After the release of kernel 5.6, gt440 stopped working. The driver is not going to. Now is not the best time to upgrade hardware. Covid-19. Please help my. :(
I don’t know what kind of distro you’re using but you should stay away from using the .run installer. Please use a packaged driver provided by your distro or switch to a LTS kernel.
Sorry. Distro opensuse tumbleweed. Kernel 5.6.
I’m not use run file. Using nvidia opensuse repo.
You could try using the arch patches on the dkms source:
https://aur.archlinux.org/packages/nvidia-390xx-dkms/
I’m try. Driver not install. Error messages.
I suspect you have to apply all three patches one after another. Did you use --dry-run to check if the patches apply cleanly? Please describe the steps you’ve done.
I’m apply only kernel-5.6.patch.
Now I will beat all three
Ok. I’m apply all pathes. This is working. Thank You.
Patched driver (openSUSE Tumbleweed x86_64)
