No kernel drivers for 6.7.x kernel
Hey,
I noticed that the openSUSE builds for Tumbleweed (Index of /opensuse/tumbleweed) are still offering modules for the 6.6.x kernel (like vidia-gfxG05-kmp-default-470.223.02_k6.6.2_1-59.12.x86_64) but nothing for 6.7.x kernel
Does anyone have information when this will be fixed? Cant use the HDMI to connect an external screen at the moment!
This is a question you have to ask to openSUSE devs.
Sadly, if they aren’t building the driver you need to do it your self with nvidia-installer or with an alternate tool.
I dont think that its the openSUSE developers, as nvidia is running the respository (downoad.nvidia.com). So they can trigger a rebuild…
I suspect this is due to the changes in the 6.7.3 kernel which require a new driver release.
https://forums.developer.nvidia.com/t/linux-6-7-3-545-29-06-550-40-07-error-modpost-gpl-incompatible-module-nvidia-ko-uses-gpl-only-symbol-rcu-read-lock/280908/77
Yes, this a possibility too.
Fedora fixed the issue in 3 days by sending the 6.7.4 for update. This the second time that issue arrive with same errors log (I don’t remind which kernel version). But the target kernel version here is 6.6.x. which I didn’t personally notice compilation problems.
@docb, pointing to nvidia driver repos in openSUSE package doesn’t mean Nvidia is maintainer of the corresponding rpm package and there’s no rpm package in this repos.
If you wish to have updated drivers, you need to install them by you self or wait openSUSE build a proper rpm package. Very sorry about that.
