Hi all,
I’ve been reading the API and reference on OpenCL and one thing I cannot figure out for the life of me is that whether the specifications for the bit-fields are Least Significant Bit or Most Significant Bit first as listed from top to bottom.
For example: Page 35 of http://www.khronos.org/registry/cl/specs/opencl-1.0.pdf
Under CL_DEVICE_SINGLE_FP_CONFIG
If only FP_DENORM is enabled, is it 000001 or 100000?
Does anyone know which is the case?
Take a look at the header file to be sure…
David
