Desktop Freezes Requires Hard Reboot Fedora 41 Asus Zephyrus nvidia 4070
Basically renders the computer useless - after around 45min I will have to hard reset
https://paste.centos.org/view/raw/8b558b1c
inxi -Fzxx
System:
  Kernel: 6.12.11-200.fc41.x86_64 arch: x86_64 bits: 64 compiler: gcc
    v: 14.2.1
  Desktop: KDE Plasma v: 6.3.0 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
    Distro: Fedora Linux 41 (KDE Plasma)
Machine:
  Type: Laptop System: ASUSTeK product: ROG Zephyrus G16 GA605WI_GA605WI
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: GA605WI v: 1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: GA605WI.306 date: 08/01/2024
Battery:
  ID-1: BAT1 charge: 68.5 Wh (81.5%) condition: 84.1/89.8 Wh (93.6%)
    volts: 15.7 min: 15.9 model: ASUS A32-K55 serial: N/A status: discharging
CPU:
  Info: 12-core model: AMD Ryzen AI 9 HX 370 w/ Radeon 890M bits: 64
    type: MT MCP arch: N/A rev: 0 cache: L1: 960 KiB L2: 12 MiB L3: 24 MiB
  Speed (MHz): avg: 599 min/max: 599/4367 boost: enabled cores: 1: 599
    2: 599 3: 599 4: 599 5: 599 6: 599 7: 599 8: 599 9: 599 10: 599 11: 599
    12: 599 13: 599 14: 599 15: 599 16: 599 17: 599 18: 599 19: 599 20: 599
    21: 599 22: 599 23: 599 24: 599 bogomips: 95823
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Graphics:
  Device-1: NVIDIA AD106M [GeForce RTX 4070 Max-Q / Mobile] vendor: ASUSTeK
    driver: nvidia v: 565.77 arch: Lovelace pcie: speed: 2.5 GT/s lanes: 8
    ports: active: none off: HDMI-A-1 empty: DP-9,eDP-2 bus-ID: 64:00.0
    chip-ID: 10de:2860
  Device-2: Advanced Micro Devices [AMD/ATI] Strix [Radeon 880M / 890M]
    vendor: ASUSTeK driver: amdgpu v: kernel pcie: speed: 16 GT/s lanes: 16
    ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, DP-7,
    DP-8, Writeback-1 bus-ID: 65:00.0 chip-ID: 1002:150e temp: 38.0 C
  Device-3: Shinetech USB2.0 FHD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-1:2 chip-ID: 3277:0051
  Display: wayland server: Xwayland v: 24.1.5 compositor: kwin_wayland
    driver: gpu: amdgpu,nvidia,nvidia-nvswitch d-rect: 4480x1600 display-ID: 0
  Monitor-1: HDMI-A-1 pos: primary,left model: LG (GoldStar) FULL HD
    res: 1920x1080 hz: 75 dpi: 102 diag: 551mm (21.7")
  Monitor-2: eDP-1 pos: right model: Samsung ATNA60DL04-0 res: 2560x1600
    hz: 240 dpi: 191 diag: 405mm (15.94")
  API: EGL v: 1.5 platforms: device: 0 drv: nvidia device: 1 drv: radeonsi
    gbm: drv: kms_swrast surfaceless: drv: nvidia wayland: drv: radeonsi x11:
    drv: radeonsi
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.3.4 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon Graphics (radeonsi gfx1150 LLVM
    19.1.0 DRM 3.59 6.12.11-200.fc41.x86_64) device-ID: 1002:150e
    display-ID: :0.0
  API: Vulkan v: 1.4.304 surfaces: xcb,xlib,wayland device: 0
    type: integrated-gpu driver: N/A device-ID: 1002:150e device: 1
    type: discrete-gpu driver: N/A device-ID: 10de:2860 device: 2 type: cpu
    driver: N/A device-ID: 10005:0000
  Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo
    de: kscreen-console,kscreen-doctor gpu: nvidia-settings,nvidia-smi
    wl: wayland-info x11: xdriinfo, xdpyinfo, xprop, xrandr
Audio:
  Device-1: NVIDIA AD106M High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 8
    bus-ID: 64:00.1 chip-ID: 10de:22bd
  Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
    Definition Audio driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s
    lanes: 16 bus-ID: 65:00.1 chip-ID: 1002:1640
  Device-3: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
    driver: snd_acp_pci v: kernel pcie: speed: 16 GT/s lanes: 16 bus-ID: 65:00.5
    chip-ID: 1022:15e2
  Device-4: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s
    lanes: 16 bus-ID: 65:00.6 chip-ID: 1022:15e3
  Device-5: Walmart AB13X Headset Adapter
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 bus-ID: 3-1.2:6 chip-ID: 001f:0b21
  API: ALSA v: k6.12.11-200.fc41.x86_64 status: kernel-api
  Server-1: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
    status: active 2: wireplumber status: active 3: pipewire-alsa type: plugin
    4: pw-jack type: plugin
Network:
  Device-1: MEDIATEK vendor: Foxconn driver: mt7925e v: kernel pcie:
    speed: 5 GT/s lanes: 1 port: N/A bus-ID: 63:00.0 chip-ID: 14c3:7925
  IF: wlp99s0 state: up mac: <filter>
Bluetooth:
  Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 bus-ID: 3-3:3 chip-ID: 0489:e11e
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.4
    lmp-v: 13
Drives:
  Local Storage: total: 1.86 TiB used: 36.07 GiB (1.9%)
  ID-1: /dev/nvme0n1 vendor: Micron model: MTFDKBA2T0QFM-1BD1AABGB
    size: 1.86 TiB speed: 63.2 Gb/s lanes: 4 serial: <filter> temp: 25.9 C
Partition:
  ID-1: / size: 1.85 TiB used: 35.46 GiB (1.9%) fs: btrfs dev: /dev/nvme0n1p3
  ID-2: /boot size: 7.78 GiB used: 604.7 MiB (7.6%) fs: ext4
    dev: /dev/nvme0n1p2
  ID-3: /boot/efi size: 2 GiB used: 19.3 MiB (0.9%) fs: vfat
    dev: /dev/nvme0n1p1
  ID-4: /home size: 1.85 TiB used: 35.46 GiB (1.9%) fs: btrfs
    dev: /dev/nvme0n1p3
Swap:
  ID-1: swap-1 type: zram size: 8 GiB used: 0 KiB (0.0%) priority: 100
    dev: /dev/zram0
Sensors:
  System Temperatures: cpu: 46.9 C mobo: N/A
  Fan Speeds (rpm): cpu: 2300
Info:
  Memory: total: 32 GiB note: est. available: 30.46 GiB used: 6.05 GiB (19.9%)
  Processes: 1210 Power: uptime: 12m wakeups: 0 Init: systemd v: 256
    target: graphical (5) default: graphical
  Packages: pm: rpm pkgs: N/A note: see --rpm pm: flatpak pkgs: 24
    Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.32 running-in: konsole
    inxi: 3.3.37
[   28.127226] amdgpu 0000:65:00.0: [drm] REG_WAIT timeout 1us * 10 tries - optc3_lock line:128
[   28.243636] systemd-journald[897]: File /var/log/journal/b97d1342c60445eb935c0d09fbf9eb58/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[   69.517540] amdgpu 0000:65:00.0: [drm] REG_WAIT timeout 1us * 10 tries - optc3_lock line:128
[  153.011620] amdgpu 0000:65:00.0: [drm] REG_WAIT timeout 1us * 10 tries - optc3_lock line:128
[  162.013245] amdgpu 0000:65:00.0: [drm] REG_WAIT timeout 1us * 10 tries - optc3_lock line:128
[  176.514605] amdgpu 0000:65:00.0: [drm] REG_WAIT timeout 1us * 10 tries - optc3_lock line:128
[  338.458935] amdgpu 0000:65:00.0: [drm] REG_WAIT timeout 1us * 10 tries - optc3_lock line:128
[  577.877193] amdgpu 0000:65:00.0: [drm] REG_WAIT timeout 1us * 10 tries - optc3_lock line:128
[  613.977539] show_signal_msg: 112 callbacks suppressed
[  613.977546] eglinfo[6892]: segfault at 8 ip 00007f2732628fcf sp 00007fff62f01c40 error 4 in libgallium-24.3.4.so[28fcf,7f2732601000+1a49000] likely on CPU 22 (core 14, socket 0)
[  613.977561] Code: 48 89 e5 41 56 41 55 41 54 41 89 f4 53 4c 8b 6f 58 48 89 fb 0f b6 05 01 9a a3 02 84 c0 0f 84 98 00 00 00 0f b6 05 f1 99 a3 02 <41> 83 7d 08 03 4c 8d 35 05 df 90 02 88 83 68 01 00 00 7e 0e 49 83
[  676.590932] apple-mfi-fastcharge 7-1: USB disconnect, device number 2
[  676.616261] ipheth 7-1:4.2: Apple iPhone USB Ethernet now disconnected
[  740.145322] eglinfo[7488]: segfault at 8 ip 00007ff151428fcf sp 00007ffeb1c36960 error 4 in libgallium-24.3.4.so[28fcf,7ff151401000+1a49000] likely on CPU 17 (core 9, socket 0)
[  740.145348] Code: 48 89 e5 41 56 41 55 41 54 41 89 f4 53 4c 8b 6f 58 48 89 fb 0f b6 05 01 9a a3 02 84 c0 0f 84 98 00 00 00 0f b6 05 f1 99 a3 02 <41> 83 7d 08 03 4c 8d 35 05 df 90 02 88 83 68 01 00 00 7e 0e 49 83
Any guidance would be greatly appreciated.
Fedora 41 + XFCE user here.
I’m 99.99% sure that this is because of the xorg-x11-server-Xwayland 24.1.5 update.
After updating, wine applications broke for me with memory errors and my desktop froze.
Tried multiple reboots, got the same results, thus I did a downgrade:
sudo dnf downgrade xorg-x11-server-Xwayland
After that & rebooting, everything works fine now.
The package is on 24.1.3 version now here, no issues at all.
Take care!
Spec: Fedora41+XFCE, Kernel 6.12.13, GF1050Ti drv 565.77
Attaching nvidia-bug-report.log.gz would definitely increase chances of someone ever looking into this ;-) Cheers!
Sorry - here you go.
nvidia-bug-report.log.gz (1.3 MB)
