One monitor completely freezes seemingly at random. I left my computer locked (not asleep) for a few hours, and I came back to one monitor that said 3:26PM(completely frozen) as well as one monitor that seems fine (8:15 PM currently).
I have seen this issue over the passed 2 days since switching to Fedora. I can CRTL + ALT + F3 to a tty and then back to KDE and everything will work.
I was on Kubuntu 24.10 for about a year and did not have many driver issues, but recently switched back to Fedora 41 (now 42).
System info:
Operating System: Fedora Linux 42
KDE Plasma Version: 6.3.4
KDE Frameworks Version: 6.13.0
Qt Version: 6.9.0
Kernel Version: 6.14.4-300.fc42.x86_64 (64-bit)
Graphics Platform: Wayland
Processors: 16 × Intel® Core™ i7-10700K CPU @ 3.80GHz
Memory: 31.1 GiB of RAM
Graphics Processor 1: NVIDIA GeForce RTX 3070
Graphics Processor 2: Intel® UHD Graphics 630
Product Name: Z590 Steel Legend WiFi 6E
Journalctl:
❯ journalctl --user-unit plasma-kwin_wayland --boot 0
May 01 10:12:15 terminal systemd[1646]: Starting plasma-kwin_wayland.service - KDE Window Manager…
May 01 10:12:15 terminal systemd[1646]: Started plasma-kwin_wayland.service - KDE Window Manager.
May 01 10:12:15 terminal kwin_wayland[1936]: No backend specified, automatically choosing drm
May 01 10:12:16 terminal kwin_wayland_wrapper[2055]: The XKEYBOARD keymap compiler (xkbcomp) reports:
May 01 10:12:16 terminal kwin_wayland_wrapper[2055]: > Warning: Could not resolve keysym XF86RefreshRateToggle
May 01 10:12:16 terminal kwin_wayland_wrapper[2055]: > Warning: Could not resolve keysym XF86Accessibility
May 01 10:12:16 terminal kwin_wayland_wrapper[2055]: > Warning: Could not resolve keysym XF86DoNotDisturb
May 01 10:12:16 terminal kwin_wayland_wrapper[2055]: Errors from xkbcomp are not fatal to the X server
May 01 10:12:16 terminal maliit-keyboard[2028]: QSoundEffect(pulseaudio): Error decoding source file:///usr/share/maliit/keyboard2/sounds/key_tick2_quiet.wav
May 01 10:12:16 terminal kwin_wayland_wrapper[2064]: The XKEYBOARD keymap compiler (xkbcomp) reports:
May 01 10:12:16 terminal kwin_wayland_wrapper[2064]: > Warning: Unsupported maximum keycode 708, clipping.
May 01 10:12:16 terminal kwin_wayland_wrapper[2064]: > X11 cannot support keycodes above 255.
May 01 10:12:16 terminal kwin_wayland_wrapper[2064]: > Warning: Could not resolve keysym XF86RefreshRateToggle
May 01 10:12:16 terminal kwin_wayland_wrapper[2064]: > Warning: Could not resolve keysym XF86Accessibility
May 01 10:12:16 terminal kwin_wayland_wrapper[2064]: > Warning: Could not resolve keysym XF86DoNotDisturb
May 01 10:12:16 terminal kwin_wayland_wrapper[2064]: Errors from xkbcomp are not fatal to the X server
May 01 10:12:19 terminal kwin_wayland[1936]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
May 01 10:12:36 terminal kwin_wayland[1936]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
May 01 10:12:37 terminal kwin_wayland[1936]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
May 01 10:17:55 terminal kscreenlocker_greet[4264]: qt.gui.imageio: libpng warning: iCCP: known incorrect sRGB profile
May 01 10:17:55 terminal maliit-keyboard[2028]: QSGContext::initialize: depth buffer support missing, expect rendering errors
May 01 10:17:55 terminal maliit-keyboard[2028]: QSGContext::initialize: stencil buffer support missing, expect rendering errors
May 01 10:28:25 terminal kscreenlocker_greet[4264]: qt.qpa.wayland: Could not create EGL surface (EGL error 0x3003)
May 01 10:28:25 terminal kscreenlocker_greet[4264]: Failed to write to the pipe: Bad file descriptor.
May 01 10:34:11 terminal kwin_wayland[1936]: kwin_libinput: Libinput: client bug: timer event3 debounce short: scheduled expiry is in the past (-23ms), your system is too slow
May 01 10:51:15 terminal kscreenlocker_greet[6800]: qt.gui.imageio: libpng warning: iCCP: known incorrect sRGB profile
May 01 12:38:42 terminal kscreenlocker_greet[6800]: qt.qpa.wayland: Could not create EGL surface (EGL error 0x3003)
May 01 12:38:42 terminal kscreenlocker_greet[6800]: Failed to write to the pipe: Bad file descriptor.
May 01 12:56:59 terminal kscreenlocker_greet[10490]: qt.gui.imageio: libpng warning: iCCP: known incorrect sRGB profile
May 01 13:49:31 terminal kscreenlocker_greet[10490]: qt.qpa.wayland: Could not create EGL surface (EGL error 0x3003)
May 01 13:49:31 terminal kscreenlocker_greet[10490]: Failed to write to the pipe: Bad file descriptor.
May 01 14:22:07 terminal kwin_wayland[1936]: qt.dbus.integration: QDBusConnection: couldn’t handle call to Teardown, no slot matched
May 01 14:22:07 terminal kwin_wayland[1936]: qt.dbus.integration: Could not find slot Krunner1Adaptor::Teardown
May 01 14:37:16 terminal kscreenlocker_greet[17336]: qt.gui.imageio: libpng warning: iCCP: known incorrect sRGB profile
May 01 15:26:17 terminal kwin_wayland[1936]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 01 15:26:17 terminal kwin_wayland[1936]: kwin_wayland_drm: Please report this at
May 01 15:26:17 terminal kwin_wayland[1936]: kwin_wayland_drm: With the output of ‘sudo dmesg’ and ‘journalctl --user-unit plasma-kwin_wayland --boot 0’
May 01 15:26:18 terminal kwin_wayland[1936]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 01 15:26:18 terminal kwin_wayland[1936]: kwin_wayland_drm: Please report this at
May 01 15:26:18 terminal kwin_wayland[1936]: kwin_wayland_drm: With the output of ‘sudo dmesg’ and ‘journalctl --user-unit plasma-kwin_wayland --boot 0’
May 01 15:26:19 terminal kwin_wayland[1936]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 01 15:26:19 terminal kwin_wayland[1936]: kwin_wayland_drm: Please report this at
May 01 15:26:19 terminal kwin_wayland[1936]: kwin_wayland_drm: With the output of ‘sudo dmesg’ and ‘journalctl --user-unit plasma-kwin_wayland --boot 0’
May 01 15:26:20 terminal kwin_wayland[1936]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 01 15:26:20 terminal kwin_wayland[1936]: kwin_wayland_drm: Please report this at
May 01 15:26:20 terminal kwin_wayland[1936]: kwin_wayland_drm: With the output of ‘sudo dmesg’ and ‘journalctl --user-unit plasma-kwin_wayland --boot 0’
May 01 15:26:21 terminal kwin_wayland[1936]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 01 15:26:21 terminal kwin_wayland[1936]: kwin_wayland_drm: Please report this at
May 01 15:26:21 terminal kwin_wayland[1936]: kwin_wayland_drm: With the output of ‘sudo dmesg’ and ‘journalctl --user-unit plasma-kwin_wayland --boot 0’
May 01 15:26:22 terminal kwin_wayland[1936]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 01 15:26:22 terminal kwin_wayland[1936]: kwin_wayland_drm: Please report this at
May 01 15:26:22 terminal kwin_wayland[1936]: kwin_wayland_drm: With the output of ‘sudo dmesg’ and ‘journalctl --user-unit plasma-kwin_wayland --boot 0’
May 01 15:26:23 terminal kwin_wayland[1936]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 01 15:26:23 terminal kwin_wayland[1936]: kwin_wayland_drm: Please report this at Linux - NVIDIA Developer Forums
May 01 15:26:23 terminal kwin_wayland[1936]: kwin_wayland_drm: With the output of ‘sudo dmesg’ and ‘journalctl --user-unit plasma-kwin_wayland --boot 0’
May 01 15:26:24 terminal kwin_wayland[1936]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 01 15:26:24 terminal kwin_wayland[1936]: kwin_wayland_drm: Please report this at Linux - NVIDIA Developer Forums
May 01 15:26:24 terminal kwin_wayland[1936]: kwin_wayland_drm: With the output of ‘sudo dmesg’ and ‘journalctl --user-unit plasma-kwin_wayland --boot 0’
May 01 15:26:25 terminal kwin_wayland[1936]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 01 15:26:25 terminal kwin_wayland[1936]: kwin_wayland_drm: Please report this at Linux - NVIDIA Developer Forums
May 01 15:26:25 terminal kwin_wayland[1936]: kwin_wayland_drm: With the output of ‘sudo dmesg’ and ‘journalctl --user-unit plasma-kwin_wayland --boot 0’
May 01 15:26:26 terminal kwin_wayland[1936]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 01 15:26:26 terminal kwin_wayland[1936]: kwin_wayland_drm: Please report this at Linux - NVIDIA Developer Forums
dmesg:
dmesgoutput.txt (102.7 KB)
sudo nvidia-bug-report.sh --extra-system-data
nvidia-bug-report.log.gz (1.5 MB)
