I am building the kernel with CONFIG_LOCKDEP=y and I see below two lockdep messages which I think are bugs. Please let me know how to fix those:
- Error in {NVIDIA_L4T_KERNEL}/nvidia/drivers/video/tegra/fb.c
[ 2.214561] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 2.216490] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 2.217986] =============================================
[ 2.218019] [ INFO: possible recursive locking detected ]
[ 2.218100] 4.9.108 #1 Not tainted
[ 2.218127] ---------------------------------------------
[ 2.218160] kworker/4:1/59 is trying to acquire lock:
[ 2.218388] ((fb_notifier_list).rwsem){.+.+.+}, at: [<ffffff80080d1258>] __blocking_notifier_call_chain+0x38/0x78
[ 2.218414]
but task is already holding lock:
[ 2.218431] ((fb_notifier_list).rwsem){.+.+.+}, at: [<ffffff80080d1258>] __blocking_notifier_call_chain+0x38/0x78
[ 2.218435]
other info that might help us debug this:
[ 2.218440] Possible unsafe locking scenario:
[ 2.218441] CPU0
[ 2.218444] ----
[ 2.218470] lock((fb_notifier_list).rwsem);
[ 2.218475] lock((fb_notifier_list).rwsem);
[ 2.218480]
*** DEADLOCK ***
[ 2.218482] May be due to missing lock nesting notation
[ 2.218489] 6 locks held by kworker/4:1/59:
[ 2.218512] #0: ("events"){.+.+.+}, at: [<ffffff80080c768c>] process_one_work+0x1ec/0x750
[ 2.218648] #1: ((&(&hdmi->hpd_worker)->work)){+.+.+.}, at: [<ffffff80080c768c>] process_one_work+0x1ec/0x750
[ 2.218680] #2: (&hdmi->hpd_lock){+.+.+.}, at: [<ffffff80086810a0>] tegra_hdmi_hpd_worker+0x50/0x368
[ 2.218710] #3: (console_lock){+.+.+.}, at: [<ffffff80086e9a0c>] tegra_fb_update_monspecs+0x44/0x268
[ 2.218737] #4: (&fb_info->lock){+.+.+.}, at: [<ffffff8008537240>] lock_fb_info+0x20/0x50
[ 2.218753] #5: ((fb_notifier_list).rwsem){.+.+.+}, at: [<ffffff80080d1258>] __blocking_notifier_call_chain+0x38/0x78
[ 2.218755]
stack backtrace:
[ 2.218786] CPU: 4 PID: 59 Comm: kworker/4:1 Not tainted 4.9.108 #1
[ 2.218788] Hardware name: jetson-xavier (DT)
[ 2.218827] Workqueue: events tegra_hdmi_hpd_worker
[ 2.218832] Call trace:
[ 2.218857] [<ffffff800808a6e8>] dump_backtrace+0x0/0x1a8
[ 2.218863] [<ffffff800808a8f4>] show_stack+0x14/0x20
[ 2.218883] [<ffffff800849897c>] dump_stack+0x9c/0xd0
[ 2.218903] [<ffffff8008113740>] validate_chain.isra.22+0xb18/0xc60
[ 2.218909] [<ffffff8008114c54>] __lock_acquire+0x374/0x728
[ 2.218913] [<ffffff80081155a4>] lock_acquire+0xd4/0x298
[ 2.218937] [<ffffff8008e10e74>] down_read+0x3c/0xc8
[ 2.219005] [<ffffff80080d1258>] __blocking_notifier_call_chain+0x38/0x78
[ 2.219010] [<ffffff80080d12ac>] blocking_notifier_call_chain+0x14/0x20
[ 2.219014] [<ffffff8008536e3c>] fb_notifier_call_chain+0x1c/0x28
[ 2.219018] [<ffffff80085372e0>] fb_blank+0x50/0xd0
[ 2.219035] [<ffffff8008530168>] fbcon_blank+0x278/0x2c0
[ 2.219053] [<ffffff8008741a6c>] do_blank_screen+0x184/0x208
[ 2.219059] [<ffffff800853228c>] fbcon_event_notify+0x94c/0x958
[ 2.219066] [<ffffff80080d0df8>] notifier_call_chain+0x50/0x90
[ 2.219070] [<ffffff80080d1270>] __blocking_notifier_call_chain+0x50/0x78
[ 2.219075] [<ffffff80080d12ac>] blocking_notifier_call_chain+0x14/0x20
[ 2.219079] [<ffffff8008536e3c>] fb_notifier_call_chain+0x1c/0x28
[ 2.219083] [<ffffff800853734c>] fb_blank+0xbc/0xd0
[ 2.219088] [<ffffff80086e9954>] tegra_fbcon_set_fb_mode+0x3c/0xb0
[ 2.219093] [<ffffff80086e9be4>] tegra_fb_update_monspecs+0x21c/0x268
[ 2.219144] [<ffffff800867c15c>] tegra_hdmi_hotplug_notify+0xa4/0xb8
[ 2.219150] [<ffffff800867f1bc>] tegra_hdmi_edid_eld_setup+0x15c/0x240
[ 2.219155] [<ffffff8008681210>] tegra_hdmi_hpd_worker+0x1c0/0x368
[ 2.219161] [<ffffff80080c772c>] process_one_work+0x28c/0x750
[ 2.219168] [<ffffff80080c7c40>] worker_thread+0x50/0x4c8
[ 2.219176] [<ffffff80080cef24>] kthread+0xf4/0x108
[ 2.219182] [<ffffff80080830d0>] ret_from_fork+0x10/0x40
[ 2.220182] tegradc 15200000.nvdisplay: blank - normal
[ 2.262425] tegradc 15200000.nvdisplay: unblank
[ 2.267076] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
I was able to get past this by replacing the function call to fb_blank() with tegra_fb_blank(). But I am unsure if this is the right thing to do. I verified that the monitor over HDMI cable turns on and off as expected, but this test may not be enough.
- “BUG:” messages when running nvpmodel_clk_cap_init().
[ 8.649787] t19x_cache tegra-cache: probed
[ 8.658921] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 8.660639] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 8.668504] tegra_hv: get_hvd: not initialized yet
[ 8.672868] user_ivc_mempool: hypervisor not present
[ 8.678805] BUG: key ffffffc3e6f97818 not in .data!
[ 8.682690] BUG: key ffffffc3e6f97850 not in .data!
[ 8.688248] BUG: key ffffffc3e6f97888 not in .data!
[ 8.692348] BUG: key ffffffc3e6f978c0 not in .data!
[ 8.697595] BUG: key ffffffc3e6f978f8 not in .data!
[ 8.702342] BUG: key ffffffc3e6f97930 not in .data!
[ 8.707788] BUG: key ffffffc3e6f97968 not in .data!
[ 8.712479] BUG: key ffffffc3e6f979a0 not in .data!
[ 8.717317] BUG: key ffffffc3e6f979d8 not in .data!
[ 8.722167] BUG: key ffffffc3e6f97a10 not in .data!
[ 8.727750] BUG: key ffffffc3e6f97a48 not in .data!
[ 8.732231] BUG: key ffffffc3e6f97a80 not in .data!
[ 8.737120] BUG: key ffffffc3e6f97ab8 not in .data!
[ 8.741926] BUG: key ffffffc3e6f97af0 not in .data!
[ 8.747629] BUG: key ffffffc3e6f97b28 not in .data!
[ 8.751530] nvpmodel: initialized successfully
[ 8.756234] GACT probability NOT on
Please let me know how to fix these messages.
