Hi
I used the L4T Base from the NGC catalog to create the container. I’m trying to install Pytorch and torchvision in this created container, but it fails.
People tell me why not use the NVIDIA L4T PyTorch from the NGC catalog.
However, NVIDIA L4T PyTorch has a large file size. My disk is not so free.
I pulled the following to match my Orin’s Jetpack.
$ sudo docker pull nvcr.io/nvidia/l4t-base:r35.1.0
I used the following to install Pytorch and torchvision.
Inside the docker container, pytorch installation is fine. succeed.
Inside the Docker container, I ran the following in order on my torchvision installation:
# apt-get install libjpeg-dev zlib1g-dev libpython3-dev libavcodec-dev libavformat-dev libswscale-dev
# python3 setup.py install --user
Running setup.py outputs the following error:
root@ubuntu:/yolo/torchvision# python3 setup.py install --user
File "setup.py", line 9, in <module>
import torch
File "/usr/local/lib/python3.8/dist-packages/torch/__init__.py", line 198, in <module>
_load_global_deps()
File "/usr/local/lib/python3.8/dist-packages/torch/__init__.py", line 151, in _load_global_deps
ctypes.CDLL(lib_path, mode=ctypes.RTLD_GLOBAL)
File "/usr/lib/python3.8/ctypes/__init__.py", line 373, in __init__
self._handle = _dlopen(self._name, mode)
OSError: libcurand.so.10: cannot open shared object file: No such file or directory
What is the reason for this? help me.
