Problems with 575.51.02 or 570.153.02 Driver can’t install on Linux Kernel 6.15
OS: openSUSE Tumbleweed
nvidia-installer.log (8.5 MB)
exist a useable Solution ?
Regards
Same OS, perfectly working out of RPM (570.153.02)
570.153.02 should work fine, 575 is not supported without patches.
570.153.02 works with the open source driver.
570.153.02 closed source driver needs patching as it uses gpl-only symbols which prevents it from loading.
The just released 575.57.08 should do the trick for you when using the MIT/GPL modules (=default option).
No does not work
how you manage to fail it working?
You haven’t considered the possibility that Suse reverted the kernel commit that made the symbols gpl-only.
It’s definitely a real issue , loading the module fails due to gpl symbols on kernel-6.15.
I am using the cachyos patch to workarround the issue for the rpmfusion driver.
Also your screenshot doesn’t prove your point, it show that nvidia is working but doesn’t show which module is used!
modinfo nvidia |grep license:
How much more proof needed?
official NVidia repo install source from RPM, closed driver. All works out the box. Didn’t touch anything at all. Just updated kernel and it works. Got to know there are any issues only here in topic.
I have legacy GPU without GSP, so it doesn’t support open driver at all, only proprietary.
As an option try this repo for kernel: https://cdn.opensuse.org/repositories/Kernel:/stable/standard/ . I use this one, OpenSUSE is slow rolling out kernels and often end up with bugs, so I ignore shipped with distro kernels. And it worked as a charm, didn’t know issue exists at all. And not willing to try distro default one.
And just checked, official OpenSUSE Tumbleweed repo doesn’t ship 6.15 at all yet. So my question remains the same: how did you manage to fail? Where is kernel from and how it manages to fail?
It’s possible to patch the .run file
wget https://raw.githubusercontent.com/leigh123linux/nvidia_patch/refs/heads/main/Workaround-nv_vm_flags_-calling-GPL-only-code.patch
sh NVIDIA-Linux-x86_64-575.57.08.run --apply-patch Workaround-nv_vm_flags_-calling-GPL-only-code.patch
Then install the custom .run file
sh NVIDIA-Linux-x86_64-575.57.08-custom.run
I use the fedora kernel from
$ dnf list kernel
Updating and loading repositories:
Fedora 42 - x86_64 - Updates 100% | 87.8 KiB/s | 9.0 KiB | 00m00s
Fedora 42 - x86_64 - Updates 100% | 3.1 MiB/s | 1.8 MiB | 00m01s
Repositories loaded.
Installed packages
kernel.x86_64 6.14.6-300.fc42 updates
kernel.x86_64 6.15.0-0.rc6.49.fc43 fedora-rawhide-nodebug
kernel.x86_64 6.15.0-61.fc43 fedora-rawhide-nodebug
Hmm… then they probably broke kernel build somehow. Likely for me no any sorts of patches needed and all works out the box. It’s anyway stupid how kernel insists on gpl nonsense at times. but in given case seems kernel vendor’s fault
Why do you think it’s everyone’s kernel that is broken and not your kernel (my guess is your ego is bigger than your brain :-) )?
multiple distros are reporting the same issue.
Have you considered your kernel is just some early git snapshot from before the kernel changes that broke nvidia.
that patch just worked for me, thank you.
