I am having troubles installing the nvidia driver,
I downloaded the driver corresponding to my card & I keep on getting this error
ERROR: An error occurred while performing the step: "Building kernel modules".
System Info:
Kernel Version: 6.11.2-amd64
gcc (Debian 14.2.0-6) 14.2.0
Driver Version 470.256.02
nvidia-bug-report.log.gz (153.4 KB)
└─$ lspci -s 3:00.0 -v
03:00.0 VGA compatible controller: NVIDIA Corporation GK106GL [Quadro K4000] (rev a1) (prog-if 00 [VGA controller])
Subsystem: NVIDIA Corporation Device 097c
Physical Slot: 2
Flags: bus master, fast devsel, latency 0, IRQ 11, NUMA node 0, IOMMU group 50
Memory at f2000000 (32-bit, non-prefetchable) [size=16M]
Memory at e0000000 (64-bit, prefetchable) [size=256M]
Memory at f0000000 (64-bit, prefetchable) [size=32M]
I/O ports at 8000 [size=128]
Expansion ROM at 000c0000 [disabled] [size=128K]
Capabilities: <access denied>
Kernel modules: nouveau
I also created this file to remove the nouveau kernel, which was not removed somehow
cat /etc/modprobe.d/blacklist-nouveau.conf
blacklist nouveau
options nouveau modset =0
Then I updated initramfs successfully & rebooted
$ sudo update-initramfs -u
Whenever I run the lspci -s 3:00.0 -v command, I still get the same result with the novoue kernel
maybe that is the conflict ?
