docker run --hostname $(hostname) --network host --runtime nvidia --privileged --rm -itd nvcr.io/nvidia/l4t-ml:r32.7.1-py3
docker attach 74153d46c073
root@xavier-nx:/# python3
Python 3.6.9 (default, Dec 8 2021, 21:08:43)
[GCC 8.4.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import torch
File "<stdin>", line 1, in <module>
File "/usr/local/lib/python3.6/dist-packages/torch/__init__.py", line 196, in <module>
_load_global_deps()
File "/usr/local/lib/python3.6/dist-packages/torch/__init__.py", line 149, in _load_global_deps
ctypes.CDLL(lib_path, mode=ctypes.RTLD_GLOBAL)
File "/usr/lib/python3.6/ctypes/__init__.py", line 348, in __init__
self._handle = _dlopen(self._name, mode)
OSError: libcurand.so.10: cannot open shared object file: No such file or directory
This happens typically as a result of partial link from host /usr/local/cuda-10.2/ to container
Then inside container:
root@airlab-wildfire-ordv2:/# ll /usr/local/cuda-10.2/lib64/
total 1544
drwxr-xr-x 1 root root 4096 Dec 15 2021 ./
drwxr-xr-x 1 root root 4096 Dec 15 2021 ../
-rw-r--r-- 1 root root 679636 Dec 15 2021 libcudadevrt.a
-rw-r--r-- 1 root root 888074 Dec 15 2021 libcudart_static.a
drwxr-xr-x 2 root root 4096 Dec 15 2021 stubs/
Whereas on host:
total 2.2G
lrwxrwxrwx 1 root root 17 Mar 1 2021 libcublasLt.so -> libcublasLt.so.10
lrwxrwxrwx 1 root root 25 Mar 1 2021 libcublasLt.so.10 -> libcublasLt.so.10.2.3.300
-rw-r--r-- 1 root root 33M Mar 1 2021 libcublasLt.so.10.2.3.300
-rw-r--r-- 1 root root 35M Mar 1 2021 libcublasLt_static.a
lrwxrwxrwx 1 root root 15 Mar 1 2021 libcublas.so -> libcublas.so.10
lrwxrwxrwx 1 root root 23 Mar 1 2021 libcublas.so.10 -> libcublas.so.10.2.3.300
-rw-r--r-- 1 root root 78M Mar 1 2021 libcublas.so.10.2.3.300
-rw-r--r-- 1 root root 93M Mar 1 2021 libcublas_static.a
-rw-r--r-- 1 root root 664K Mar 1 2021 libcudadevrt.a
lrwxrwxrwx 1 root root 17 Mar 1 2021 libcudart.so -> libcudart.so.10.2
lrwxrwxrwx 1 root root 21 Mar 1 2021 libcudart.so.10.2 -> libcudart.so.10.2.300
-rw-r--r-- 1 root root 480K Mar 1 2021 libcudart.so.10.2.300
-rw-r--r-- 1 root root 868K Mar 1 2021 libcudart_static.a
lrwxrwxrwx 1 root root 14 Mar 1 2021 libcufft.so -> libcufft.so.10
lrwxrwxrwx 1 root root 22 Mar 1 2021 libcufft.so.10 -> libcufft.so.10.1.2.300
-rw-r--r-- 1 root root 193M Mar 1 2021 libcufft.so.10.1.2.300
-rw-r--r-- 1 root root 184M Mar 1 2021 libcufft_static.a
-rw-r--r-- 1 root root 201M Mar 1 2021 libcufft_static_nocallback.a
lrwxrwxrwx 1 root root 15 Mar 1 2021 libcufftw.so -> libcufftw.so.10
lrwxrwxrwx 1 root root 23 Mar 1 2021 libcufftw.so.10 -> libcufftw.so.10.1.2.300
-rw-r--r-- 1 root root 492K Mar 1 2021 libcufftw.so.10.1.2.300
-rw-r--r-- 1 root root 32K Mar 1 2021 libcufftw_static.a
lrwxrwxrwx 1 root root 18 Mar 1 2021 libcuinj64.so -> libcuinj64.so.10.2
lrwxrwxrwx 1 root root 22 Mar 1 2021 libcuinj64.so.10.2 -> libcuinj64.so.10.2.300
-rw-r--r-- 1 root root 1.5M Mar 1 2021 libcuinj64.so.10.2.300
-rw-r--r-- 1 root root 33K Mar 1 2021 libculibos.a
lrwxrwxrwx 1 root root 16 Mar 1 2021 libcupti.so -> libcupti.so.10.2
lrwxrwxrwx 1 root root 20 Mar 1 2021 libcupti.so.10.2 -> libcupti.so.10.2.175
-rw-r--r-- 1 root root 4.4M Mar 1 2021 libcupti.so.10.2.175
lrwxrwxrwx 1 root root 15 Mar 1 2021 libcurand.so -> libcurand.so.10
lrwxrwxrwx 1 root root 23 Mar 1 2021 libcurand.so.10 -> libcurand.so.10.1.2.300
-rw-r--r-- 1 root root 60M Mar 1 2021 libcurand.so.10.1.2.300
-rw-r--r-- 1 root root 60M Mar 1 2021 libcurand_static.a
lrwxrwxrwx 1 root root 17 Mar 1 2021 libcusolver.so -> libcusolver.so.10
lrwxrwxrwx 1 root root 25 Mar 1 2021 libcusolver.so.10 -> libcusolver.so.10.3.0.300
-rw-r--r-- 1 root root 209M Mar 1 2021 libcusolver.so.10.3.0.300
-rw-r--r-- 1 root root 119M Mar 1 2021 libcusolver_static.a
lrwxrwxrwx 1 root root 17 Mar 1 2021 libcusparse.so -> libcusparse.so.10
lrwxrwxrwx 1 root root 25 Mar 1 2021 libcusparse.so.10 -> libcusparse.so.10.3.1.300
-rw-r--r-- 1 root root 135M Mar 1 2021 libcusparse.so.10.3.1.300
-rw-r--r-- 1 root root 143M Mar 1 2021 libcusparse_static.a
-rw-r--r-- 1 root root 8.0M Mar 1 2021 liblapack_static.a
-rw-r--r-- 1 root root 888K Mar 1 2021 libmetis_static.a
lrwxrwxrwx 1 root root 13 Mar 1 2021 libnppc.so -> libnppc.so.10
lrwxrwxrwx 1 root root 21 Mar 1 2021 libnppc.so.10 -> libnppc.so.10.2.1.300
-rw-r--r-- 1 root root 492K Mar 1 2021 libnppc.so.10.2.1.300
-rw-r--r-- 1 root root 27K Mar 1 2021 libnppc_static.a
lrwxrwxrwx 1 root root 15 Mar 1 2021 libnppial.so -> libnppial.so.10
lrwxrwxrwx 1 root root 23 Mar 1 2021 libnppial.so.10 -> libnppial.so.10.2.1.300
-rw-r--r-- 1 root root 11M Mar 1 2021 libnppial.so.10.2.1.300
-rw-r--r-- 1 root root 14M Mar 1 2021 libnppial_static.a
lrwxrwxrwx 1 root root 15 Mar 1 2021 libnppicc.so -> libnppicc.so.10
lrwxrwxrwx 1 root root 23 Mar 1 2021 libnppicc.so.10 -> libnppicc.so.10.2.1.300
-rw-r--r-- 1 root root 4.7M Mar 1 2021 libnppicc.so.10.2.1.300
-rw-r--r-- 1 root root 5.5M Mar 1 2021 libnppicc_static.a
lrwxrwxrwx 1 root root 16 Mar 1 2021 libnppicom.so -> libnppicom.so.10
lrwxrwxrwx 1 root root 24 Mar 1 2021 libnppicom.so.10 -> libnppicom.so.10.2.1.300
-rw-r--r-- 1 root root 1.4M Mar 1 2021 libnppicom.so.10.2.1.300
-rw-r--r-- 1 root root 1.1M Mar 1 2021 libnppicom_static.a
lrwxrwxrwx 1 root root 16 Mar 1 2021 libnppidei.so -> libnppidei.so.10
lrwxrwxrwx 1 root root 24 Mar 1 2021 libnppidei.so.10 -> libnppidei.so.10.2.1.300
-rw-r--r-- 1 root root 7.8M Mar 1 2021 libnppidei.so.10.2.1.300
-rw-r--r-- 1 root root 11M Mar 1 2021 libnppidei_static.a
lrwxrwxrwx 1 root root 14 Mar 1 2021 libnppif.so -> libnppif.so.10
lrwxrwxrwx 1 root root 22 Mar 1 2021 libnppif.so.10 -> libnppif.so.10.2.1.300
-rw-r--r-- 1 root root 52M Mar 1 2021 libnppif.so.10.2.1.300
-rw-r--r-- 1 root root 56M Mar 1 2021 libnppif_static.a
lrwxrwxrwx 1 root root 14 Mar 1 2021 libnppig.so -> libnppig.so.10
lrwxrwxrwx 1 root root 22 Mar 1 2021 libnppig.so.10 -> libnppig.so.10.2.1.300
-rw-r--r-- 1 root root 28M Mar 1 2021 libnppig.so.10.2.1.300
-rw-r--r-- 1 root root 30M Mar 1 2021 libnppig_static.a
lrwxrwxrwx 1 root root 14 Mar 1 2021 libnppim.so -> libnppim.so.10
lrwxrwxrwx 1 root root 22 Mar 1 2021 libnppim.so.10 -> libnppim.so.10.2.1.300
-rw-r--r-- 1 root root 6.9M Mar 1 2021 libnppim.so.10.2.1.300
-rw-r--r-- 1 root root 7.1M Mar 1 2021 libnppim_static.a
lrwxrwxrwx 1 root root 15 Mar 1 2021 libnppist.so -> libnppist.so.10
lrwxrwxrwx 1 root root 23 Mar 1 2021 libnppist.so.10 -> libnppist.so.10.2.1.300
-rw-r--r-- 1 root root 20M Mar 1 2021 libnppist.so.10.2.1.300
-rw-r--r-- 1 root root 23M Mar 1 2021 libnppist_static.a
lrwxrwxrwx 1 root root 15 Mar 1 2021 libnppisu.so -> libnppisu.so.10
lrwxrwxrwx 1 root root 23 Mar 1 2021 libnppisu.so.10 -> libnppisu.so.10.2.1.300
-rw-r--r-- 1 root root 476K Mar 1 2021 libnppisu.so.10.2.1.300
-rw-r--r-- 1 root root 12K Mar 1 2021 libnppisu_static.a
lrwxrwxrwx 1 root root 15 Mar 1 2021 libnppitc.so -> libnppitc.so.10
lrwxrwxrwx 1 root root 23 Mar 1 2021 libnppitc.so.10 -> libnppitc.so.10.2.1.300
-rw-r--r-- 1 root root 3.0M Mar 1 2021 libnppitc.so.10.2.1.300
-rw-r--r-- 1 root root 3.1M Mar 1 2021 libnppitc_static.a
lrwxrwxrwx 1 root root 13 Mar 1 2021 libnpps.so -> libnpps.so.10
lrwxrwxrwx 1 root root 21 Mar 1 2021 libnpps.so.10 -> libnpps.so.10.2.1.300
-rw-r--r-- 1 root root 9.1M Mar 1 2021 libnpps.so.10.2.1.300
-rw-r--r-- 1 root root 11M Mar 1 2021 libnpps_static.a
lrwxrwxrwx 1 root root 15 Mar 1 2021 libnvblas.so -> libnvblas.so.10
lrwxrwxrwx 1 root root 23 Mar 1 2021 libnvblas.so.10 -> libnvblas.so.10.2.3.300
-rw-r--r-- 1 root root 528K Mar 1 2021 libnvblas.so.10.2.3.300
lrwxrwxrwx 1 root root 16 Mar 1 2021 libnvgraph.so -> libnvgraph.so.10
lrwxrwxrwx 1 root root 22 Mar 1 2021 libnvgraph.so.10 -> libnvgraph.so.10.2.300
-rw-r--r-- 1 root root 158M Mar 1 2021 libnvgraph.so.10.2.300
-rw-r--r-- 1 root root 161M Mar 1 2021 libnvgraph_static.a
-rw-r--r-- 1 root root 7.1M Mar 1 2021 libnvperf_host.so
-rw-r--r-- 1 root root 1.1M Mar 1 2021 libnvperf_target.so
lrwxrwxrwx 1 root root 25 Mar 1 2021 libnvrtc-builtins.so -> libnvrtc-builtins.so.10.2
lrwxrwxrwx 1 root root 29 Mar 1 2021 libnvrtc-builtins.so.10.2 -> libnvrtc-builtins.so.10.2.300
-rw-r--r-- 1 root root 4.6M Mar 1 2021 libnvrtc-builtins.so.10.2.300
lrwxrwxrwx 1 root root 16 Mar 1 2021 libnvrtc.so -> libnvrtc.so.10.2
lrwxrwxrwx 1 root root 20 Mar 1 2021 libnvrtc.so.10.2 -> libnvrtc.so.10.2.300
-rw-r--r-- 1 root root 20M Mar 1 2021 libnvrtc.so.10.2.300
lrwxrwxrwx 1 root root 18 Mar 1 2021 libnvToolsExt.so -> libnvToolsExt.so.1
lrwxrwxrwx 1 root root 22 Mar 1 2021 libnvToolsExt.so.1 -> libnvToolsExt.so.1.0.0
-rw-r--r-- 1 root root 44K Mar 1 2021 libnvToolsExt.so.1.0.0
drwxr-xr-x 2 root root 4.0K Mar 29 19:13 stubs
This results in me having to docker run -v /usr/local/cuda-10.2:/usr/local/cuda-10.2:ro everytime.
Please fix this ASAP, I assume the nvidia-docker2 right now is still immature.
I was also trying to build Torch-TensorRT inside the dockerfile, but it didn’t work even though I’ve correctly set the /etc/docker/deamon.json:
"runtimes": {
"nvidia": {
"path": "nvidia-container-runtime",
"runtimeArgs": []
"default-runtime": "nvidia"
However, it didn’t work, so I have to put it into a second stage after I’ve docker run -v /usr/local/cuda-10.2:/usr/local/cuda-10.2:ro the CPU-only image
Similar things happen to cuDNN libraries
I don’t want to install the bulky nvidia-cuda and nvidia-l4t-cuda or other sub-packages of nvidia-jetpack
It’ll be nice if VPI and other sub-packages of nvidia-jetpack can also be automatically mounted
