Kwin_wayland_drm: Pageflip timed out! - Complete system freeze
When I run moderately demanding games, my system will inevitably hard freeze after some time (neither TTYs or the SysReq keys will work).
I have stress tested my system with memtester86+ and s-tui and no errors occurred. This issue also has never occurred on Windows.
journallog.txt (652.7 KB)
dmesg.txt (78.4 KB)
journalctl-plasma-kwin_wayland.txt (22.1 KB)
Same happened to me:
Journal:
mar 15 10:26:51 fedora systemd[3598]: Starting plasma-kwin_wayland.service - KDE Window Manager...
mar 15 10:26:51 fedora systemd[3598]: Started plasma-kwin_wayland.service - KDE Window Manager.
mar 15 10:26:52 fedora kwin_wayland[3937]: No backend specified, automatically choosing drm
mar 15 10:26:54 fedora kwin_wayland_wrapper[4036]: The XKEYBOARD keymap compiler (xkbcomp) reports:
mar 15 10:26:54 fedora kwin_wayland_wrapper[4036]: > Warning:          Unsupported maximum keycode 708, clipping.
mar 15 10:26:54 fedora kwin_wayland_wrapper[4036]: >                   X11 cannot support keycodes above 255.
mar 15 10:26:54 fedora kwin_wayland_wrapper[4036]: > Warning:          Could not resolve keysym XF86KbdInputAssistPrevgrou
mar 15 10:26:54 fedora kwin_wayland_wrapper[4036]: > Warning:          Could not resolve keysym XF86KbdInputAssistNextgrou
mar 15 10:26:54 fedora kwin_wayland_wrapper[4036]: Errors from xkbcomp are not fatal to the X server
mar 15 10:26:58 fedora kwin_wayland[3937]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
mar 15 10:27:03 fedora kwin_wayland[3937]: Module 'org.kde.kwin.decoration' does not contain a module identifier directive - i>
mar 15 10:27:13 fedora kwin_wayland[3937]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
mar 15 10:29:29 fedora kwin_wayland[3937]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
mar 15 10:29:31 fedora kwin_wayland[3937]: kwin_scene_opengl: 0x502: GL_INVALID_OPERATION error generated.
mar 15 10:33:14 fedora kwin_wayland[3937]: kwin_scene_opengl: 0x502: GL_INVALID_OPERATION error generated.
mar 15 10:33:19 fedora kwin_wayland[3937]: kwin_scene_opengl: 0x502: GL_INVALID_OPERATION error generated.
mar 15 10:41:24 fedora kwin_wayland[3937]: kwin_core: Cannot grant a token to KWin::ClientConnection(0x55ef9340e920)
dmesg.txt (110.2 KB)
Same happened here, but the reason is because I use a Samsung Odyssey G5 34" 165hz Ultrawide monitor. When using the old AOC 2230Fh which pre-dates 2010 it works just fine.
dmesg.txt (113.8 KB)
journalctl.txt (166.7 KB)
