1.) PBO texture size of 2048 causes a 15ms delay
Configuration: 64Bit Windows, newest 64Bit Drivers, GTX280
If the PBO size for the screen-texture in my CUDA environment is set to 1024x1024 there is no problem, but if its set to 2048x2048 then there is a 20ms delay by the driver for registering and unregistering the driver.
cudaGLRegisterBufferObject(pbo)
cudaGLUnregisterBufferObject(pbo)
on 32 Bit there is no such error.
2.) GL_STREAM_DRAW which worked well in oder CUDA versions causes a 20ms delay in CUDA 2.3
Configuration: Cuda:2.3, Windows XP 32 Bit, Drivers 6.14.11.9038, GTX260 & GTX285 tested
In older CUDA versions (like 2.1), GL_STREAM_DRAW worked well to create the PBO (glBufferData).
In CUDA 2.3, the parameter needs to be changed to GL_DYNAMIC_COPY
If any of you knows a workaround for the 1st bug that would be very helpful.
