Bug for __pipeline_memcpy_async
it seems to me that there is a bug or that I made a mistake in my use of __pipeline memcpy async, there is no implementation online for the moment so it is complicated to implement
Code;
#include <stdio.h>
#include <cuda_pipeline.h>
__global__ void test_pipe_intr(float* input) {
    __shared__ float smem[32];
    __shared__ int idx4;
    idx4 = threadIdx.x * 4;
    // for tread 0 get it imput[0 - 4], for tread 1 get it imput[4 - 8]
    __pipeline_memcpy_async(smem, input + idx4, 16);
    __pipeline_commit();
    __pipeline_wait_prior(0);
    printf("% i = %f \n", threadIdx.x, smem[0]);
int main() {
    float* h_C = (float*)malloc(32000*sizeof(float));
    float* d_C;
    // fill a array from 0 to 32000
    for (int i = 0; i < 32000; i++) {
        h_C[i] = i;
    cudaMalloc(&d_C, 32000*sizeof(float));
    cudaMemcpy(d_C, h_C, 32000*sizeof(float), cudaMemcpyHostToDevice);
    test_pipe_intr<<<1, 32>>>(d_C);
    cudaDeviceSynchronize();
venus@V:~/Pipeline$ compute-sanitizer ./a.out
========= COMPUTE-SANITIZER
 0 = 96.000000
 1 = 96.000000
 2 = 96.000000
 3 = 96.000000
 4 = 96.000000
 5 = 96.000000
 6 = 96.000000
 7 = 96.000000
 8 = 96.000000
 9 = 96.000000
 10 = 96.000000
 11 = 96.000000
 12 = 96.000000
 13 = 96.000000
 14 = 96.000000
 15 = 96.000000
 16 = 96.000000
 17 = 96.000000
 18 = 96.000000
 19 = 96.000000
 20 = 96.000000
 21 = 96.000000
 22 = 96.000000
 23 = 96.000000
 24 = 96.000000
 25 = 96.000000
 26 = 96.000000
 27 = 96.000000
 28 = 96.000000
 29 = 96.000000
 30 = 96.000000
 31 = 96.000000
========= ERROR SUMMARY: 0 errors
I expected to have 0 = 0, 1 = 4, 2 = 8… as a result
Thank for hell
That won’t work. You might wish to understand how shared memory works. It is shared among all threads in the block. I’m pretty sure you want an ordinary local variable there:
int idx4 = threadIdx.x*4;
Furthermore, you haven’t allocated enough shared memory for 32 threads in the block * four float quantities per thread (16 bytes per thread). You have various indexing errors as well. It’s not clear you understand what __shared__ memory is or how it works.
    __shared__ float smem[32*4];
    int idx4 = threadIdx.x * 4;
    __pipeline_memcpy_async(smem + idx4, input + idx4, 16);
    printf("% i = %f \n", threadIdx.x, smem[idx4]);
