll /usr/local/cuda/lib64/. The result is below.
合計 2259944
lrwxrwxrwx 1 root root 15 3月 2 2021 libcublas.so -> libcublas.so.10
lrwxrwxrwx 1 root root 23 3月 2 2021 libcublas.so.10 -> libcublas.so.10.2.3.300
-rw-r--r-- 1 root root 81096256 3月 2 2021 libcublas.so.10.2.3.300
lrwxrwxrwx 1 root root 17 3月 2 2021 libcublasLt.so -> libcublasLt.so.10
lrwxrwxrwx 1 root root 25 3月 2 2021 libcublasLt.so.10 -> libcublasLt.so.10.2.3.300
-rw-r--r-- 1 root root 33562824 3月 2 2021 libcublasLt.so.10.2.3.300
-rw-r--r-- 1 root root 36011742 3月 2 2021 libcublasLt_static.a
-rw-r--r-- 1 root root 96903266 3月 2 2021 libcublas_static.a
-rw-r--r-- 1 root root 679636 3月 2 2021 libcudadevrt.a
lrwxrwxrwx 1 root root 17 3月 2 2021 libcudart.so -> libcudart.so.10.2
lrwxrwxrwx 1 root root 21 3月 2 2021 libcudart.so.10.2 -> libcudart.so.10.2.300
-rw-r--r-- 1 root root 490664 3月 2 2021 libcudart.so.10.2.300
-rw-r--r-- 1 root root 888074 3月 2 2021 libcudart_static.a
lrwxrwxrwx 1 root root 14 3月 2 2021 libcufft.so -> libcufft.so.10
lrwxrwxrwx 1 root root 22 3月 2 2021 libcufft.so.10 -> libcufft.so.10.1.2.300
-rw-r--r-- 1 root root 201494704 3月 2 2021 libcufft.so.10.1.2.300
-rw-r--r-- 1 root root 192531512 3月 2 2021 libcufft_static.a
-rw-r--r-- 1 root root 210524874 3月 2 2021 libcufft_static_nocallback.a
lrwxrwxrwx 1 root root 15 3月 2 2021 libcufftw.so -> libcufftw.so.10
lrwxrwxrwx 1 root root 23 3月 2 2021 libcufftw.so.10 -> libcufftw.so.10.1.2.300
-rw-r--r-- 1 root root 503192 3月 2 2021 libcufftw.so.10.1.2.300
-rw-r--r-- 1 root root 31970 3月 2 2021 libcufftw_static.a
lrwxrwxrwx 1 root root 18 3月 2 2021 libcuinj64.so -> libcuinj64.so.10.2
lrwxrwxrwx 1 root root 22 3月 2 2021 libcuinj64.so.10.2 -> libcuinj64.so.10.2.300
-rw-r--r-- 1 root root 1535464 3月 2 2021 libcuinj64.so.10.2.300
-rw-r--r-- 1 root root 33242 3月 2 2021 libculibos.a
lrwxrwxrwx 1 root root 16 3月 2 2021 libcupti.so -> libcupti.so.10.2
lrwxrwxrwx 1 root root 20 3月 2 2021 libcupti.so.10.2 -> libcupti.so.10.2.175
-rw-r--r-- 1 root root 4526616 3月 2 2021 libcupti.so.10.2.175
lrwxrwxrwx 1 root root 15 3月 2 2021 libcurand.so -> libcurand.so.10
lrwxrwxrwx 1 root root 23 3月 2 2021 libcurand.so.10 -> libcurand.so.10.1.2.300
-rw-r--r-- 1 root root 62698584 3月 2 2021 libcurand.so.10.1.2.300
-rw-r--r-- 1 root root 62767380 3月 2 2021 libcurand_static.a
lrwxrwxrwx 1 root root 17 3月 2 2021 libcusolver.so -> libcusolver.so.10
lrwxrwxrwx 1 root root 25 3月 2 2021 libcusolver.so.10 -> libcusolver.so.10.3.0.300
-rw-r--r-- 1 root root 218927328 3月 2 2021 libcusolver.so.10.3.0.300
-rw-r--r-- 1 root root 123895098 3月 2 2021 libcusolver_static.a
lrwxrwxrwx 1 root root 17 3月 2 2021 libcusparse.so -> libcusparse.so.10
lrwxrwxrwx 1 root root 25 3月 2 2021 libcusparse.so.10 -> libcusparse.so.10.3.1.300
-rw-r--r-- 1 root root 141252584 3月 2 2021 libcusparse.so.10.3.1.300
-rw-r--r-- 1 root root 149512102 3月 2 2021 libcusparse_static.a
-rw-r--r-- 1 root root 8319056 3月 2 2021 liblapack_static.a
-rw-r--r-- 1 root root 909274 3月 2 2021 libmetis_static.a
lrwxrwxrwx 1 root root 13 3月 2 2021 libnppc.so -> libnppc.so.10
lrwxrwxrwx 1 root root 21 3月 2 2021 libnppc.so.10 -> libnppc.so.10.2.1.300
-rw-r--r-- 1 root root 503184 3月 2 2021 libnppc.so.10.2.1.300
-rw-r--r-- 1 root root 26846 3月 2 2021 libnppc_static.a
lrwxrwxrwx 1 root root 15 3月 2 2021 libnppial.so -> libnppial.so.10
lrwxrwxrwx 1 root root 23 3月 2 2021 libnppial.so.10 -> libnppial.so.10.2.1.300
-rw-r--r-- 1 root root 11509472 3月 2 2021 libnppial.so.10.2.1.300
-rw-r--r-- 1 root root 14410930 3月 2 2021 libnppial_static.a
lrwxrwxrwx 1 root root 15 3月 2 2021 libnppicc.so -> libnppicc.so.10
lrwxrwxrwx 1 root root 23 3月 2 2021 libnppicc.so.10 -> libnppicc.so.10.2.1.300
-rw-r--r-- 1 root root 4914920 3月 2 2021 libnppicc.so.10.2.1.300
-rw-r--r-- 1 root root 5722536 3月 2 2021 libnppicc_static.a
lrwxrwxrwx 1 root root 16 3月 2 2021 libnppicom.so -> libnppicom.so.10
lrwxrwxrwx 1 root root 24 3月 2 2021 libnppicom.so.10 -> libnppicom.so.10.2.1.300
-rw-r--r-- 1 root root 1453728 3月 2 2021 libnppicom.so.10.2.1.300
-rw-r--r-- 1 root root 1093680 3月 2 2021 libnppicom_static.a
lrwxrwxrwx 1 root root 16 3月 2 2021 libnppidei.so -> libnppidei.so.10
lrwxrwxrwx 1 root root 24 3月 2 2021 libnppidei.so.10 -> libnppidei.so.10.2.1.300
-rw-r--r-- 1 root root 8175688 3月 2 2021 libnppidei.so.10.2.1.300
-rw-r--r-- 1 root root 10762478 3月 2 2021 libnppidei_static.a
lrwxrwxrwx 1 root root 14 3月 2 2021 libnppif.so -> libnppif.so.10
lrwxrwxrwx 1 root root 22 3月 2 2021 libnppif.so.10 -> libnppif.so.10.2.1.300
-rw-r--r-- 1 root root 54362944 3月 2 2021 libnppif.so.10.2.1.300
-rw-r--r-- 1 root root 58471042 3月 2 2021 libnppif_static.a
lrwxrwxrwx 1 root root 14 3月 2 2021 libnppig.so -> libnppig.so.10
lrwxrwxrwx 1 root root 22 3月 2 2021 libnppig.so.10 -> libnppig.so.10.2.1.300
-rw-r--r-- 1 root root 28761920 3月 2 2021 libnppig.so.10.2.1.300
-rw-r--r-- 1 root root 31432462 3月 2 2021 libnppig_static.a
lrwxrwxrwx 1 root root 14 3月 2 2021 libnppim.so -> libnppim.so.10
lrwxrwxrwx 1 root root 22 3月 2 2021 libnppim.so.10 -> libnppim.so.10.2.1.300
-rw-r--r-- 1 root root 7163640 3月 2 2021 libnppim.so.10.2.1.300
-rw-r--r-- 1 root root 7396476 3月 2 2021 libnppim_static.a
lrwxrwxrwx 1 root root 15 3月 2 2021 libnppist.so -> libnppist.so.10
lrwxrwxrwx 1 root root 23 3月 2 2021 libnppist.so.10 -> libnppist.so.10.2.1.300
-rw-r--r-- 1 root root 20877336 3月 2 2021 libnppist.so.10.2.1.300
-rw-r--r-- 1 root root 23399160 3月 2 2021 libnppist_static.a
lrwxrwxrwx 1 root root 15 3月 2 2021 libnppisu.so -> libnppisu.so.10
lrwxrwxrwx 1 root root 23 3月 2 2021 libnppisu.so.10 -> libnppisu.so.10.2.1.300
-rw-r--r-- 1 root root 486576 3月 2 2021 libnppisu.so.10.2.1.300
-rw-r--r-- 1 root root 11458 3月 2 2021 libnppisu_static.a
lrwxrwxrwx 1 root root 15 3月 2 2021 libnppitc.so -> libnppitc.so.10
lrwxrwxrwx 1 root root 23 3月 2 2021 libnppitc.so.10 -> libnppitc.so.10.2.1.300
-rw-r--r-- 1 root root 3112480 3月 2 2021 libnppitc.so.10.2.1.300
-rw-r--r-- 1 root root 3205362 3月 2 2021 libnppitc_static.a
lrwxrwxrwx 1 root root 13 3月 2 2021 libnpps.so -> libnpps.so.10
lrwxrwxrwx 1 root root 21 3月 2 2021 libnpps.so.10 -> libnpps.so.10.2.1.300
-rw-r--r-- 1 root root 9539760 3月 2 2021 libnpps.so.10.2.1.300
-rw-r--r-- 1 root root 10690508 3月 2 2021 libnpps_static.a
lrwxrwxrwx 1 root root 18 3月 2 2021 libnvToolsExt.so -> libnvToolsExt.so.1
lrwxrwxrwx 1 root root 22 3月 2 2021 libnvToolsExt.so.1 -> libnvToolsExt.so.1.0.0
-rw-r--r-- 1 root root 44088 3月 2 2021 libnvToolsExt.so.1.0.0
lrwxrwxrwx 1 root root 15 3月 2 2021 libnvblas.so -> libnvblas.so.10
lrwxrwxrwx 1 root root 23 3月 2 2021 libnvblas.so.10 -> libnvblas.so.10.2.3.300
-rw-r--r-- 1 root root 540232 3月 2 2021 libnvblas.so.10.2.3.300
lrwxrwxrwx 1 root root 16 3月 2 2021 libnvgraph.so -> libnvgraph.so.10
lrwxrwxrwx 1 root root 22 3月 2 2021 libnvgraph.so.10 -> libnvgraph.so.10.2.300
-rw-r--r-- 1 root root 165012616 3月 2 2021 libnvgraph.so.10.2.300
-rw-r--r-- 1 root root 168141386 3月 2 2021 libnvgraph_static.a
-rw-r--r-- 1 root root 7430712 3月 2 2021 libnvperf_host.so
-rw-r--r-- 1 root root 1096016 3月 2 2021 libnvperf_target.so
lrwxrwxrwx 1 root root 25 3月 2 2021 libnvrtc-builtins.so -> libnvrtc-builtins.so.10.2
lrwxrwxrwx 1 root root 29 3月 2 2021 libnvrtc-builtins.so.10.2 -> libnvrtc-builtins.so.10.2.300
-rw-r--r-- 1 root root 4794168 3月 2 2021 libnvrtc-builtins.so.10.2.300
lrwxrwxrwx 1 root root 16 3月 2 2021 libnvrtc.so -> libnvrtc.so.10.2
lrwxrwxrwx 1 root root 20 3月 2 2021 libnvrtc.so.10.2 -> libnvrtc.so.10.2.300
-rw-r--r-- 1 root root 20432800 3月 2 2021 libnvrtc.so.10.2.300
drwxr-xr-x 2 root root 4096 5月 18 14:20 stubs
Next,
I tried ls -ll /etc/nvidia-container-runtime/host-files-for-container.d/. The result is below.
$ sudo docker run -it --rm --runtime nvidia --network host nvcr.io/nvidia/l4t-pytorch:r32.7.1-pth1.9-py3
root@desktop:/# -ll /etc/nvidia-container-runtime/host-files-for-container.d/
bash: -ll: command not found
root@desktop:/# ls -ll /etc/nvidia-container-runtime/host-files-for-container.d/
ls: cannot access '/etc/nvidia-container-runtime/host-files-for-container.d/': No such file or directory
Could you please tell me how this works fine?
I know how to mount Docker, but I don’t know what I need to mount.
Thank you for your advice.
Hi
I understand the cause.
I flashed Jetpack 4.6.1 again.
and,
I confirmed that it is R32.7.1 with the cat / etc / nv_tegra_release command.
I chose a suitable l4t-pytorch by referring to the following.
I used nvcr.io/nvidia/l4t-pytorch: r32.7.1-pth1.9-py3.
Then I was able to execute it without any problems.
Thank you everyone.
system
Closed
July 13, 2022, 2:17am
11
