I have sort of hoped that someone else would have reported this by now.
This bug happens only on laptops with dual GPUs installed, and which have a high resolution high refresh rate and optionally HDR attached, and only when running Wayland as a compositor on the iGPU.
On my specific system, the following text is displayed in the journal at irregular intervals:
Mar 11 07:14:36 Evert.Scar kwin_wayland[2020]: 0x500: GL_INVALID_ENUM error generated. Invalid .
Mar 11 07:14:36 Evert.Scar kwin_wayland[2020]: Invalid framebuffer status: “GL_FRAMEBUFFER_INCOMPLETE_MISSING_ATTACHMENT”
Mar 11 07:14:36 Evert.Scar kwin_wayland[2020]: Failed to create framebuffer: Invalid argument
The system seems stable and performant most of the time. Any instabilities in the system cannot be purely ascribed to this issue, so I am not going to speculate.
A bug report has been raised with KDE:
And with freedesktop:
There is a workaround described in the Arch Linux forums:
But this workaround just has the nVdia GPU do the composing, which defeats the purpose of Optimus graphics.
My hunch is that kwin_wayland is calling something in the nVidia driver in a way that is not properly implemented.
With the latest nvidia drivers, this problem got way worse.
I get this error on every screen update now, and with a display rate of 144Hz, this makes for some pretty big logs.
My current workaround is to run the system in AsusMuxDgpu mode when the external monitor is plugged in.
Unfortunately suspend is broken in AsusMuxDgpu mode, so I had to turn that off as well.
From what I can tell, the problem is tied to the hybrid Wayland setup itself, especially when the internal panel is on the AMD iGPU and at
least one external display is active on the NVIDIA GPU.
When I switch from 240hz to 60hz - it helps but it does not fix the problem
I ended up here because on my laptop (multi-GPU with NVIDIA GeForce GTX 1660 Ti) with external monitor running Ubuntu 25.10 (nvidia-driver-580.142) and (now) Ubuntu 26.04 (nvidia-driver-595.58) with KDE plasma+Wayland I experienced a complete system freeze when trying to move my mouse from internal laptop display to external monitor. A discussion with an AI did not provide a solution. The link posted above saved my day, because setting ‘KWIN_FORCE_SW_CURSOR=1’ did it for me. Nevertheless AI suggested it being a NVIDIA issue not an KDE issue. Thats why I wanted to add that reply here. Maybe that can be of any help?
For some unknown reason I cannot upload the log of the nvidia-bug-report.sh… Keeps hanging on “processing upload”
Thanks for posting this here. I’ll post it with the KDE bug report, and hopefully someone will get to the bottom of why this is happening.
Confirmed that forcing a software cursor fixes the issue on my system too.
i had to disable logging because it was writing to my SSD constantly i only noticed the issue because i noticed my NVME heating to 60 on idle which wasn’t normal
