Fresh install of KDE on Fedora with a 3060 xc. The screen turns off, then turns back on and the video output is frozen.
Command line: BOOT_IMAGE=(hd2,gpt2)/boot/vmlinuz-6.17.12-300.fc43.x86_64 root=UUID=f9db4109-9a11-45ee-905d-cb2acb68699f ro selinux=0 pcie=aspm_off usbcore.quirks=0bda:9210:k rd.driver.blacklist=nouveau,nova_core modprobe.blacklist=nouveau,nova_core
Should I just use Nouveau? Nouveau works but doesnt have good preformance.
I dont get it, I used GNOME for years, had proprietary drivers and never really had issues. Does KDE implement wayland in a stupid way? What should I even consider doing right now…
Dec 18 22:13:37 fedora kernel: ACPI: \_TZ_.TZ10: _PSL evaluation failure
Dec 18 22:13:37 fedora kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT0._GTF due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
Dec 18 22:13:37 fedora kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT1._GTF due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
Dec 18 22:13:37 fedora kernel: hid-generic 0003:3434:0360.0001: input,hidraw0: USB HID v1.11 Keyboard [Keychron Keychron V6] on usb-0000:00:14.0-9/input0
Dec 18 22:13:37 fedora kernel: hid-generic 0003:3434:0360.0002: hiddev96,hidraw1: USB HID v1.11 Device [Keychron Keychron V6] on usb-0000:00:14.0-9/input1
Dec 18 22:13:37 fedora kernel: hid-generic 0003:3434:0360.0003: input,hidraw2: USB HID v1.11 Mouse [Keychron Keychron V6] on usb-0000:00:14.0-9/input2
Dec 18 22:13:37 fedora kernel: playstation 0003:054C:05C4.0004: hidraw3: USB HID v1.11 Gamepad [Sony Computer Entertainment Wireless Controller] on usb-0000:00:14.0-4.3/input0
Dec 18 22:13:37 fedora kernel: hid-generic 0003:1532:0099.0005: input,hidraw4: USB HID v1.11 Mouse [Razer Razer Basilisk V3] on usb-0000:00:14.0-10/input0
Dec 18 22:13:37 fedora kernel: hid-generic 0003:1532:0099.0006: input,hidraw5: USB HID v1.11 Keyboard [Razer Razer Basilisk V3] on usb-0000:00:14.0-10/input1
Dec 18 22:13:37 fedora kernel: hid-generic 0003:1532:0099.0007: input,hidraw6: USB HID v1.11 Keyboard [Razer Razer Basilisk V3] on usb-0000:00:14.0-10/input2
Dec 18 22:13:37 fedora kernel: hid-generic 0003:1532:0099.0008: hidraw7: USB HID v1.11 Device [Razer Razer Basilisk V3] on usb-0000:00:14.0-10/input3
Dec 18 22:13:39 fedora systemd[1]: systemd-boot-clear-sysfail.service - Clear SysFail Entry If The Boot Is Successful was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/LoaderEntrySysFail-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f).
Dec 18 22:13:39 fedora kernel: razermouse: module verification failed: signature and/or required key missing - tainting kernel
Dec 18 22:13:40 fedora kernel: razermouse 0003:1532:0099.0005: input,hidraw4: USB HID v1.11 Mouse [Razer Razer Basilisk V3] on usb-0000:00:14.0-10/input0
Dec 18 22:13:40 fedora kernel: razermouse 0003:1532:0099.0006: input,hidraw5: USB HID v1.11 Keyboard [Razer Razer Basilisk V3] on usb-0000:00:14.0-10/input1
Dec 18 22:13:40 fedora systemd[1]: systemd-boot-clear-sysfail.service - Clear SysFail Entry If The Boot Is Successful was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/LoaderEntrySysFail-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f).
Dec 18 22:13:40 fedora kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 234
Dec 18 22:13:40 fedora kernel: nvidia 0000:01:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=io+mem
Dec 18 22:13:40 fedora kernel: razermouse 0003:1532:0099.0007: input,hidraw6: USB HID v1.11 Keyboard [Razer Razer Basilisk V3] on usb-0000:00:14.0-10/input2
Dec 18 22:13:40 fedora kernel: razermouse 0003:1532:0099.0008: hidraw7: USB HID v1.11 Device [Razer Razer Basilisk V3] on usb-0000:00:14.0-10/input3
Dec 18 22:13:40 fedora kernel: nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for x86_64 580.95.05 Release Build (dvs-builder@U22-I3-B17-02-5) Tue Sep 23 09:42:01 UTC 2025
Dec 18 22:13:40 fedora kernel: [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
Dec 18 22:13:42 fedora kernel: caller RmInitX86EmuState+0x11e/0x25e [nvidia] mapping multiple BARs
Dec 18 22:13:42 fedora kernel: [drm] Initialized nvidia-drm 0.0.0 for 0000:01:00.0 on minor 1
Dec 18 22:13:42 fedora kernel: nvidia 0000:01:00.0: vgaarb: deactivate vga console
Dec 18 22:13:42 fedora kernel: fbcon: nvidia-drmdrmfb (fb0) is primary device
Dec 18 22:13:42 fedora kernel: nvidia 0000:01:00.0: [drm] fb0: nvidia-drmdrmfb frame buffer device
Dec 18 22:13:42 fedora systemd[1]: systemd-boot-clear-sysfail.service - Clear SysFail Entry If The Boot Is Successful was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/LoaderEntrySysFail-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f).
Dec 18 22:13:42 fedora audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=nvidia-powerd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 18 22:13:42 fedora systemd[1]: Started nvidia-powerd.service - nvidia-powerd service.
Dec 18 22:13:42 fedora nvidia-powerd[828]: nvidia-powerd version:2.0 (build 1)
Dec 18 22:13:42 fedora nvidia-powerd[828]: DBus Connection is established
Dec 18 22:13:42 fedora nvidia-powerd[828]: ERROR! Running on an unsupported system (PCI device Id: 0x2504)
Dec 18 22:13:42 fedora nvidia-powerd[828]: Quit successfully
Dec 18 22:13:42 fedora audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=nvidia-powerd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 18 22:13:42 fedora systemd[1]: nvidia-powerd.service: Deactivated successfully.
Dec 18 22:13:42 fedora systemd[1]: nvidia-fallback.service - Fallback to nouveau as nvidia did not load was skipped because of an unmet condition check (ConditionPathExists=!/sys/module/nvidia).
Dec 18 22:13:43 fedora dbus-broker-launch[807]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Dec 18 22:13:43 fedora audit[1213]: AUDIT1103 pid=1213 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="sddm" exe="/usr/lib/systemd/systemd-executor" hostname=? addr=? terminal=? res=failed'
Dec 18 22:13:44 fedora wireplumber[1525]: wp-event-dispatcher: wp_event_dispatcher_unregister_hook: assertion 'already_registered_dispatcher == self' failed
Dec 18 22:13:44 fedora wireplumber[1525]: wp-event-dispatcher: <WpAsyncEventHook:0x5650664d9300> failed: failed to activate item: Object activation aborted: proxy destroyed
Dec 18 22:13:45 fedora sddm-greeter-qt6[1497]: QWaylandGLContext: Failed to create the decorations EGLContext. Decorations will not be drawn.
Dec 18 22:13:45 fedora sddm-helper-start-wayland[1484]: "QSGContext::initialize: depth buffer support missing, expect rendering errors\nQSGContext::initialize: stencil buffer support missing, expect rendering errors\n"
Dec 18 22:13:53 fedora unix_chkpwd[1689]: password check failed for user (will)
Dec 18 22:13:53 fedora sddm-helper[1687]: pam_unix(sddm:auth): authentication failure; logname= uid=0 euid=0 tty= ruser= rhost= user=will
Dec 18 22:13:53 fedora audit[1687]: AUDIT1100 pid=1687 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=? acct="will" exe="/usr/libexec/sddm-helper" hostname=? addr=? terminal=? res=failed'
Dec 18 22:13:55 fedora sddm-helper[1687]: [PAM] authenticate: Authentication failure
Dec 18 22:13:55 fedora sddm[1119]: Authentication error: SDDM::Auth::ERROR_AUTHENTICATION "Authentication failure"
Dec 18 22:13:59 fedora audit[1700]: AUDIT1103 pid=1700 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="will" exe="/usr/lib/systemd/systemd-executor" hostname=? addr=? terminal=? res=failed'
Dec 18 22:13:59 fedora sddm-helper-start-wayland[1484]: "kwin_wayland_drm: atomic commit failed: Permission denied\n"
