Just want to report that Nvidia driver 515.76 does not work with kernel 6.0. When I boot Ubuntu with 6.0 kernel, Nvidia driver just doesn’t work. Latest kernel I can use is 5.19.12
+1
It works fine here.
I assume you are on Ubuntu Jammy. The steps that are working for me are:
- Install gcc-12
- Remove and symlink /etc/alternatives/cc to /usr/bin/gcc-12 (nvidia dkms is using cc)
- Change the following lines in /usr/src/nvidia-515.65.01/nvidia-drm/nvidia-drm-helper.c
--- nvidia-drm-helper.c.org 2022-10-06 09:11:59.857005122 +0200
+++ nvidia-drm-helper.c 2022-10-06 09:12:02.837791655 +0200
@@ -41,6 +41,10 @@
#include <drm/drm_atomic_uapi.h>
#endif
+#if defined(NV_DRM_FRAMEBUFFER_GET_PRESENT)
+#include <drm/drm_framebuffer.h>
+#endif
static void __nv_drm_framebuffer_put(struct drm_framebuffer *fb)
- Reinstall the kernel headers to run dkms again (apt purge linux-headers-xxx-generic, dpkg -i linux-headers-xxx-generic.deb).
There was an error in the log about trivial-auto-var-init which gave me a hint.
