once every couple of hours, my system freezes completely.
To “unstuck” it, I have to switch TTY (CTRL+ALT+F3), then go back to the graphical session (CTRL+ALT+F2). Then, the computer works, but has a lower framerate (probably 60hz); I have to switch the framerate to a lower value, then bump it up again.
When this happens, I see this in dmesg:
[18096.465785] [drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000a00] Flip event timeout on head 0
[18099.665638] [drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000a00] Flip event timeout on head 0
Some specs:
I have a 3090 graphics card, and a 4k, 240hz, HDR monitor. I use Gnome, with HDR turned on, but the issue occurred even with HDR off, and using a lower framerate.
marco@fedora:~$ uname -a
Linux fedora 6.14.9-300.fc42.x86_64 #1 SMP PREEMPT_DYNAMIC Thu May 29 14:27:53 UTC 2025 x86_64 GNU/Linux
marco@fedora:~$ nvidia-smi
Mon Jun 2 16:44:38 2025
| NVIDIA-SMI 570.153.02 Driver Version: 570.153.02 CUDA Version: 12.8 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 3090 Off | 00000000:0A:00.0 On | N/A |
| 0% 54C P0 88W / 370W | 2654MiB / 24576MiB | 19% Default |
| | | N/A |
marco@fedora:~$ cat /etc/default/grub
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR="$(sed 's, release .*$,,g' /etc/system-release)"
GRUB_DEFAULT=saved
GRUB_DISABLE_SUBMENU=true
GRUB_TERMINAL_OUTPUT="console"
GRUB_CMDLINE_LINUX="rhgb quiet nvidia-drm.modeset=1 rd.driver.blacklist=nouveau modprobe.blacklist=nouveau"
GRUB_DISABLE_RECOVERY="true"
GRUB_ENABLE_BLSCFG=true
