I’ve recompiled an nvidia kernel of release 28.2.1 and included all needed bluetooth modules:
CONFIG_BT=y
CONFIG_BT_BREDR=y
CONFIG_BT_RFCOMM=y
CONFIG_BT_RFCOMM_TTY=y
CONFIG_BT_BNEP=y
CONFIG_BT_BNEP_MC_FILTER=y
CONFIG_BT_BNEP_PROTO_FILTER=y
CONFIG_BT_HIDP=y
CONFIG_BT_HS=y
CONFIG_BT_LE=y
CONFIG_BT_SELFTEST is not set
CONFIG_BT_DEBUGFS=y
CONFIG_BT_INTEL=y
CONFIG_BT_BCM=y
CONFIG_BT_RTL=y
CONFIG_BT_QCA=y
CONFIG_BT_HCIBTUSB=y
CONFIG_BT_HCIBTUSB_BCM=y
CONFIG_BT_HCIBTUSB_RTL=y
CONFIG_BT_HCIBTSDIO=y
CONFIG_BT_HCIUART=y
CONFIG_BT_HCIUART_H4=y
CONFIG_BT_HCIUART_BCSP=y
CONFIG_BT_HCIUART_ATH3K=y
CONFIG_BT_HCIUART_LL=y
CONFIG_BT_HCIUART_3WIRE=y
CONFIG_BT_HCIUART_INTEL=y
CONFIG_BT_HCIUART_BCM=y
CONFIG_BT_HCIUART_QCA=y
CONFIG_BT_HCIBCM203X=y
CONFIG_BT_HCIBPA10X=y
CONFIG_BT_HCIBFUSB=y
CONFIG_BT_HCIVHCI=y
CONFIG_BT_MRVL=y
CONFIG_BT_MRVL_SDIO=y
CONFIG_BT_ATH3K=y
By default I see that hci0 is configured on a SDIO bus instead of a UART bus like on the devkit:
nvidia@cam5-71995:~$ hciconfig -a
hci0: Type: BR/EDR Bus: SDIO
BD Address: 00:00:00:00:00:00 ACL MTU: 0:0 SCO MTU: 0:0
DOWN
RX bytes:0 acl:0 sco:0 events:0 errors:0
TX bytes:0 acl:0 sco:0 commands:0 errors:0
Features: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Packet type: DM1 DH1 HV1
Link policy:
Link mode: SLAVE ACCEPT
On the devkit:
nvidia@tegra-ubuntu:/boot$ hciconfig -a
hci0: Type: BR/EDR Bus: UART
BD Address: 00:04:4B:C4:C7:9A ACL MTU: 1021:8 SCO MTU: 64:1
UP RUNNING PSCAN
RX bytes:6674693 acl:3748 sco:0 events:76856 errors:0
TX bytes:22060 acl:317 sco:0 commands:1347 errors:0
Features: 0xbf 0xfe 0xcf 0xfe 0xdb 0xff 0x7b 0x87
Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
Link policy: RSWITCH SNIFF
Class: 0x000000
Service Classes: Unspecified
Device Class: Miscellaneous,
HCI Version: 4.1 (0x7) Revision: 0x1000
LMP Version: 4.1 (0x7) Subversion: 0x610c
Manufacturer: Broadcom Corporation (15)
I tried to attach a device with hciattach but I get a connection timeout:
nvidia@cam5-71995:~$ sudo hciattach /dev/ttyTHS1 any
Device setup complete
hci1: Type: BR/EDR Bus: UART
DOWN INIT RUNNING
TX bytes:12 acl:0 sco:0 commands:3 errors:0
Link policy:
DOWN
Link policy:
nvidia@cam5-71995:~$ sudo hciconfig hci1 up
Can’t init device hci1: Connection timed out (110)
Also I found that the service nvwifibt is not running maybe because /proc/bluetooth/sleep/lpm is not existing.
Please help
