I need to use one kind of sdio-wifi module named ap6398s on Xavier platform, but i want to know if sdio can support wifi on Xavier?
And I find sdio dst below :
source/kernel_src/hardware/nvidia/soc/t18x/kernel-dts/tegra186-soc/tegra186-soc-sdhci.dtsi
sdmmc1: sdhci@3400000 {
compatible = "nvidia,tegra186-sdhci";
reg = <0x0 0x3400000 0x0 0x210>;
interrupts = < 0 62 0x04>;
max-clk-limit = <204000000>;
ddr-clk-limit = <48000000>;
tap-delay = <11>;
trim-delay = <5>;
nvidia,ddr-tap-delay = <11>;
ddr-trim-delay = <5>;
mmc-ocr-mask = <3>;
bus-width = <4>;
ignore-pm-notify;
keep-power-in-suspend;
non-removable;
cap-mmc-highspeed;
cap-sd-highspeed;
pwrdet-support;
pinctrl-names = "sdmmc_e_33v_enable", "sdmmc_e_33v_disable";
pinctrl-0 = <&sdmmc1_e_33V_enable>;
pinctrl-1 = <&sdmmc1_e_33V_disable>;
compad-vref-3v3 = <0x1>;
compad-vref-1v8 = <0x2>;
nvidia,min-tap-delay = <84>;
nvidia,max-tap-delay = <136>;
pll_source = "pll_p";
resets = <&tegra_car TEGRA186_RESET_SDMMC1>;
reset-names = "sdhci";
clocks = <&tegra_car TEGRA186_CLK_SDMMC1>,
<&tegra_car TEGRA186_CLK_PLLP_OUT0>,
<&tegra_car TEGRA186_CLK_SDMMC_LEGACY_TM>;
clock-names = "sdmmc", "pll_p", "sdmmc_legacy_tm";
iommus = <&smmu TEGRA_SID_SDMMC1A>;
nvidia,en-periodic-calib;
status = "disabled";
So status = “disabled”, I want to know where status was opened “okay”?
We don’t verify wifi sdio on Xavier but only on TX2. Theoretically, it should work. You could enable the status in dts first.
Also, the reference document:
kernel/kernel-4.9/Documentation/devicetree/bindings/mmc/sdhci-tegra.txt
btw, xavier is t194 platform but not t186.
sdhci@3400000 {
mmc-ocr-mask = <0x0>;
cd-gpios = <&tegra_main_gpio TEGRA194_MAIN_GPIO(G, 7) 0>;
non-removable;
max-frequency = <50000000>;
nvidia,cd-wakeup-capable;
nvidia,vmmc-always-on;
only-1-8-v;
status = "okay";
Below is the list from my TX2 which has TX2 enabled.
nvidia@nvidia-desktop:/proc/device-tree/sdhci@3440000$ ll
-r–r–r-- 1 root root 4 Jul 7 23:32 bus-width
-r–r–r-- 1 root root 0 Jul 7 23:32 cap-mmc-highspeed
-r–r–r-- 1 root root 0 Jul 7 23:32 cap-sd-highspeed
-r–r–r-- 1 root root 28 Jul 7 23:32 clock-names
-r–r–r-- 1 root root 24 Jul 7 23:32 clocks
-r–r–r-- 1 root root 4 Jul 7 23:32 compad-vref-1v8
-r–r–r-- 1 root root 4 Jul 7 23:32 compad-vref-3v3
-r–r–r-- 1 root root 22 Jul 7 23:32 compatible
-r–r–r-- 1 root root 4 Jul 7 23:32 ddr-clk-limit
-r–r–r-- 1 root root 4 Jul 7 23:32 ddr-trim-delay
-r–r–r-- 1 root root 0 Jul 7 23:32 force-non-removable-rescan
-r–r–r-- 1 root root 0 Jul 7 23:32 ignore-pm-notify
-r–r–r-- 1 root root 12 Jul 7 23:32 interrupts
-r–r–r-- 1 root root 0 Jul 7 23:32 keep-power-in-suspend
-r–r–r-- 1 root root 4 Jul 7 23:32 linux,phandle
-r–r–r-- 1 root root 4 Jul 7 23:32 max-clk-limit
-r–r–r-- 1 root root 4 Jul 7 23:32 mmc-ocr-mask
-r–r–r-- 1 root root 6 Jul 7 23:32 name
-r–r–r-- 1 root root 0 Jul 7 23:32 non-removable
-r–r–r-- 1 root root 4 Jul 7 23:32 nvidia,ddr-tap-delay
-r–r–r-- 1 root root 0 Jul 7 23:32 nvidia,en-periodic-calib
-r–r–r-- 1 root root 4 Jul 7 23:32 nvidia,max-tap-delay
-r–r–r-- 1 root root 4 Jul 7 23:32 nvidia,min-tap-delay
-r–r–r-- 1 root root 0 Jul 7 23:32 only-1-8-v
-r–r–r-- 1 root root 4 Jul 7 23:32 phandle
-r–r–r-- 1 root root 4 Jul 7 23:32 pinctrl-0
-r–r–r-- 1 root root 4 Jul 7 23:32 pinctrl-1
-r–r–r-- 1 root root 39 Jul 7 23:32 pinctrl-names
-r–r–r-- 1 root root 6 Jul 7 23:32 pll_source
drwxr-xr-x 11 root root 0 Jul 7 23:32 prod-settings/
-r–r–r-- 1 root root 0 Jul 7 23:32 pwrdet-support
-r–r–r-- 1 root root 16 Jul 7 23:32 reg
-r–r–r-- 1 root root 6 Jul 7 23:32 reset-names
-r–r–r-- 1 root root 8 Jul 7 23:32 resets
-r–r–r-- 1 root root 5 Jul 7 23:32 status
-r–r–r-- 1 root root 4 Jul 7 23:32 tap-delay
-r–r–r-- 1 root root 4 Jul 7 23:32 trim-delay
-r–r–r-- 1 root root 4 Jul 7 23:32 uhs-mask
-r–r–r-- 1 root root 4 Jul 7 23:32 vmmc-supply
-r–r–r-- 1 root root 4 Jul 7 23:32 vqmmc-supply
CMD Voltage is in abnormal status , you can see it in red circle.
I only debug from the software.
Please share your dmesg and device tree under sdhci@34000000 as text file.
It is hard to read by image.
Dst show below, whether or not is there one way to increase the ability to driver the cmd-pin?
compatible = “nvidia,tegra194-sdhci”;
reg = <0x0 0x3400000 0x0 0x00020000>;
interrupts = < 0 TEGRA194_IRQ_SDMMC1 0x04>;
dma-coherent;
max-clk-limit = <208000000>;
bus-width = <4>;
cap-mmc-highspeed;
cap-sd-highspeed;
sd-uhs-sdr104;
sd-uhs-sdr50;
sd-uhs-sdr25;
sd-uhs-sdr12;
mmc-ddr-1_8v;
mmc-hs200-1_8v;
nvidia,vqmmc-always-on;
cd-inverted;
nvidia,min-tap-delay = <96>;
nvidia,max-tap-delay = <139>;
pwrdet-support;
pinctrl-names = “sdmmc_e_33v_enable”, “sdmmc_e_33v_disable”;
ignore-pm-notify;
resets = <&bpmp_resets TEGRA194_RESET_SDMMC1>;
reset-names = “sdhci”;
pll_source = “pll_p”, “pll_c4_muxed”;
nvidia,set-parent-clk;
nvidia,parent_clk_list = “pll_p”, “pll_p”, “pll_p”, “pll_p”, “pll_p”, “pll_c4_muxed”, “pll_c4_muxed”, “pll_c4_muxed”, “pll_c4_muxed”, “pll_c4_muxed”, “NULL”;
clocks = <&bpmp_clks TEGRA194_CLK_SDMMC1>,
<&bpmp_clks TEGRA194_CLK_PLLP_OUT0>,
<&bpmp_clks TEGRA194_CLK_PLLC4_MUXED>,
<&bpmp_clks TEGRA194_CLK_SDMMC_LEGACY_TM>;
clock-names = “sdmmc”, “pll_p”, “pll_c4_muxed”, “sdmmc_legacy_tm”;
uhs-mask = <0x08>;
status = “disabled”;
sdhci@3400000 {
non-removable;
compad-vref-3v3 = <0x7>;
compad-vref-1v8 = <0x7>;
only-1-8-v;
status = “okay”;
Please also share the kernel log (dmesg) too.
The kernel log must wait for some time,I just power down the board to change some resistances.
Whether or not is there one way from the software to increase the ability(the driving cureent) to driver the cmd-pin?
You also have difference between your dts and the dts from TX2. Please also check those.
I dont know TX2, can you show me the sdio-dst on TX2 platform?
I just pasted that above… if you need any detail for specific property, please let me know.
I mean the dst such as this shown below ,that you pasted has no value.
dma-coherent;
bus-width = <4>;
cap-mmc-highspeed;
cap-sd-highspeed;
sd-uhs-sdr104;
sd-uhs-sdr50;
sd-uhs-sdr25;
sd-uhs-sdr12;
mmc-ddr-1_8v;
mmc-hs200-1_8v;
cd-inverted;
pwrdet-support;
ignore-pm-notify;
uhs-mask = <0x08>;
I think you could just compare the property name and tell us what you are lacking of.
I don’t want you to get confused by the whole tx2 dts because the clk and pin info are all different.
I lack these below ,
force-non-removable-rescan;
vqmmc-supply
tap-delay
trim-delay
ddr-clk-limit
ddr-trim-delay
please add force-non-removable-rescan and keep-power-in-suspend directly.
and share us the dmesg and final dts file as attachment.
FInal dts file:
compatible = "nvidia,tegra194-sdhci";
dma-coherent;
bus-width = <4>;
cap-mmc-highspeed;
cap-sd-highspeed;
sd-uhs-sdr104;
sd-uhs-sdr50;
sd-uhs-sdr25;
sd-uhs-sdr12;
mmc-ddr-1_8v;
mmc-hs200-1_8v;
cd-inverted;
pwrdet-support;
ignore-pm-notify;
pll_source = "pll_p", "pll_c4_muxed";
nvidia,parent_clk_list = "pll_p", "pll_p", "pll_p", "pll_p", "pll_p", "pll_c4_muxed", "pll_c4_muxed", "pll_c4_muxed", "pll_c4_muxed", "pll_c4_muxed", "NULL";
clock-names = "sdmmc", "pll_p", "pll_c4_muxed", "sdmmc_legacy_tm";
uhs-mask = <0x08>;
sdhci@3400000 {
only-1-8-v;
status = "okay";
And appendix is the dmesg log .log.txt (93.8 KB)
SDIO still can not scan the wifi module(ap6398s).Please help me analys the log on #19.
