I’ve received a bug report from a user. He’s running my code on 64 bit Windows 7 with Cuda 4.0, driver 275.33, and a Quadro FX 380M (which supports compute level 1.2). The kernel compiler fails with the following log:
ptxas application ptx input, line 128; error : Instruction 'cvt' requires SM 1.3 or higher, or map_f64_to_f32 directive
ptxas application ptx input, line 129; error : Instruction 'mov' requires SM 1.3 or higher, or map_f64_to_f32 directive
ptxas application ptx input, line 130; error : Instruction 'div' requires SM 1.3 or higher, or map_f64_to_f32 directive
ptxas application ptx input, line 163; error : Instruction 'cvt' requires SM 1.3 or higher, or map_f64_to_f32 directive
ptxas application ptx input, line 164; error : Instruction 'cvt' requires SM 1.3 or higher, or map_f64_to_f32 directive
ptxas application ptx input, line 165; error : Instruction 'cvt' requires SM 1.3 or higher, or map_f64_to_f32 directive
ptxas application ptx input, line 166; error : Instruction 'cvt' requires SM 1.3 or higher, or map_f64_to_f32 directive
ptxas application ptx input, line 167; error : Instruction 'mul' requires SM 1.3 or higher, or map_f64_to_f32 directive
ptxas application ptx input, line 168; error : Instruction 'mul' requires SM 1.3 or higher, or map_f64_to_f32 directive
ptxas application ptx input, line 169; error : Instruction 'mul' requires SM 1.3 or higher, or map_f64_to_f32 directive
ptxas application ptx input, line 170; error : Instruction 'mul' requires SM 1.3 or higher, or map_f64_to_f32 directive
ptxas application ptx input, line 178; error : Instruction 'cvt' requires SM 1.3 or higher, or map_f64_to_f32 directive
ptxas application ptx input, line 179; error : Instruction 'cvt' requires SM 1.3 or higher, or map_f64_to_f32 directive
ptxas application ptx input, line 180; error : Instruction 'cvt' requires SM 1.3 or higher, or map_f64_to_f32 directive
ptxas fatal : Ptx assembly aborted due to errors
ptxas application ptx input, line 128; warning : Double is not supported. Demoting to float
It looks like the compiler is getting confused and generating 1.3 instructions on a device that only supports 1.2. It clearly realizes it shouldn’t do that, as seen from the last line: “Double is not supported. Demoting to float” But it does it anyway.
Has anyone seen anything like this before? Any idea what I can do about it?
Peter
