Please help.
After installing NVidia drivers, ubuntu boots with black screen or login screen that freezes.
I tried installing different driver versions. 390, 418, 440, 450, 460. I tried installing via the software & updates additional drivers GUI and with cmd via ppa.nvidia-bug-report.log.gz (165.6 KB)
Please delete /etc/X11/xorg.conf or any file whose name begins with it.
Thank you, but after reloading, the size of the screen isn’t right, with drivers > 400 I can’t even see the login prompt. 390 seems to be working right but it doesn’t detect the external display.
Please create a new nvidia-bug-report.log.
@generix, any suggestions?
Not having the external monitor with the 390 driver is a known bug with the old driver, workaround
https://devtalk.nvidia.com/default/topic/1066683/linux/ubuntu-18-04-3-blank-screen-at-startup-with-430-drivers-and-gtx-960/post/5402308/#5402308
Why you’re getting the odd display with the 460 driver is new to me, the logs look fine for it. I’ll have to take a closer look at it tomorrow.
Can you switch to VT (ctrl+alt+f4) while seeing only the backgroud with the 460 driver and create a new nvidia-bug-report.log?
@generix any suggestions?
Please help, it’s really important for me.
I don’t really know what’s going on with the 460 driver, the Xserver is coming up correctly but gnome-shell doesn’t seem to start.
Please run
sudo journalctl -b0 |grep gnome-shell >journal.txt
while bootng with the 460 driver and attach journal.txt.
Also, please post the output of
ls -l /usr/lib/x86_64-linux-gnu/libGL*
lrwxrwxrwx 1 root root 18 лис 24 12:55 /usr/lib/x86_64-linux-gnu/libGLdispatch.so -> libGLdispatch.so.0
lrwxrwxrwx 1 root root 22 кві 19 00:30 /usr/lib/x86_64-linux-gnu/libGLdispatch.so.0 -> libGLdispatch.so.0.0.0
-rw-r--r-- 1 root root 715200 лис 24 12:55 /usr/lib/x86_64-linux-gnu/libGLdispatch.so.0.0.0
lrwxrwxrwx 1 root root 32 кві 9 16:59 /usr/lib/x86_64-linux-gnu/libGLESv1_CM_nvidia.so.1 -> libGLESv1_CM_nvidia.so.460.73.01
-rw-r--r-- 1 root root 67880 кві 2 00:32 /usr/lib/x86_64-linux-gnu/libGLESv1_CM_nvidia.so.460.73.01
lrwxrwxrwx 1 root root 17 лис 24 12:55 /usr/lib/x86_64-linux-gnu/libGLESv1_CM.so -> libGLESv1_CM.so.1
lrwxrwxrwx 1 root root 21 лис 24 12:55 /usr/lib/x86_64-linux-gnu/libGLESv1_CM.so.1 -> libGLESv1_CM.so.1.2.0
-rw-r--r-- 1 root root 43336 лис 24 12:55 /usr/lib/x86_64-linux-gnu/libGLESv1_CM.so.1.2.0
lrwxrwxrwx 1 root root 29 кві 9 16:59 /usr/lib/x86_64-linux-gnu/libGLESv2_nvidia.so.2 -> libGLESv2_nvidia.so.460.73.01
-rw-r--r-- 1 root root 117032 кві 2 00:32 /usr/lib/x86_64-linux-gnu/libGLESv2_nvidia.so.460.73.01
lrwxrwxrwx 1 root root 14 лис 24 12:55 /usr/lib/x86_64-linux-gnu/libGLESv2.so -> libGLESv2.so.2
lrwxrwxrwx 1 root root 18 кві 19 00:30 /usr/lib/x86_64-linux-gnu/libGLESv2.so.2 -> libGLESv2.so.2.1.0
-rw-r--r-- 1 root root 72008 лис 24 12:55 /usr/lib/x86_64-linux-gnu/libGLESv2.so.2.1.0
lrwxrwxrwx 1 root root 10 лис 24 12:55 /usr/lib/x86_64-linux-gnu/libGL.so -> libGL.so.1
lrwxrwxrwx 1 root root 14 кві 19 00:30 /usr/lib/x86_64-linux-gnu/libGL.so.1 -> libGL.so.1.7.0
-rw-r--r-- 1 root root 547152 лис 24 12:55 /usr/lib/x86_64-linux-gnu/libGL.so.1.7.0
lrwxrwxrwx 1 root root 15 кві 19 00:30 /usr/lib/x86_64-linux-gnu/libGLU.so.1 -> libGLU.so.1.3.1
-rw-r--r-- 1 root root 461624 бер 21 2020 /usr/lib/x86_64-linux-gnu/libGLU.so.1.3.1
lrwxrwxrwx 1 root root 16 кві 19 00:30 /usr/lib/x86_64-linux-gnu/libGLX_indirect.so.0 -> libGLX_mesa.so.0
lrwxrwxrwx 1 root root 20 кві 19 00:30 /usr/lib/x86_64-linux-gnu/libGLX_mesa.so.0 -> libGLX_mesa.so.0.0.0
-rw-r--r-- 1 root root 508984 гру 18 10:35 /usr/lib/x86_64-linux-gnu/libGLX_mesa.so.0.0.0
lrwxrwxrwx 1 root root 26 кві 9 16:59 /usr/lib/x86_64-linux-gnu/libGLX_nvidia.so.0 -> libGLX_nvidia.so.460.73.01
-rw-r--r-- 1 root root 1211504 кві 2 00:31 /usr/lib/x86_64-linux-gnu/libGLX_nvidia.so.460.73.01
lrwxrwxrwx 1 root root 11 лис 24 12:55 /usr/lib/x86_64-linux-gnu/libGLX.so -> libGLX.so.0
lrwxrwxrwx 1 root root 15 кві 19 00:30 /usr/lib/x86_64-linux-gnu/libGLX.so.0 -> libGLX.so.0.0.0
-rw-r--r-- 1 root root 141912 лис 24 12:55 /usr/lib/x86_64-linux-gnu/libGLX.so.0.0.0
Mysterious, gnome-shell seems to start just fine but I don’t know where, the nvidia gpu is only running the Xserver. Please try creating two files optimus.desktop in /etc/xdg/autostart/ and /usr/share/gdm3/greeter/autostart/ containing
[Desktop Entry]
Type=Application
Name=Optimus
Exec=sh -c "xrandr --setprovideroutputsource modesetting NVIDIA-0; xrandr --auto"
NoDisplay=true
X-GNOME-Autostart-Phase=DisplayServer
I did but the situation is the same.;(
- Added this file into 2 directories;
- Switched to nvidia;
- Rebooted.
No idea. You could try switching to lightdm instead of gdm.
