Nvidia driver fail on build kernel module form source << Centos 7.5 >>
I made an update to centos 7.5 with last kernel aviable but kernel module no load. then re install Nvidia*.run package, and fail kernel module build process.
installer >> NVIDIA-Linux-x86_64-367.124.run
uname -a
Linux ngrid 3.10.0-862.2.3.el7.x86_64 #1 SMP Wed May 9 18:05:47 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
#rpm -qa | grep kernel
kernel-3.10.0-862.2.3.el7.x86_64
kernel-headers-3.10.0-862.2.3.el7.x86_64
kernel-devel-3.10.0-862.2.3.el7.x86_64
kernel-tools-libs-3.10.0-862.2.3.el7.x86_64
kernel-tools-3.10.0-862.2.3.el7.x86_64
abrt-addon-kerneloops-2.1.11-50.el7.centos.x86_64
lspci | grep ‘NVIDIA’
0c:00.0 VGA compatible controller: NVIDIA Corporation GK104GL [GRID K2] (rev a1)
0d:00.0 VGA compatible controller: NVIDIA Corporation GK104GL [GRID K2] (rev a1)
ERROR: Failed to run /usr/sbin/dkms build -m nvidia -v 367.124 -k 3.10.0-862.2.3.el7.x86_64:
Kernel preparation unnecessary for this kernel. Skipping…
     Building module:
     cleaning build area...
     'make' -j6 NV_EXCLUDE_BUILD_MODULES='' KERNEL_UNAME=3.10.0-862.2.3.el7.x86_64 modules......(bad exit status: 2)
     Error! Bad return status for module build on kernel: 3.10.0-862.2.3.el7.x86_64 (x86_64)
     Consult /var/lib/dkms/nvidia/367.124/build/make.log for more information.
<</var/lib/dkms/nvidia/367.124/build/make.log >>
<<nvidia-installer.log>>
I am also experiencing a failed build with a similar setup.
uname -a
Linux 10.92.80.171 3.10.0-862.3.2.el7.x86_64 #1 SMP Mon May 21 23:36:36 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
kernel-3.10.0-862.3.2.el7.x86_64
kernel-devel-3.10.0-862.3.2.el7.x86_64
kernel-3.10.0-862.el7.x86_64
kernel-debug-devel-3.10.0-862.3.2.el7.x86_64
kernel-tools-libs-3.10.0-862.3.2.el7.x86_64
kernel-headers-3.10.0-862.3.2.el7.x86_64
kernel-tools-3.10.0-862.3.2.el7.x86_64
lspci | grep NVIDIA
0e:00.0 VGA compatible controller: NVIDIA Corporation GK104GL [GRID K2] (rev a1)
ERROR: Failed to run /sbin/dkms build -m nvidia -v 367.124 -k 3.10.0-862.3.2.el7.x86_64:
     Building module:
     'make' -j32 NV_EXCLUDE_BUILD_MODULES='' KERNEL_UNAME=3.10.0-862.3.2.el7.x86_64 modules....(bad exit status: 2)
     Error! Bad return status for module build on kernel: 3.10.0-862.3.2.el7.x86_64 (x86_64)
make.log
https://pastebin.com/tfC2m6PP
https://pastebin.com/35nvS4ju
