in l4t sdk 32.4.2 broke transcoder interlaced h264 source. After transcode picture twitching.
Reproduce:
gst-launch-1.0 filesrc location=mag0.mp4 ! qtdemux name=demux demux.video_0 ! queue ! h264parse ! nvv4l2decoder ! nvvidconv ! 'video/x-raw(memory:NVMM), format=(string)I420' ! nvv4l2h264enc bitrate=5000000 ! h264parse ! queue ! matroskamux name=mux ! filesink location=mag.mkv -e
Downgrade to # R32 (release), REVISION: 2.3, GCID: 17644089, BOARD: t186ref, EABI: aarch64, DATE: Tue Nov 5 21:48:17 UTC 2019 solve problem.
r32.4.3 is production release. Please try this version. If the issue is still present, please share the video file so that we can reproduce the issue.
last r32.4.3 also broken. Looks like bug from nvbuffer api, because my v4l2 code produce also twitching picture. For you fast investigate, gstreamer without nvvidconv create picture without twiching and source must be interlaced.
Please share the video clip so that we can reproduce the issue.
We can reproduce the issue with the video file. Will investigate further and update.
r32.4.4 release don’t fix this issue
DaneLLL
November 5, 2020, 9:05am
10
We don’t observe the issue in running the pipeline:
$ gst-launch-1.0 filesrc location=mag0.mp4 ! qtdemux name=demux demux.video_0 ! queue ! h264parse ! nvv4l2decoder ! nvv4l2h264enc bitrate=5000000 ! h264parse ! queue ! matroskamux name=mux ! filesink location=mag-1.mkv
Please give it a try.
remove nvvidconv don’t solve my problem. Video broken when resize use
gst-launch-1.0 filesrc location=mag0.mp4 ! qtdemux name=demux demux.video_0 ! queue ! h264parse ! nvv4l2decoder ! nvvidconv ! 'video/x-raw(memory:NVMM), width=(int)320, height=(int)200, format=(string)I420' ! nvv4l2h264enc bitrate=5000000 ! h264parse ! queue ! matroskamux name=mux ! filesink location=mag-1.mkv -e
I’m watch something like when use samples.
./video_decode H264 --disable-rendering --input-nalu -f 2 -v4l2-memory-cap-plane 1 -o /mnt/nfs/ts/mag0.yuv /mnt/nfs/ts/mag0.h264
Looks like NvBufferTransform produce broken image nv12 → yuv420p.
jetson tx2 4gb
# cat /etc/nv_tegra_release
# R32 (release), REVISION: 5.1, GCID: 27362550, BOARD: t186ref, EABI: aarch64, DATE: Wed May 19 18:16:00 UTC 2021
# dpkg -l | grep l4t
ii nvidia-l4t-3d-core 32.5.1-20210519111140 arm64 NVIDIA GL EGL Package
ii nvidia-l4t-apt-source 32.5.1-20210219084708 arm64 NVIDIA L4T apt source list debian package
ii nvidia-l4t-bootloader 32.5.1-20210614115015 arm64 NVIDIA Bootloader Package
ii nvidia-l4t-camera 32.5.1-20210519111140 arm64 NVIDIA Camera Package
ii nvidia-l4t-configs 32.5.1-20210219084708 arm64 NVIDIA configs debian package
ii nvidia-l4t-core 32.5.1-20210519111140 arm64 NVIDIA Core Package
ii nvidia-l4t-cuda 32.5.1-20210519111140 arm64 NVIDIA CUDA Package
ii nvidia-l4t-firmware 32.5.1-20210519111140 arm64 NVIDIA Firmware Package
ii nvidia-l4t-graphics-demos 32.5.1-20210519111140 arm64 NVIDIA graphics demo applications
ii nvidia-l4t-gstreamer 32.5.1-20210519111140 arm64 NVIDIA GST Application files
ii nvidia-l4t-init 32.5.1-20210519111140 arm64 NVIDIA Init debian package
ii nvidia-l4t-initrd 32.5.1-20210614115015 arm64 NVIDIA initrd debian package
ii nvidia-l4t-jetson-io 32.5.1-20210219084708 arm64 NVIDIA Jetson.IO debian package
rc nvidia-l4t-jetson-multimedia-api 32.5.1-20210519111140 arm64 NVIDIA Jetson Multimedia API is a collection of lower-level APIs that support flexible application development.
ii nvidia-l4t-kernel 4.9.201-tegra-32.5.1-20210505093723 arm64 NVIDIA Kernel Package
ii nvidia-l4t-kernel-dtbs 4.9.201-tegra-32.5.1-20210505093723 arm64 NVIDIA Kernel DTB Package
ii nvidia-l4t-kernel-headers 4.9.201-tegra-32.5.1-20210505093723 arm64 NVIDIA Linux Tegra Kernel Headers Package
ii nvidia-l4t-libvulkan 32.5.1-20210519111140 arm64 NVIDIA Vulkan Loader Package
ii nvidia-l4t-multimedia 32.5.1-20210519111140 arm64 NVIDIA Multimedia Package
ii nvidia-l4t-multimedia-utils 32.5.1-20210519111140 arm64 NVIDIA Multimedia Package
ii nvidia-l4t-oem-config 32.5.1-20210219084708 arm64 NVIDIA OEM-Config Package
ii nvidia-l4t-tools 32.5.1-20210614115015 arm64 NVIDIA Public Test Tools Package
ii nvidia-l4t-wayland 32.5.1-20210519111140 arm64 NVIDIA Wayland Package
ii nvidia-l4t-weston 32.5.1-20210519111140 arm64 NVIDIA Weston Package
ii nvidia-l4t-x11 32.5.1-20210519111140 arm64 NVIDIA X11 Package
ii nvidia-l4t-xusb-firmware 32.5.1-20210614115015 arm64 NVIDIA USB Firmware Package
Also, NvBufferTransform not guilty. Corrupts video dumps directly from dma_buf capture plane decoder. I’ve tested several codecs. With interlaced source decoder produce corrupt video, and progressive source works well.
Would like to know what your use-case is. For transcoding, you can simply link
... ! nvv4l2decoder ! nvv4l2h264enc ! ...
We have checked with teams and provided this suggestion. It is not required to convert NV12 to I420. Not sure why you have to do it in your use-case. Keeping NV12 should be a valid solution for general use-cases.
without nvvidconv transcoder works fine, but i need resized video. Also in another project, i send decoded dma_buf from nvv4ldecoder to cuda and receive in cuda code artefacts from interlaced source too. Progressive source works ok.
Thanks for your support.
Please try the command by setting num-extra-surfaces and adding queue :
$ gst-launch-1.0 filesrc location=mag0.mp4 ! qtdemux name=demux demux.video_0 ! queue ! h264parse ! nvv4l2decoder num-extra-surfaces=4 ! queue ! nvvidconv ! 'video/x-raw(memory:NVMM), width=320,height=240' ! nvoverlaysink
Artifacts remain, but they appear much less frequently.
source: ao0.mp4 - Google Drive
result: a3.mkv - Google Drive
artefacts at 00:01:01, 00:02:00, 00:02:41 etc
gst-launch-1.0 filesrc location=ao0.mp4 ! qtdemux name=demux demux.video_0 ! queue ! h264parse ! nvv4l2decoder num-extra-surfaces=4 ! queue ! nvvidconv ! 'video/x-raw(memory:NVMM), format=(string)I420' ! nvv4l2h264enc bitrate=7000000 ! h264parse ! queue ! matroskamux name=mux ! filesink location=a3.mkv -e
Does it happen if you do rescaling like:
Or it only happens in converting to I420:
Converting NV12 to I420 looks not required. It is better to send NV12 buffers to hardware encoder.
Please also try to adjust num-extra-surfaces and min-threshold-buffers like:
... ! nvv4l2decoder num-extra-surfaces=8 ! queue min-threshold-buffers=8 ! ...
