NVIDIA driver compatibility with Linux kernel 6.17 (Debian Trixie)
Hi everyone,
I recently installed the NVIDIA drivers on my new Debian system and have been experimenting with different kernel versions. I noticed that kernel 6.17 seems to be newer than what the current Debian-packaged driver supports. I’m not very experienced with Linux kernel and driver release, so I wanted to ask a few things:
Have I made any mistakes in how I installed the NVIDIA drivers? I’m running Debian 13 (Trixie) with the backported 6.17 kernel, so I’m assuming this version might simply be too new for the driver/NVIDIA DKMS to build correctly.
I’m also a bit confused about versioning: Debian’s repositories provide NVIDIA driver version 550, but here on the forum I see mentions of driver versions up to 590, and the production branch seems to be around 580. Is this a Debian packaging delay, or is there something I’m misunderstanding about how these versions are distributed?
If this isn’t an installation issue, is there any general expectation for when a driver update might support kernel 6.17?
Thank you for explaining this :)
There are 3 major ways Nvidia drivers are packaged for Debian, see the details on the Debian wiki.
Debian generally packages only LTS versions, so 535, 550 and probably soon they will also add 580.
I’m on 6.17.8 from trixie-backports as well and 590 (still in beta) from the Nvidia DC repo works fine for me. Previously I was using 580 from the DC repo for Debian-12 and it was also working fine with this kernel (the DC repo for D-13 have been created just a few days ago).
How exactly have you tried to install the driver and what sort of problems are you experiencing exactly? Please consider attaching a bug report file.
Thank you for the speedy answer and sorry for a late one.
I was installing the nvidia-smi directly with apt
root@server:~# apt install nvidia-smi
Installing:
  nvidia-smi
Installing dependencies:
  firmware-nvidia-gsp      libnvidia-egl-gbm1         libxkbfile1               nvidia-persistenced
  glx-alternative-mesa     libnvidia-egl-wayland1     libxmu6                   nvidia-settings
  glx-alternative-nvidia   libnvidia-eglcore          libxpm4                   nvidia-support
  glx-diversions           libnvidia-encode1          libxt6t64                 nvidia-suspend-common
  libcuda1                 libnvidia-glcore           nvidia-alternative        nvidia-vdpau-driver
  libegl-nvidia0           libnvidia-glvkspirv        nvidia-driver             nvidia-vulkan-common
  libfontenc1              libnvidia-gpucomp          nvidia-driver-bin         nvidia-vulkan-icd
  libgl1-nvidia-glvnd-glx  libnvidia-ml1              nvidia-driver-libs        update-glx
  libgles-nvidia1          libnvidia-pkcs11-openssl3  nvidia-egl-common         x11-xkb-utils
  libgles-nvidia2          libnvidia-ptxjitcompiler1  nvidia-egl-icd            xcvt
  libgles1                 libnvidia-rtcore           nvidia-installer-cleanup  xfonts-base
  libglx-nvidia0           libopengl0                 nvidia-kernel-common      xfonts-encodings
  libice6                  libsm6                     nvidia-kernel-dkms        xfonts-utils
  libnvcuvid1              libxaw7                    nvidia-kernel-support     xserver-common
  libnvidia-allocator1     libxcvt0                   nvidia-legacy-check       xserver-xorg-core
  libnvidia-cfg1           libxfont2                  nvidia-modprobe           xserver-xorg-video-nvidia
Suggested packages:
  nvidia-cuda-mps  vulkan-tools  xfs  | xserver  xfonts-100dpi  | xfonts-75dpi  xfonts-scalable
Recommended packages:
  libcuda1:i386  nvidia-driver-libs:i386
Summary:
  Upgrading: 0, Installing: 65, Removing: 0, Not Upgrading: 0
  Download size: 0 B / 159 MB
  Space needed: 454 MB / 897 GB available
Continue? [Y/n] y
<SNIPPED>
Building initial module nvidia-current/550.163.01 for 6.17.8+deb13-amd64
Sign command: /lib/modules/6.17.8+deb13-amd64/build/scripts/sign-file
Signing key: /var/lib/dkms/mok.key
Public certificate (MOK): /var/lib/dkms/mok.pub
Building module(s).........(bad exit status: 2)
Failed command:
env NV_VERBOSE=1 make -j16 modules KERNEL_UNAME=6.17.8+deb13-amd64
Error! Bad return status for module build on kernel: 6.17.8+deb13-amd64 (x86_64)
Consult /var/lib/dkms/nvidia-current/550.163.01/build/make.log for more information.
dpkg: error processing package nvidia-kernel-dkms (--configure):
 installed nvidia-kernel-dkms package post-installation script subprocess returned error exit status 10
dpkg: dependency problems prevent configuration of nvidia-driver:
 nvidia-driver depends on nvidia-kernel-dkms (= 550.163.01-2) | nvidia-kernel-550.163.01 | nvidia-open-kernel-550.163.01; however:
  Package nvidia-kernel-dkms is not configured yet.
  Package nvidia-kernel-550.163.01 is not installed.
  Package nvidia-kernel-dkms which provides nvidia-kernel-550.163.01 is not configured yet.
  Package nvidia-open-kernel-550.163.01 is not installed.
dpkg: error processing package nvidia-driver (--configure):
 dependency problems - leaving unconfigured
Processing triggers for libc-bin (2.41-12) ...
Processing triggers for initramfs-tools (0.148.3) ...
update-initramfs: Generating /boot/initrd.img-6.17.8+deb13-amd64
Processing triggers for update-glx (1.2.2) ...
Processing triggers for glx-alternative-nvidia (1.2.2) ...
update-alternatives: using /usr/lib/nvidia to provide /usr/lib/glx (glx) in auto mode
Processing triggers for glx-alternative-mesa (1.2.2) ...
Errors were encountered while processing:
 nvidia-kernel-dkms
 nvidia-driver
Error: Sub-process /usr/bin/dpkg returned an error code (1)
root@server:~#
I am also attaching the bug report by nvidia-bug-report.sh
Thank you!
nvidia-bug-report.log.gz (108.0 KB)
Now it’s clear: kernel 6.16+ requires Nvidia driver 580+ due to changes in some header files and you attempted to install 550 from the Debian repos on 6.17 from trixie-backports, so it failed to compile as expected.
You have a few options here:
  • use the default 6.12 kernel and driver v550 from the Debian repos
  • stay at 6.17 and install v580 or v590 using the dot-run installer
  • stay at 6.17 and install v590 from the mentioned Nvidia DC apt repos (follow the instructions for Debian-12 from the official docs just replacing $(distro) with debian13)
Whichever way you decide, first make sure to clean the current mess with apt-get --autoremove purge '*nvidia*' '*nvidia*:i386' '*cuda*' '*cuda*:i386'
Hope this helps :)
UPDATE:
  • you didn’t mention what GPU you have: support for Maxwell, Pascal and Volta is discontinued since v590, so if you have an older GPU (like GTX 10xx or older), then you need to use v580 (or earlier) and choose proprietary modules flavor.
  • when installing from the Debian repos, you should follow the exact instructions from the wiki: adding components, installing headers, finally installing nvidia-driver + firmware + open/proprietary modules, NOT just installing nvidia-smi and hoping that all the rest will be somehow properly pulled-in also.
PS: I’ve added a warning to the wiki, so others will not fall into the same trap.
Followed this and made it work :)
Thanks for the help!
Glad it to hear it works :)
For anyone coming here in the (near) future: I’ve just noticed that there’s a corresponding version 550.163.01-4~bpo13+1 in trixie-backports: it is possible that it was patched to work with kernels 6.16+, but I haven’t verified it (I’ve added yet another note to the wiki though ;-] ).
UPDATE: proprietary flavor of 550.163.01-4~bpo13+1 indeed compiles correctly on the 6.17 kernel from trixie-backports. Open flavor still fails. The wiki has been updated accordingly.
UPDATE 2:
  • open flavor from backports now also works on 6.17 kernels (1123024).
  • I’ve filed a wishlist bug BTW to package some version supporting Blackwell (1123506)
the wiki has been updated with the above info and istructions.
Great news! thank you for this :)
