Hello! I’m trying to bring up Ampak AP6256 chip, which uses BCM43456 chip for WiFi but I’m having weird problems with the driver. I have connected everything and the pins have voltages as they should but none of the Broadcom drivers (brcmfc or bcmdhd) work for me.
This is how I set up SDMMC device tree:
wifi_pwrseq: wifi-pwrseq {
compatible = "mmc-pwrseq-simple";
reset-gpios = <&tegra_main_gpio TEGRA_MAIN_GPIO(C, 1) GPIO_ACTIVE_LOW>;
post-power-on-delay-ms = <300>;
power-off-delay-us = <300>;
&sdmmc3 {
#address-cells = <1>;
#size-cells = <0>;
mmc-pwrseq = <&wifi_pwrseq>;
uhs-mask = <0x8>;
only-1-8-v;
non-removable;
force-non-removable-rescan;
no-sd;
max-clk-limit = <25000000>;
status = "okay";
Here’s bcmdhd
log and device tree - it fails on power up but it clearly does pull the wlan-pwr-gpio
pin correctly, when checked with multimeter:
bcmdhd_wlan {
compatible = "android,bcmdhd_wlan";
interrupt-parent = <&tegra_main_gpio>;
interrupts = <TEGRA_MAIN_GPIO(L, 0) IRQ_TYPE_LEVEL_HIGH>;
wlan-pwr-gpio = <&tegra_main_gpio TEGRA_MAIN_GPIO(C, 1) 0>;
fw_path = "/lib/firmware/brcm/fw_bcmdhd.bin";
nv_path = "/lib/firmware/brcm/nvram.txt";
sdhci-host = <&sdmmc3>;
pwr-retry-cnt = <3>;
status = "okay";
[ 99.857230] dhd_module_init in
[ 99.857299] found wifi platform device bcmdhd_wlan
[ 99.858171] Failed to request wlan_pwr gpio 337
[ 99.858204] wifi_platform_get_country_code_map: could not get country_code_map
[ 99.858207] wifi_plat_dev_drv_probe:platform country code map is not available
[ 99.858223] Power-up adapter 'DHD generic adapter'
[ 99.858229] wifi_platform_set_power = 1
[ 100.062596] wifi_platform_bus_enumerate device present 1
[ 102.066489] failed to power up DHD generic adapter, 3 retry left
[ 102.082746] wifi_platform_set_power = 0
[ 102.290528] wifi_platform_bus_enumerate device present 0
[ 102.290561] wifi_platform_set_power = 1
[ 102.498524] wifi_platform_bus_enumerate device present 1
[ 102.501092] mmc1: card 0001 removed
[ 102.501197] sdhci-tegra 3440000.sdhci: Tuning done, restoring the best tap value : 230
[ 102.967383] sdhci-tegra 3440000.sdhci: Tuning done, restoring the best tap value : 230
[ 102.977659] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 104.530508] failed to power up DHD generic adapter, 2 retry left
[ 104.546698] wifi_platform_set_power = 0
[ 104.754514] wifi_platform_bus_enumerate device present 0
[ 104.754540] wifi_platform_set_power = 1
[ 104.962573] wifi_platform_bus_enumerate device present 1
[ 104.965360] mmc1: card 0001 removed
[ 104.965446] sdhci-tegra 3440000.sdhci: Tuning done, restoring the best tap value : 230
[ 105.432519] sdhci-tegra 3440000.sdhci: Tuning done, restoring the best tap value : 230
[ 105.443410] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 106.994536] failed to power up DHD generic adapter, 1 retry left
[ 107.010797] wifi_platform_set_power = 0
[ 107.218553] wifi_platform_bus_enumerate device present 0
[ 107.218587] wifi_platform_set_power = 1
[ 107.426604] wifi_platform_bus_enumerate device present 1
[ 107.428595] mmc1: card 0001 removed
[ 107.428671] sdhci-tegra 3440000.sdhci: Tuning done, restoring the best tap value : 230
[ 107.894563] sdhci-tegra 3440000.sdhci: Tuning done, restoring the best tap value : 230
[ 107.905434] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 107.905881] Exceeded the total number of cards allowed
[ 107.911106] mmcblk: probe of mmc1:0001 failed with error -22
As for brcmfmac driver - it can’t even get the platform data:
[ 227.163203] brcmfmac: brcmfmac_module_init No platform data available.
brcmfmac dtsi:
&sdmmc3 {
#size-cells = <0>;
uhs-mask = <0x8>;
only-1-8-v;
non-removable;
no-sd;
status = "okay";
brcmfmac: brcmfmac@1 {
reg = <1>;
compatible = "brcm,bcm4329-fmac";
Thanks in advance!
