I am facing issue in WiFi bring up on custom carrier board with Jetson Xavier NX module.
I am using BCM43455 module and using SDIO interface. I have defined dts like this,
sdhci@3440000 {
#address-cells = <1>;
#size-cells = <0>;
compatible = "nvidia,tegra194-sdhci";
reg = <0x0 0x3440000 0x0 0x00020000>;
interrupts = < 0 TEGRA194_IRQ_SDMMC3 0x04>;
iommus = <&smmu TEGRA_SID_SDMMC3A>;
dma-coherent;
max-clk-limit = <208000000>;
bus-width = <4>;
cap-mmc-highspeed;
cap-sd-highspeed;
sd-uhs-sdr104;
sd-uhs-sdr50;
sd-uhs-sdr25;
sd-uhs-sdr12;
mmc-ddr-1_8v;
mmc-hs200-1_8v;
cd-inverted;
nvidia,min-tap-delay = <96>;
nvidia,max-tap-delay = <139>;
nvidia,vqmmc-always-on;
pwrdet-support;
pinctrl-names = "sdmmc_e_33v_enable", "sdmmc_e_33v_disable";
pinctrl-0 = <&sdmmc3_e_33V_enable>;
pinctrl-1 = <&sdmmc3_e_33V_disable>;
ignore-pm-notify;
resets = <&bpmp_resets TEGRA194_RESET_SDMMC3>;
reset-names = "sdhci";
pll_source = "pll_p", "pll_c4_muxed";
nvidia,set-parent-clk;
nvidia,parent_clk_list = "pll_p", "pll_p", "pll_p", "pll_p", "pll_p", "pll_c4_muxed", "pll_c4_muxed", "pll_c4_muxed", "pll_c4_muxed", "pll_c4_muxed", "NULL";
clocks = <&bpmp_clks TEGRA194_CLK_SDMMC3>,
<&bpmp_clks TEGRA194_CLK_PLLP_OUT0>,
<&bpmp_clks TEGRA194_CLK_PLLC4_MUXED>,
<&bpmp_clks TEGRA194_CLK_SDMMC_LEGACY_TM>;
clock-names = "sdmmc", "pll_p", "pll_c4_muxed", "sdmmc_legacy_tm";
uhs-mask = <0x08>;
nvidia,en-periodic-calib;
status = "okay";
brcmf: wifi@0 {
reg = <0>;
compatible = "brcm,bcm4329-fmac";
sdhci registered properly,
[ 5.285300] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
but WiFi module probe itself not happening. did i miss anything in the dts?
Thanks,
Arun
