Okay , no useable NVIDIA Driver for Kernel Linux 6.15 exist
my OS: openSUSE Tumbleweed 64 Bit Driver 575.51-02 works with Kernel 6.14.8 not with 6.15,
I Think you have no useable Solution , so i where Change my Graphic Hardware from NVIDIA to AMD
570.153.02 works ok with 6.15 kernel if you use the open source nvidia module.
strange but true, I’ve just installed 570.153.02 on kernel 6.15.1 and it works, for some reason 575 doesn’t
You mentioned using 575.51.02, but the fixes for kernel 6.15 are in 575.57.08.
Still need to use the open source variant without a patch though, no driver has an official fix for the closed source variant and GPL conflicts yet as far as I know.
575.57.08 doesn’t work with 6.15.1 ml either. Kernel fails to build and then system unable to boot (kernel panic).
CentOS 9 Stream.
Hello
575.57.08 with Patch works fine on Kernel 6.15.0
regards
Franz
No problem for me using 575.57.08 with 6.15.1 on NixOS.
