Does somebody else tried to run bodypose2D once on the jetson agx orin? deepstream in general is running on the agx orin, but not bodypose2d. there are some dependencies on an older library called libmyelin.so.1 which is not anymore used in the required trt8. some ideas around?
Bodypose2D is supported by Deepstream 6.1 which can work on Orin with JetPack 5.0.1 DP.
Could you share more details about the error you meet with us?
Please noted that the TensorRT engine doesn’t support portability.
If you are using an engine file created by previous TensorRT software, please recreate it again for JetPack 5.
