either that or put a # in front of it to comment it out.
Done that, still same.
No idea what’s going on. Without logs, I’m blind.
Please delete any config files you created, uninstall the runfile driver using the --uinstall option, then folow this to install the repo driver:
https://en.opensuse.org/SDB:NVIDIA_drivers
I can rollback to the before of the driver installation and then try to install it from repos but I’ve tried it already before…
Did you have a desktop before installing the driver in any way?
Yep, I was able to use both of my screens and was using KDE plasma
Then please create a new nvidia-bug-report.log, rool back and upload the all reports so I can see what happened.
I’m creating a debug log and then rollback and send the log right?
nvidia-bug-report.log.gz (735.8 KB)
Looks like the nvidia driver only loaded too late because it’s not in the initrd.
Please install the driver from repo, then create
/etc/dracut.conf.d/nvidia.conf
add_drivers+="nvidia nvidia-modeset nvidia-drm"
run sudo dracut -f
and reboot.
Added repo, installing drivers and dependencies of it, 436mb.
Done but again I see only the cursor and the _ again
I found a way to upload logs called transfer.sh uploading logs using it
The nvidia driver is still loading too late. I guess suse has a dracut config that prevents the nvidia driver from being embedded into the initrd, please see this:
https://forums.developer.nvidia.com/t/cant-run-any-program-via-nvidia-card/169074/6?u=generix
Can it be because of mokutil?
No, that has nothing to do with it.
I have 99-debug.conf, nvidia.conf and ostree.conf in my /etc/dracut.conf.d should I create 60-nvidia-default.conf and write them into it?
Update:added blacklist nouveau and tried it, it booted using intel HD Graphics. Tried adding nvidia-drm.modeset=1 and it is broken again
Added them to /etc/modprobe.d/nvidia.conf
