Impossible to install Nvidia Driver
Hi
I am running Debian Sid with kernel 6.13, I didn’t manage to install successfully Nvidia driver.
I get following error :
2055 | NV_STATUS uvm_api_clear_all_access_counters(UVM_CLEAR_ALL_ACCESS_COUNTERS_PARAMS *params, struct file *filp)
CC [M] nvidia-uvm/uvm_maxwell.o
CC [M] nvidia-uvm/uvm_maxwell_host.o
CC [M] nvidia-uvm/uvm_maxwell_ce.o
CC [M] nvidia-uvm/uvm_maxwell_sec2.o
CC [M] nvidia-uvm/uvm_maxwell_mmu.o
CC [M] nvidia-uvm/uvm_maxwell_fault_buffer.o
CC [M] nvidia-uvm/uvm_maxwell_access_counter_buffer.o
CC [M] nvidia-uvm/uvm_pascal.o
CC [M] nvidia-uvm/uvm_pascal_ce.o
CC [M] nvidia-uvm/uvm_pascal_host.o
CC [M] nvidia-uvm/uvm_pascal_mmu.o
CC [M] nvidia-uvm/uvm_pascal_fault_buffer.o
CC [M] nvidia-uvm/uvm_volta_ce.o
CC [M] nvidia-uvm/uvm_volta_host.o
CC [M] nvidia-uvm/uvm_volta_mmu.o
CC [M] nvidia-uvm/uvm_volta.o
CC [M] nvidia-uvm/uvm_volta_fault_buffer.o
CC [M] nvidia-uvm/uvm_volta_access_counter_buffer.o
CC [M] nvidia-uvm/uvm_turing.o
CC [M] nvidia-uvm/uvm_turing_access_counter_buffer.o
CC [M] nvidia-uvm/uvm_turing_fault_buffer.o
CC [M] nvidia-uvm/uvm_turing_mmu.o
CC [M] nvidia-uvm/uvm_turing_host.o
CC [M] nvidia-uvm/uvm_ampere.o
CC [M] nvidia-uvm/uvm_ampere_ce.o
CC [M] nvidia-uvm/uvm_ampere_host.o
CC [M] nvidia-uvm/uvm_ampere_fault_buffer.o
CC [M] nvidia-uvm/uvm_ampere_mmu.o
CC [M] nvidia-uvm/uvm_hopper.o
CC [M] nvidia-uvm/uvm_hopper_fault_buffer.o
CC [M] nvidia-uvm/uvm_hopper_ce.o
CC [M] nvidia-uvm/uvm_hopper_host.o
CC [M] nvidia-uvm/uvm_hopper_sec2.o
CC [M] nvidia-uvm/uvm_hopper_mmu.o
CC [M] nvidia-uvm/uvm_ada.o
CC [M] nvidia-uvm/uvm_blackwell.o
CC [M] nvidia-uvm/uvm_blackwell_fault_buffer.o
CC [M] nvidia-uvm/uvm_blackwell_mmu.o
CC [M] nvidia-uvm/uvm_blackwell_host.o
CC [M] nvidia-uvm/uvm_policy.o
CC [M] nvidia-uvm/uvm_perf_utils.o
CC [M] nvidia-uvm/uvm_kvmalloc.o
CC [M] nvidia-uvm/uvm_pmm_sysmem.o
CC [M] nvidia-uvm/uvm_pmm_gpu.o
CC [M] nvidia-uvm/uvm_migrate.o
CC [M] nvidia-uvm/uvm_populate_pageable.o
CC [M] nvidia-uvm/uvm_migrate_pageable.o
CC [M] nvidia-uvm/uvm_map_external.o
CC [M] nvidia-uvm/uvm_user_channel.o
CC [M] nvidia-uvm/uvm_hmm.o
CC [M] nvidia-uvm/uvm_perf_heuristics.o
CC [M] nvidia-uvm/uvm_perf_thrashing.o
CC [M] nvidia-uvm/uvm_perf_prefetch.o
CC [M] nvidia-uvm/uvm_ats.o
CC [M] nvidia-uvm/uvm_ats_ibm.o
CC [M] nvidia-uvm/uvm_ats_faults.o
CC [M] nvidia-uvm/uvm_ats_sva.o
CC [M] nvidia-uvm/uvm_conf_computing.o
CC [M] nvidia-uvm/uvm_test.o
CC [M] nvidia-uvm/uvm_test_rng.o
CC [M] nvidia-uvm/uvm_range_tree_test.o
CC [M] nvidia-uvm/uvm_range_allocator_test.o
CC [M] nvidia-uvm/uvm_gpu_semaphore_test.o
CC [M] nvidia-uvm/uvm_mem_test.o
CC [M] nvidia-uvm/uvm_rm_mem_test.o
CC [M] nvidia-uvm/uvm_page_tree_test.o
CC [M] nvidia-uvm/uvm_tracker_test.o
CC [M] nvidia-uvm/uvm_push_test.o
CC [M] nvidia-uvm/uvm_channel_test.o
CC [M] nvidia-uvm/uvm_ce_test.o
CC [M] nvidia-uvm/uvm_host_test.o
CC [M] nvidia-uvm/uvm_lock_test.o
CC [M] nvidia-uvm/uvm_perf_utils_test.o
CC [M] nvidia-uvm/uvm_kvmalloc_test.o
CC [M] nvidia-uvm/uvm_pmm_test.o
CC [M] nvidia-uvm/uvm_pmm_sysmem_test.o
CC [M] nvidia-uvm/uvm_perf_events_test.o
CC [M] nvidia-uvm/uvm_perf_module_test.o
CC [M] nvidia-uvm/uvm_get_rm_ptes_test.o
CC [M] nvidia-uvm/uvm_fault_buffer_flush_test.o
CC [M] nvidia-uvm/uvm_peer_identity_mappings_test.o
CC [M] nvidia-uvm/uvm_va_block_test.o
CC [M] nvidia-uvm/uvm_range_group_tree_test.o
CC [M] nvidia-uvm/uvm_thread_context_test.o
CC [M] nvidia-uvm/uvm_rb_tree_test.o
CC [M] nvidia-uvm/uvm_sec2_test.o
CC [M] nvidia-modeset/nvidia-modeset-linux.o
CC [M] nvidia-modeset/nv-kthread-q.o
CC [M] nvidia-drm/nvidia-drm.o
CC [M] nvidia-drm/nvidia-drm-drv.o
CC [M] nvidia-drm/nvidia-drm-utils.o
CC [M] nvidia-drm/nvidia-drm-crtc.o
CC [M] nvidia-drm/nvidia-drm-encoder.o
CC [M] nvidia-drm/nvidia-drm-connector.o
CC [M] nvidia-drm/nvidia-drm-gem.o
CC [M] nvidia-drm/nvidia-drm-fb.o
CC [M] nvidia-drm/nvidia-drm-modeset.o
CC [M] nvidia-drm/nvidia-drm-fence.o
CC [M] nvidia-drm/nvidia-drm-helper.o
CC [M] nvidia-drm/nv-kthread-q.o
nvidia-drm/nvidia-drm-drv.c:1918:6: error: ‘struct drm_driver’ has no member named ‘date’
1918 | .date = “20160202”,
nvidia-drm/nvidia-drm-drv.c:1918:31: error: initialization of ‘unsigned int’ from ‘char *’ makes integer from pointer without a cast [-Wint-conversion]
nvidia-drm/nvidia-drm-drv.c:1918:31: note: (near initialization for ‘nv_drm_driver.driver_features’)
nvidia-drm/nvidia-drm-drv.c:1918:31: error: initializer element is not computable at load time
make[4]: *** [/usr/src/linux-headers-6.13.0-amd64/scripts/Makefile.build:207: nvidia-drm/nvidia-drm-drv.o] Error 1
make[4]: *** Attente des tâches non terminées…
make[3]: *** [/usr/src/linux-headers-6.13.0-amd64/Makefile:1994: .] Error 2
make[2]: *** [/usr/src/linux-headers-6.13.0-amd64/Makefile:251: __sub-make] Error 2
make[2] : on quitte le répertoire « /var/lib/dkms/nvidia/570.86.16/build »
make[1]: *** [Makefile:251: __sub-make] Error 2
make[1] : on quitte le répertoire « /usr/src/linux-headers-6.13.0-amd64 »
make: *** [Makefile:115: modules] Error 2
I tried many drivers but it didn’t work
I tried
and
but nothing.
Any help will be welcome
Mahashakti89
Try the latest beta.
The current release is not compatible with 6.13.
Thanks for your answer
I already tried it. Same result
PS :What’s for you latest BETA ?
This one: Driver Details | NVIDIA
This is the driver I used
Problem solved with new driver NVIDIA-Linux-x86_64-570.124.04.run
