Pageflip timed out when change brightness since 570.124.04
My main Monitor (DP) feezes when quickly changing color via plasma powerdevel since 570.124.04 and kwin throws pageflip timed out errors. My secondary Monitor (HDMI) is unaffected. Downgrading back to 570.86.16 resolves everything.
kernel.log (113.3 KB)
kwin.log (178.3 KB)
(The API mismatch errors come from downgrading the driver after the issue happened)
Operating System: Arch Linux
KDE Plasma Version: 6.3.2
KDE Frameworks Version: 6.11.0
Qt Version: 6.8.2
Kernel Version: 6.13.5-zen1-1-zen (64-bit)
Graphics Platform: Wayland
Processors: 16 × AMD Ryzen 7 5800X 8-Core Processor
Memory: 31.3 GiB of RAM
Graphics Processor: NVIDIA GeForce RTX 3070 Ti
I’m getting that, but that’s not the worst bug by far. For me, 570.124.04 doesn’t even come up and X more or less hangs with this:
Mar 1 03:22:09 flash kernel: nvidia-modeset: ERROR: GPU:0: Idling display engine timed out: 0x0000c67e:0:0:1230
This is with an RTX4090 and the 6.13.5 kernel. It’s unusable. I had to revert back to 570.86.16. X would not start up and I couldn’t even log into a text console. I had to either block the nvidia module or log in remotely via ssh.
I was able to fix this by deleting the kwinrc. (But this is probaply still a bug in the driver)
edit: it only happens when night light is enabled
Disabling night light really worked, though my driver is 570.86
Saw in my Journal entries to report the bug, someone has already so that’s good. Figured I would contribute more since I am here.
03:03:43.290 UTC user@1000.service kwin_wayland_drm: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
03:03:44.278 UTC user@1000.service kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
03:03:44.286 UTC user@1000.service kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
I am uploading the full output of journalctl --user-unit plasma-kwin_wayland --boot 0 if it helps at all. output.log (67.4 KB)
Can confirm that twice now after changing brightness levels my primary display freezes, I cannot see anything changing on the screen, my other two monitors continue to function. The only way I can make it snap out of it is by pressing Ctrl + F2 to force console change and then Ctrl + F1 to go back. That makes it go back to normal. Then I can adjust brightness.
Qt Version: 6.8.2
Kernel Version: 6.13.5-arch1-1 (64-bit)
Processors: 16 × AMD Ryzen 7 9800X3D 8-Core Processor
Memory: 60.4 GiB of RAM
Graphics Processor 1: NVIDIA GeForce RTX 4070/PCIe/SSE2
Graphics Processor 2: NVIDIA GeForce RTX 4070/PCIe/SSE2
Manufacturer: Gigabyte Technology Co., Ltd.
Product Name: X870 EAGLE WIFI7
System Version: Default string-CF-ADO
I don’t have two Graphics cards, not sure why it says that.
Driver: nvidia-dkms 570.124.04-1
Same. It’s my rightmost of 3 monitors that freezes. Then it completely breaks about a minute after that.
It happens randomly though, and doesn’t occur when I change brightness.
570.124.04
Kernel: Linux 6.13.7-2-cachyos
Display (Dell AW2721D): 2560x1440 @ 240 *
Display (VX2768-2KP): 2560x1440 @ 144 Hz]
DE: KDE Plasma 6.3.3
WM: KWin (Wayland)
CPU: AMD Ryzen 9 5900X (24) @ 4.95 GHz
GPU: NVIDIA GeForce RTX 3080
