[BUG Report] 580.105.08 Monitor Freeze when Resuming from sleep or waking up monitors (3 Monitor setup, Cachyos Plasma))
Hello, I’m reporting here as instructed in the logs, when resuming from sleep or waking up screens after they go dark (by moving the mouse or hitting the keyboard), I get, seemingly at random, a whole system freeze, that can only be recovered through a hard reboot (power button press).
I had to disable sleep because it happened much more often when resuming from sleep that when simply waking screens, so this report is based on the waking up screen issue only
What happens :
  • PC is left unattended for some time and screens go dark as per the settings in KDE
  • Come back later and wake up monitor through moving the mouse, sometimes it works as expected (no crash), sometimes, monitor seem to wake up (power light indicates that it has a signal), some monitors get the latest image that was displayed, or a weird half loaded version (mostly black), and the last monitor stays blank
  • About 5 seconds later, one monitor goes to no signal while the others stay frozen
  • I have to reboot
In the logs I get the following error
déc. 05 19:58:33 Cadmium kwin_wayland[4010]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
déc. 05 19:58:33 Cadmium kwin_wayland[4010]: Please report this at Linux - NVIDIA Developer Forums
déc. 05 19:58:33 Cadmium kwin_wayland[4010]: With the output of ‘sudo dmesg’ and ‘journalctl --user-unit plasma-kwin_wayland --boot 0’
System Info
Operating System: CachyOS Linux
KDE Plasma Version: 6.5.3
KDE Frameworks Version: 6.20.0
Qt Version: 6.10.1
Kernel Version: 6.18.0-3-cachyos (64-bit)
Graphics Platform: Wayland
Processors: 8 × AMD Ryzen 7 7800X3D 8-Core Processor
Memory: 32 GiB of RAM (30,5 GiB usable)
Graphics Processor 1: NVIDIA GeForce RTX 4070 Ti SUPER
Graphics Processor 2: AMD Ryzen 7 7800X3D 8-Core Processor
Manufacturer: Micro-Star International Co., Ltd.
Product Name: MS-7D75
System Version: 1.0
Nvidia Driver version : 580.105.08
Please find attached wayland infos from the info centre and output from dmesg and journalctl --user-unit plasma-kwin_wayland --boot -1
I’m available for additional info if needed
Edit : Forgot to add driver version
I have the same problem.
I get event log errors from nvlddmkm such as this: The description for Event ID 14 from source nvlddmkm cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
\Device\000000c8
52344000 c062e03c 00000000 202d8dee 202d8a56 202d9592 202e31f4 202e30de
The message resource is present but the message was not found in the message table
Dear @developer.nvidia.com.surg
Thank you for reporting issue, please help to share nvidia bug report for triage purpose.
Hello, I thought this was fixed, but it still happens after updating to 590.48.01.
I’ve attached the bug report generated by nvidia-bug-report.sh
@amrits I’m not sure what you mean by your message ?
Does the dev team have a similar bug traced ? Is there any target for a fix ?
Thank you
nvidia-bug-report.log.gz (559.0 KB)
