Failed Building Kernel Driver
uname -a
Linux trabajar2 5.15.0-2-amd64 #1 SMP Debian 5.15.5-1 (2021-11-26) x86_64 GNU/Linux
File I am suing : ./NVIDIA-Linux-x86_64-390.144.run
lspci
00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09)
00:02.0 VGA compatible controller: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09)
00:16.0 Communication controller: Intel Corporation 6 Series/C200 Series Chipset Family MEI Controller #1 (rev 04)
00:19.0 Ethernet controller: Intel Corporation 82579LM Gigabit Network Connection (Lewisville) (rev 04)
00:1a.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 (rev 04)
00:1b.0 Audio device: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 (rev b4)
00:1c.1 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 2 (rev b4)
00:1c.3 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 4 (rev b4)
00:1c.4 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 5 (rev b4)
00:1c.6 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 7 (rev b4)
00:1d.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation QM67 Express Chipset LPC Controller (rev 04)
00:1f.2 IDE interface: Intel Corporation 6 Series/C200 Series Chipset Family Mobile SATA Controller (IDE mode, ports 0-3) (rev 04)
00:1f.3 SMBus: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller (rev 04)
00:1f.5 IDE interface: Intel Corporation 6 Series/C200 Series Chipset Family Mobile SATA Controller (IDE mode, ports 4-5) (rev 04)
01:00.0 VGA compatible controller: NVIDIA Corporation GF108GLM [Quadro 1000M] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GF108 High Definition Audio Controller (rev a1)
03:00.0 Network controller: Qualcomm Atheros AR9485 Wireless Network Adapter (rev 01)
0d:00.0 System peripheral: Ricoh Co Ltd MMC/SD Host Controller (rev 08)
0d:00.3 FireWire (IEEE 1394): Ricoh Co Ltd R5C832 PCIe IEEE 1394 Controller (rev 04)
0e:00.0 USB controller: NEC Corporation uPD720200 USB 3.0 Host Controller (rev 04)
cat /var/log/nvidia-installer.log
| __state
make[3]: *** [/usr/src/linux-headers-5.15.0-2-common/scripts/Makefile.build:282: /tmp/selfgz1803/NVIDIA-Linux-x86_64-390.144/kernel/nvidia/os-interface.o] Error 1
make[3]: *** [/usr/src/linux-headers-5.15.0-2-common/scripts/Makefile.build:282: /tmp/selfgz1803/NVIDIA-Linux-x86_64-390.144/kernel/nvidia/nvlink_linux.o] Error 1
make[3]: Target ‘__build’ not remade because of errors.
make[2]: *** [/usr/src/linux-headers-5.15.0-2-common/Makefile:1892: /tmp/selfgz1803/NVIDIA-Linux-x86_64-390.144/kernel] Error 2
make[2]: Target ‘modules’ not remade because of errors.
make[2]: Leaving directory ‘/usr/src/linux-headers-5.15.0-2-amd64’
make[1]: *** [Makefile:231: __sub-make] Error 2
make[1]: Target ‘modules’ not remade because of errors.
make[1]: Leaving directory ‘/usr/src/linux-headers-5.15.0-2-common’
make: *** [Makefile:81: modules] Error 2
→ Error.
ERROR: An error occurred while performing the step: “Checking to see whether the nvidia kernel module was successfully built”. See /var/log/nvidia-installer.log for details.
→ The command cd ./kernel; /usr/bin/make -k -j8 NV_KERNEL_MODULES="nvidia" NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/5.15.0-2-amd64/source" SYSOUT="/lib/modules/5.15.0-2-amd64/build" failed with the following output:
make[1]: Entering directory ‘/usr/src/linux-headers-5.15.0-2-common’
make[2]: Entering directory ‘/usr/src/linux-headers-5.15.0-2-amd64’
warning: the compiler differs from the one used to build the kernel
The kernel was built by: gcc-11 (Debian 11.2.0-12) 11.2.0
You are using: cc (Debian 11.2.0-12) 11.2.0
CC [M] /tmp/selfgz1803/NVIDIA-Linux-x86_64-390.144/kernel/nvidia/os-interface.o
CC [M] /tmp/selfgz1803/NVIDIA-Linux-x86_64-390.144/kernel/nvidia/nvlink_linux.o
In file included from /usr/src/linux-headers-5.15.0-2-common/include/linux/kernel.h:5,
from /usr/src/linux-headers-5.15.0-2-common/include/linux/list.h:9,
from /usr/src/linux-headers-5.15.0-2-common/include/linux/preempt.h:11,
from /usr/src/linux-headers-5.15.0-2-common/include/linux/spinlock.h:55,
from /tmp/selfgz1803/NVIDIA-Linux-x86_64-390.144/kernel/common/inc/nv-lock.h:16,
from /tmp/selfgz1803/NVIDIA-Linux-x86_64-390.144/kernel/common/inc/nv-linux.h:19,
from /tmp/selfgz1803/NVIDIA-Linux-x86_64-390.144/kernel/nvidia/os-interface.c:15:
/usr/src/linux-headers-5.15.0-2-common/include/linux/stdarg.h:6: warning: “va_start” redefined
6 | define va_start(v, l) __builtin_va_start(v, l)
In file included from /tmp/selfgz1803/NVIDIA-Linux-x86_64-390.144/kernel/common/inc/os-interface.h:27,
from /tmp/selfgz1803/NVIDIA-Linux-x86_64-390.144/kernel/nvidia/os-interface.c:14:
/usr/lib/gcc/x86_64-linux-gnu/11/include/stdarg.h:47: note: this is the location of the previous definition
47 | define va_start(v,l) __builtin_va_start(v,l)
/usr/src/linux-headers-5.15.0-2-common/include/linux/stdarg.h:8: warning: “va_arg” redefined
8 | define va_arg(v, T) __builtin_va_arg(v, T)
/usr/lib/gcc/x86_64-linux-gnu/11/include/stdarg.h:49: note: this is the location of the previous definition
49 | define va_arg(v,l) __builtin_va_arg(v,l)
/usr/src/linux-headers-5.15.0-2-common/include/linux/stdarg.h:9: warning: “va_copy” redefined
9 | define va_copy(d, s) __builtin_va_copy(d, s)
/usr/lib/gcc/x86_64-linux-gnu/11/include/stdarg.h:52: note: this is the location of the previous definition
52 | define va_copy(d,s) __builtin_va_copy(d,s)
/tmp/selfgz1803/NVIDIA-Linux-x86_64-390.144/kernel/nvidia/os-interface.c: In function ‘os_delay’:
/tmp/selfgz1803/NVIDIA-Linux-x86_64-390.144/kernel/nvidia/os-interface.c:583:18: error: ‘struct task_struct’ has no member named ‘state’; did you mean ‘__state’?
583 | current->state = TASK_INTERRUPTIBLE;
| __state
/tmp/selfgz1803/NVIDIA-Linux-x86_64-390.144/kernel/nvidia/nvlink_linux.c: In function ‘nvlink_sleep’:
/tmp/selfgz1803/NVIDIA-Linux-x86_64-390.144/kernel/nvidia/nvlink_linux.c:600:18: error: ‘struct task_struct’ has no member named ‘state’; did you mean ‘__state’?
600 | current->state = TASK_INTERRUPTIBLE;
| __state
ERROR: The nvidia kernel module was not created.
ERROR: Installation has failed. Please see the file ‘/var/log/nvidia-installer.log’ for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
] SOLVED SOLUTION [
I had to patch the Nvidia install file for my specific card. By using the following command.
./inttf-nvidia-patcher.sh -v 390.144
Go the script from here : https://www.if-not-true-then-false.com/2020/inttf-nvidia-patcher/
It works for the latest kernels is the current Nvidia driver is slow to support the current kernel.
Run the following to see how to get it to support other cards.
./inttf-nvidia-patcher.sh -h
This script downloads the driver for you and path it.
I had to install libglvnd-dev to get things to work.
apt install libglvnd-dev
You will also want to download kernel drivers like this.
apt-get install linux-headers-uname -r build-essential
