Bug: 570.124.04 - freeze on monitor wakeup - "Flip event timeout"
Started right after I upgraded to 570.124.04.
Was not present in 570.86.16.
To replicate -
  1. Lock the system with two monitors. Wait until monitors are switched off.
  2. Press any key.
  3. Symptoms: Primary monitor wakes up but system is frozen. The other monitor does not wake up.
I tried Ctrl+Alt+F1 to reboot, unfortunately that did not work either; it froze the system completely (Capslock no longer lit up on keyboard).
System configuration -
GPU: RTX 3090
Monitors: Two
Operating System: Arch Linux
Desktop Environment: KDE (Wayland)
Display Manager: ly (text-based, instead of SDDM)
Journal excerpt -
repeat of this many times -
Mar 02 12:42:05 workstation kwin_wayland[1190]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Mar 02 12:42:05 workstation kwin_wayland[1190]: kwin_wayland_drm: Please report this at Linux - NVIDIA Developer Forums
Mar 02 12:42:05 workstation kwin_wayland[1190]: kwin_wayland_drm: With the output of ‘sudo dmesg’ and ‘journalctl --user-unit plasma-kwin_wayland --boot 0’
Mar 02 12:42:06 workstation kwin_wayland[1190]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Mar 02 12:42:06 workstation kwin_wayland[1190]: kwin_wayland_drm: Please report this at Linux - NVIDIA Developer Forums
Mar 02 12:42:06 workstation kwin_wayland[1190]: kwin_wayland_drm: With the output of ‘sudo dmesg’ and ‘journalctl --user-unit plasma-kwin_wayland --boot 0’
interspersed sometimes with kernel: [drm:nv_drm_atomic_comit [nvidia_drm]] ERROR -
Mar 02 12:42:35 workstation kwin_wayland[1190]: kwin_wayland_drm: With the output of ‘sudo dmesg’ and ‘journalctl --user-unit plasma-kwin_wayland --boot 0’
Mar 02 12:42:36 workstation kernel: [drm:nv_drm_atomic_commit [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Flip event timeout on head 0
Mar 02 12:42:36 workstation kwin_wayland[1190]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Mar 02 12:42:36 workstation kwin_wayland[1190]: kwin_wayland_drm: Please report this at Linux - NVIDIA Developer Forums
Having the same problem. I’ve submitted a bug report to NVIDIA. I’m also getting: nvidia-modeset: ERROR: GPU:0: Error while waiting for GPU progress
Running 6.13.5-arch1-1 with 570.124.04-2 and when I turn off my monitor and turn it back on the screen is black and my second monitor that I didn’t turn off is frozen and the system completely freezes.
nvidia-bug-report.log (2.5 MB)
I have the same issue when returning back from stand-by. It started happening on 570.124.04, but it was not an issue on 570.86.16.
Here’s my journalctl dump:
kwin_wayland[1353]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
kwin_wayland[1353]: kwin_scene_opengl: 0x501: GL_INVALID_VALUE error generated. <levels>, <width> and <height> must be 1 or greater.
kwin_wayland[1353]: kwin_scene_opengl: Invalid framebuffer status:  "GL_FRAMEBUFFER_INCOMPLETE_ATTACHMENT"
kwin_wayland[1353]: kwin_scene_opengl: 0x502: GL_INVALID_OPERATION error generated. Framebuffer name must be generated before being bound.
kwin_wayland[1353]: kwin_scene_opengl: 0x506: GL_INVALID_FRAMEBUFFER_OPERATION error generated. Operation is not valid because a bound framebuffer is not framebuffer complete.
kwin_wayland[1353]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
kwin_wayland[1353]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
kwin_wayland[1353]: kwin_wayland_drm: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
kwin_wayland[1353]: kwin_wayland_drm: The main thread was hanging temporarily!
Workaround
It seems like the bug occurs only when two monitors are active.
Given that, here is my very hacky workaround without having to downgrade, until this is fixed.
I created this script to switch to one monitor on screen lock, and reset to my original config on unlock.
#!/bin/bash
# one_monitor_on_screenlock.sh
set -uexo pipefail
dbus-monitor --session "type='signal',interface='org.freedesktop.ScreenSaver',member='ActiveChanged'" | \
while read line; do
    if echo "$line" | grep -q "boolean true"; then
        kscreen-doctor output.DP-1.enable output.DP-4.disable
    elif echo "$line" | grep -q "boolean false"; then
        kscreen-doctor output.DP-4.enable output.DP-4.position.2560,0 output.DP-4.priority.1 output.DP-1.enable
    fi
done
Then I added it as a Login Script in KDE Settings → Autostart.
I have the exact same issue (Arch 6.13.5, Hyprland), except I have a single monitor (AW3821DW) and the moment it goes into DPMS ON (from the lock screen) I can’t have it turn on again. Requires a full reboot.
I get the following in the journal:
[drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000a00] Flip event timeout on head 0
I’ve reverted to 570.86.16 which is working properly.
I see this issue too, started with 570.124.04, did not happen with previous 570.86.16.
I’m on Gentoo with Linux 6.13.5-gentoo-dist and I have two monitors, 1 TFT connected via Displayport and a TV connected via HDMI. After I turn off all the screens, it seems everything is frozen and I can’t get any of the screens to turn on again. I can however ssh into the system and issue a soft reboot, so it is not actually frozen
I am also experiencing this but with three monitors.
[drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Flip event timeout on head 2
[drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to apply atomic modeset.  Error code: -22
kwin_wayland_drm: atomic commit failed: Device or resource busy
There is a new version, 570.124.06, in the cuda repository and I don’t have this issue on that version.
I’m sorry this isn’t true. Happened after the third time my monitors woke up. Although I did get this log event instead:
kwin_wayland_drm: No drm events for gpu "/dev/dri/card0" within last 1 second
Confirming. Same issue on latest Arch, with same logs on desktop with RTX4070 and one external monitor via DisplayPort.
mar 04 11:47:01 onyx kwin_wayland[751]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
mar 04 11:47:01 onyx kwin_wayland[751]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
mar 04 11:47:01 onyx kwin_wayland[751]: kwin_wayland_drm: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
mar 04 11:47:02 onyx kwin_wayland[751]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
mar 04 11:47:02 onyx kwin_wayland[751]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
mar 04 11:47:02 onyx kwin_wayland[751]: kwin_wayland_drm: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
mar 04 11:47:03 onyx kernel: [drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Flip event timeout on head 0
mar 04 11:47:03 onyx kwin_wayland[751]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
mar 04 11:47:03 onyx kwin_wayland[751]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
mar 04 11:47:03 onyx kwin_wayland[751]: kwin_wayland_drm: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
mar 04 11:47:04 onyx kwin_wayland[751]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
mar 04 11:47:04 onyx kwin_wayland[751]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
mar 04 11:47:04 onyx kwin_wayland[751]: kwin_wayland_drm: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
mar 04 11:47:05 onyx kwin_wayland[751]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
mar 04 11:47:05 onyx kwin_wayland[751]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
mar 04 11:47:05 onyx kwin_wayland[751]: kwin_wayland_drm: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
mar 04 11:47:06 onyx kwin_wayland[751]: kwin_wayland_drm: Pageflip arrived after all, 43546ms after the commit
mar 04 11:47:06 onyx kernel: [drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Flip event timeout on head 0
mar 04 11:47:06 onyx kwin_wayland[751]: kwin_wayland_drm: atomic commit failed: Permission denied
mar 04 11:47:09 onyx kernel: [drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Flip event timeout on head 0
mar 04 11:47:12 onyx kernel: [drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Flip event timeout on head 0
Same here, with two screens, Wayland on EndeavourOS with latest driver 570.124.04 on nvidia-open.
Same here, with one screen, Wayland (Gnome and KDE) on Nobara41 with latest nvidia-open and closed.
Only a Downgrade to 570.86.16 Helped.
Same monitor (i have only 1 monitor) with a 4070 super and using Bazzite that come with 570.124.04 driver and the system freeze when resuming from sleep :
nvidia-modeset: ERROR: GPU:0: Error while waiting for GPU progress: 0x0000c67e:6 2:0:2824:2816
Mar 03 20:34:38 bazzite kernel: nvidia-modeset: ERROR: GPU:0: Error while waiting for GPU progress: 0x0000c67e:6 2:0:2824:2816
570.86.16 is fine.
Hi all,
The Pageflip timed out! issue is being tracked on NVIDIA Bug # 5158370.
The nvidia-modeset: ERROR: GPU:0: Error while waiting for GPU progress issue is being tracked on NVIDIA Bug # 5141371 (bananen’s report).
They may have the same root cause but are being tracked separately for now.
Thank you
Thank you very much! I could not find a link to #5158370, is it in an internal tracker?
Please let me know if you need any inputs, e.g. for replicating the issue.
Some more details from me -
Software: KDE, Arch Linux
GPU: RTX 3090
Monitors: Two 1440p monitors connected directly to the GPU via the two Displayport connectors.
How to replicate:
  1. To make it quicker to replicate, set Display & Brightness → Turn of Screen → “When Locked: Immediately”.
  2. Lock screen with Win+L. Your monitors will turn off, while the CPU should still be active.
  3. Wake up the monitors by moving the mouse or pressing a key.
  4. If the issue occurs, you’ll notice one of the monitors does not wake up and the other freezes.
Frequency of the issue: Happens with a very high probability, perhaps every time.
Similar here and have had to revert back to 570.86.16
System Config:
Arch Linux
4 monitors (all at 60 Mhz, I’m a dba/dev, not a gamer)
XORG
GPU: GeForce RTX 4060 Ti (8 GB RAM).
CPU: AMD Ryzen 5 3600
Window Manager: i3
It does not matter whether GSP is enabled or disabled.
On resuming from suspend:
  • two monitors (out of four) do not come back. The ones that do not come back are numbers 1 and 2 in the ordering sequence.
  • any graphics slows to a crawl - e.g. mouse may move jerkily 4 pixels every 3 seconds.
  • keyboard still works but it may take a couple of minutes to get the system to recognize that I want focus at monitor 3
  • I can ssh in with no problem - However, attempts to shutdown and restart get blocked by the following error message: nvidia-modeset: ERROR: GPU:0: Error while waiting for GPU progress: 0x0000c77d:0 2:0:348:336
  • The other error that is seen is:
    nvidia-modeset: ERROR: GPU:0: Idling display engine timed out: 0x0000c67e:6:0:1230
Yes. This is an internal bug. I will post updates from our investigation when available. Thanks
I’m having a similar, although possibly different, bug. The monitor will freeze, but the system otherwise continues to work. Music keeps playing, USB devices can still control audio, and if I’m on call with people they can still hear me + see my camera if it was on. I get the same error message from journalctl though, and the symptoms seem similar.
System config:
Fedora 42
1 monitor (AW34DWF)
Wayland
GPU: 4090
CPU: Ryzen 9 5950x
KDE
For me, the bug occurs somewhat randomly, although it maybe is related to browsers/electron apps. It works fine almost all the time, but occasionally it freezes during them. That being said, most of what I do on my computer is in browsers or electron apps, so might not be a real pattern.
Here’s the output from journalctl --user-unit plasma-kwin_wayland --boot -1
Mar 15 22:29:50 fedora kwin_wayland[5693]: kwin_core: Cannot grant a token to KWin::ClientConnection(0x559233542230)
Mar 15 22:31:48 fedora kwin_wayland[5693]: kwin_core: Cannot grant a token to KWin::ClientConnection(0x559233542230)
Mar 15 22:31:49 fedora kwin_wayland[5693]: kwin_core: Cannot grant a token to KWin::ClientConnection(0x559233542230)
Mar 15 22:31:50 fedora kwin_wayland[5693]: kwin_core: Cannot grant a token to KWin::ClientConnection(0x559233542230)
Mar 15 22:31:51 fedora kwin_wayland[5693]: kwin_core: Cannot grant a token to KWin::ClientConnection(0x559233542230)
Mar 15 22:31:52 fedora kwin_wayland[5693]: kwin_core: Cannot grant a token to KWin::ClientConnection(0x559233542230)
Mar 15 22:31:53 fedora kwin_wayland[5693]: kwin_core: Cannot grant a token to KWin::ClientConnection(0x559233542230)
Mar 15 22:31:54 fedora kwin_wayland[5693]: kwin_core: Cannot grant a token to KWin::ClientConnection(0x559233542230)
Mar 15 23:26:13 fedora kwin_wayland[5693]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Mar 15 23:26:13 fedora kwin_wayland[5693]: kwin_wayland_drm: Please report this at Linux - NVIDIA Developer Forums
Mar 15 23:26:13 fedora kwin_wayland[5693]: kwin_wayland_drm: With the output of ‘sudo dmesg’ and ‘journalctl --user-unit plasma-kwin_wayland --boot 0’
Mar 15 23:26:14 fedora kwin_wayland[5693]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
I have pretty much the same issue as @maxwellalt123. It occurs most frequently, if not always, when a Chromium/Electron-based application is running and seems to be related to GPU acceleration during video decoding when two monitors are connected. Recently, it happened while watching YouTube on a Chromium browser with the new 570.124.04 drivers. It occurred precisely when I was adjusting the brightness of monitor #1. The image froze on monitor #1, but monitor #2 continued to function perfectly. Restarting plasmashell does nothing, and the only thing that helps (though not always) is either restarting the entire sddm or opening a separate tty window using Ctrl + F3 and starting a new graphical session.
System config:
Operating System: Fedora Linux 41
KDE Plasma Version: 6.3.3
KDE Frameworks Version: 6.12.0
Qt Version: 6.8.2
Kernel Version: 6.13.6-200.fc41.x86_64 (64-bit)
Graphics Platform: Wayland
Processors: 16 × AMD Ryzen 7 2700X Eight-Core Processor
Memory: 23.3 GiB of RAM
Graphics Processor: NVIDIA GeForce RTX 3060 Ti
Manufacturer: Micro-Star International Co., Ltd
Product Name: MS-7B86
System Version: 7.0
This happens regardless of the kernel version and whether GSP or nvidia-drm.modeset=1 is enabled.
It always occurs on my primary monitor connected via DisplayPort.
Main Display Specs:
Acer Technologies XV242Y
165Hz 1080p DP
HDR: Disabled
Freesync: Disabled
Second Display Specs:
Acer Technologies VG220Q
75Hz HDMI
mar 16 23:57:25 fedora kwin_wayland[4653]: kwin_scene_opengl: 0x502: GL_INVALID_OPERATION error generated.
mar 17 00:01:01 fedora kwin_wayland[4653]: kwin_xwl: Could not create a source from 0x5594d2e2d0b0 0
mar 17 00:01:01 fedora kwin_wayland[4653]: kwin_xwl: Could not create a source from 0x5594d3d2be20 0
mar 17 00:01:09 fedora kwin_wayland[4653]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
mar 17 00:01:11 fedora kwin_wayland[4653]: kwin_scene_opengl: 0x502: GL_INVALID_OPERATION error generated.
mar 17 00:02:59 fedora kwin_wayland[4653]: kwin_core: XCB error: 3 (BadWindow), sequence: 27741, resource id: 20971715, major code: 129 (SHAPE), minor code: 6 (Input)
mar 17 00:05:55 fedora kwin_wayland[4653]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
mar 17 00:15:57 fedora kwin_wayland[4653]: kwin_core: XCB error: 3 (BadWindow), sequence: 29549, resource id: 20971722, major code: 129 (SHAPE), minor code: 6 (Input)
mar 17 00:25:46 fedora kwin_wayland[4653]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
mar 17 00:44:08 fedora kwin_wayland[4653]: kwin_core: XCB error: 3 (BadWindow), sequence: 38921, resource id: 20971787, major code: 129 (SHAPE), minor code: 6 (Input)
mar 17 00:46:13 fedora kwin_wayland[4653]: kwin_core: XCB error: 3 (BadWindow), sequence: 39034, resource id: 20971790, major code: 129 (SHAPE), minor code: 6 (Input)
mar 17 00:47:19 fedora kwin_wayland[4653]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
mar 17 00:47:19 fedora kwin_wayland[4653]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
mar 17 00:47:19 fedora kwin_wayland[4653]: kwin_wayland_drm: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Now I that you mention it, my display is display port as well. There might be a pattern there.
I’m seeing the same issue with a display port.
RTX 3060 on Linux 6.13.7-arch1-1 nvidia driver 570.124.04-4
