I am currently running Asus FX505DD (Ryzen 5 3550H + 1050 3GB Max-Q)
Seems like the driver is not working (correctly?)
I went from Ubuntu 18.04 to 19.10 expecting it to start working, but no luck.
I tried download drivers using ppa and “Additional Drivers”
At best I was ending up with black screen.
The graphics card is not appearing in Settings > Details too
Settings > Details:
Ubuntu 19.10
Device name : tomdery-fx505DD
Memory : 7,6GiB
Processor : AMD Ryzen 5 3550H with radeon vega mobile gfx x 8
Graphics : AMD Raven
GNOME : 3.34.2
OS type : 64-bit
Disk : 250.1GB (don't know why it is showing up as a full disc, because its a 165GB/82GB partition)
$ uname -a
Linux tomdery-FX505DD 5.3.0-29-generic #31-Ubuntu SMP Fri Jan 17 17:27:26 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
$ nvidia-smi
Tue Feb 11 21:35:05 2020
| NVIDIA-SMI 440.59 Driver Version: 440.59 CUDA Version: 10.2 |
| 0 GeForce GTX 1050 Off | 00000000:01:00.0 Off | N/A |
| N/A 39C P0 N/A / N/A | 0MiB / 3020MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
$ prime-select query
nvidia
$ ubuntu-drivers devices
== /sys/devices/pci0000:00/0000:00:01.1/0000:01:00.0 ==
modalias : pci:v000010DEd00001C91sv00001043sd000018F1bc03sc00i00
vendor : NVIDIA Corporation
driver : nvidia-driver-435 - distro non-free
driver : nvidia-driver-440 - third-party free recommended
driver : nvidia-driver-430 - third-party free
driver : xserver-xorg-video-nouveau - distro free builtin
$ dmesg | grep -i nvidia
[ 2.917756] nvidia: module license 'NVIDIA' taints kernel.
[ 2.948852] nvidia-nvlink: Nvlink Core is being initialized, major device number 237
[ 2.950059] nvidia 0000:01:00.0: enabling device (0000 -> 0003)
[ 2.950960] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 3.050903] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 440.59 Thu Jan 30 01:00:41 UTC 2020
[ 3.100511] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 440.59 Thu Jan 30 00:59:18 UTC 2020
[ 3.424579] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 3.424581] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
[ 3.528870] nvidia-uvm: Loaded the UVM driver, major device number 234.
[ 3.559163] audit: type=1400 audit(1581445640.860:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=774 comm="apparmor_parser"
[ 3.559168] audit: type=1400 audit(1581445640.860:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=774 comm="apparmor_parser"
[ 4.238409] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input15
$ inxi -Fxzd
System:
Host: tomdery-FX505DD Kernel: 5.3.0-29-generic x86_64 bits: 64
compiler: gcc v: 9.2.1 Desktop: Gnome 3.34.1
Distro: Ubuntu 19.10 (Eoan Ermine)
Machine:
Type: Laptop System: ASUSTeK product: TUF Gaming FX505DD_FX505DD v: 1.0
serial: <filter>
Mobo: ASUSTeK model: FX505DD v: 1.0 serial: <filter>
UEFI: American Megatrends v: FX505DD.310 date: 12/24/2019
Battery:
ID-1: BAT0 charge: 29.3 Wh condition: 40.4/48.2 Wh (84%) model: FX50442
status: Discharging
CPU:
Topology: Quad Core model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen+ rev: 1 L2 cache: 2048 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 33540
Speed: 1240 MHz min/max: 1400/2100 MHz Core speeds (MHz): 1: 1363 2: 1315
3: 1252 4: 1276 5: 1333 6: 1323 7: 1337 8: 1246
Graphics:
Device-1: NVIDIA GP107M [GeForce GTX 1050 3 GB Max-Q] vendor: ASUSTeK
driver: nvidia v: 440.59 bus ID: 01:00.0
Device-2: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel
bus ID: 04:00.0
Display: x11 server: X.Org 1.20.5 driver: ati,fbdev
unloaded: modesetting,nouveau,nvidia,radeon,vesa
resolution: 1920x1080~120Hz
OpenGL: renderer: AMD RAVEN (DRM 3.33.0 5.3.0-29-generic LLVM 9.0.0)
v: 4.5 Mesa 19.2.8 direct render: Yes
Audio:
Device-1: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 01:00.1
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 04:00.6
Sound Server: ALSA v: k5.3.0-29-generic
Network:
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus ID: 02:00.0
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtl8821ce v: v5.2.5.2.1_xxxx.20181112_beta
port: d000 bus ID: 03:00.0
IF: wlp3s0 state: up mac: <filter>
Drives:
Local Storage: total: 232.89 GiB used: 10.08 GiB (4.3%)
ID-1: /dev/sda vendor: Crucial model: CT250MX500SSD1 size: 232.89 GiB
temp: 45 C
Message: No Optical or Floppy data was found.
Partition:
ID-1: / size: 76.40 GiB used: 10.04 GiB (13.1%) fs: ext4 dev: /dev/sda5
Sensors:
System Temperatures: cpu: 45.6 C mobo: N/A gpu: amdgpu temp: 45 C
Fan Speeds (RPM): cpu: 0
Info:
Processes: 337 Uptime: 46m Memory: 7.28 GiB used: 2.48 GiB (34.1%)
Init: systemd runlevel: 5 Compilers: gcc: 9.2.1 Shell: bash v: 5.0.3
inxi: 3.0.36
nvidia-bug-report.log.gz (404 KB)
