I’ve been experiencing a rendering issue in multiple Proton games on Linux where the game will randomly freeze visually during gameplay. I believe this is a regression with the RTX 50-series linux drivers, as this issue is only present on these cards.
System Information
Distribution: CachyOS (fully up to date)
Desktop Environment: KDE Plasma (KWin)
Session: Wayland
Kernel: 7.1.2-2-cachyos
GPU: NVIDIA GeForce RTX 5070 Ti
CPU: AMD Ryzen 7 7800x3D
Driver: 610.43.02 (Open Kernel Modules)
OpenGL: 4.6.0 NVIDIA 610.43.02
Vulkan Instance: 1.4.350
Vulkan Driver: 610.43.02
Symptoms
At seemingly random points while playing:
The game display freezes completely.
Audio that is already playing continues (e.g. background music), but no new audio appears to play after the freeze (e.g sound effects, voice lines).
GPU utilization drops to 0% while the game is frozen.
The rest of the desktop remains fully responsive.
Alt+Tabbing away from the game and then back (or refocusing with the meta key) immediately restores rendering, and the game continues from the state it would’ve been in (i.e. implying the game is still running and progressing, but just not rendering)
Because the game resumes immediately after refocusing the window, it appears the game itself continues running while presentation/rendering stops.
I have not found a reliable way to reproduce the issue. It appears to happen randomly, although I suspect GPU load spikes may increase the likelihood, possibly shader compilation contributes, as it tends to happen early into my playtime, except FFXIV, which happens constantly, possibly due to its large scope. This does not affect all games, many games I have gone 20+ hours with no issues
Affected games
So far I’ve observed this in:
Final Fantasy XIV (DX11) ← Constantly happens, on average every hour or so.
Warframe (DX11) ← Only happened once 30 minutes after I started for the first time
Satisfactory (DX11) ← Happened roughly 3 times across 3 hours, hasn’t happened 10 hours later
Proton versions tested
Proton 11
Proton Experimental
Proton GE 10-34
proton-cachyos-11.0-20260601
Troubleshooting
I’ve tried:
Running the games through Gamescope.
Multiple Proton versions (listed above).
Booting the LTS kernel.
Running with the latest updates.
Using Wayland mode on supported proton versions
None of these changed the behavior.
Additional observations
No relevant messages appear in dmesg or the system journal when the freeze occurs.
I’ve spoken with several other Linux users who have reported similar symptoms, and all of them were using RTX 50-series GPUs.
If there are any additional logs, debug options, or tests that would help narrow this down, I’d be happy to collect them. If anyone else has seen this issue too, please share, maybe we can figure out what’s up. Thanks!
Oh wow, I was just thinking about making a nearly identical post yesterday, but didn’t when I found this github post. The title lists the 5090 but I’m reasonably certain it’s all 5000 series cards. Was hoping maybe I’d find more information today when I found your post, but I’m starting to think I will not have answers anytime soon.
I can say that I have tried most of the same stuff as you, all symptoms being identical. Games I’ve experienced freezing in are Warframe (DX12) and Orcs Must Die: Deathtrap; and mostly using Proton 11; Proton GE 11-1; Proton 10; and Proton GE 10-34. Weirdly it doesn’t freeze at all in Monster Hunter Wilds. I’ve even tried starting steam in a gamescope session and then launching the games that way instead of using a DE, but the games still freeze.
My wife and I run RTX 5070’s and both have these issues. She has an AMD Processor on CachyOS with KDE; I’ve got an older Intel Processor on Arch with Gnome and it makes no difference.
Same issue with RTX 5080.
I have such problem with World of Warcraft, Space Marine 2 and the new Iron Nest. Especially the last title freezes a lot… I use mostly Proton-CachyOS, tested also with GE and Experimental.
Would be nice to see any reaction of Nvidia to this report. Problem occurs for over a year and it’s extremely frustrating when game freezes in the worst possible moment.
EDIT: Here is a fresh log from my short World of Warcraft session, when game’s window got a freeze at least 4 times.
Symptoms match the original report exactly: rendering freezes at random, audio and game state keep progressing, the desktop stays fully responsive, and Alt+Tab away and back restores rendering instantly.
Switching from exclusive fullscreen to borderless windowed made no difference.
Note that my driver is 610.57.04 while the original report is on 610.43.02, so the bug is not specific to one point release within the 610 branch.
Can confirm that I have the same issue happening from time to time while playing games via Steam Proton.
My setup is:
Arch Linux (Linux 7.1.10-arch1-1)
GNOME 50 (Wayland)
5070Ti (610.57.04 open kernel modules)
Ryzen 9800x3d
Worth noticing that not every single game is affected but there are some like:
Helldivers 2
Cyberpunk 2077
Control
Also, it might be just me but I feel like it stopped happening as often as it used to comparing to the previous driver versions (590, 595). I remember someone mentioned that it affects only Linux systems running a combination of AMD Ryzen CPUs and NVIDIA cards (Zen 4,5 + Blackwell, not sure about that though).
Anyway, the issues has been present for quite a while now and has been mentioned by different folks in dedicated driver threads many times now, would be nice to have it resolved eventually :)
Confirming this issue on Fedora 44 / KDE Wayland with an RTX 5070 Ti.
System:
RTX 5070 Ti
NVIDIA 610.57.04
KWin 6.7.4
Xwayland 24.1.13
Kernel 7.1.10-200.fc44.x86_64
I’m seeing this in Final Fantasy VII Remake under Proton. The game will visually freeze while audio continues; the game itself also appears paused rather than continuing invisibly in the background.
Normally the freeze lasts a second or two, but today I’ve seen repeated freezes lasting 15–20 seconds in both combat and cutscenes.
Pressing the Meta key to open the Plasma application launcher immediately resumes rendering every time.
I checked both the kernel journal and user journal after reproducing it and there were no relevant NVIDIA/KWin/DRM/Xid messages logged during the freeze.
I can confirm that I am experiencing the same issue, specifically with Hogwarts Legacy, and I can reproduce the characteristic behavior described in this thread.
The game randomly freezes during gameplay. The behavior is very distinctive:
The game becomes completely unresponsive.
The desktop itself remains responsive.
Pressing Alt+Tab immediately restores the game.
Pressing the Meta/Windows key also restores the game.
Pressing PrintScreen has also restored the game.
After the window/focus change, the game continues normally.
There is no game crash and I do not have to restart it.
The issue is intermittent rather than occurring at a specific location or action in the game.
I have also checked the kernel journal after reproducing the issue. I did not find NVIDIA Xid, NVRM, DRM, GPU, GSP, PCIe or AER errors associated with the freeze.
I tested the following without eliminating the problem:
Proton Experimental
Proton 9.0-4
Borderless Windowed
VRR disabled
Gamescope
Different FPS limits
Steam Overlay enabled/disabled
VKD3D_SHADER_CACHE_PATH=0
VKD3D_CONFIG=no_upload_hvv
VKD3D_CONFIG=single_queue
VKD3D_CONFIG=swapchain_legacy
disabling VK_KHR_present_wait
VKD3D_SWAPCHAIN_PRESENT_MODE=FIFO
VKD3D_SWAPCHAIN_PRESENT_MODE=IMMEDIATE
PROTON_HIDE_NVIDIA_GPU=1
None of these tests eliminated the freezing.
One additional observation: this does not appear to be a general system-wide instability. For example, I have also been playing Gothic 1 Remake on the same system without experiencing this particular freezing behavior.
I am reporting this because the behavior appears very similar to the other RTX 50-series reports in this thread, especially the fact that changing the window focus with Alt+Tab/Meta immediately restores rendering.
Adding a data point to this thread, since my setup differs from most reports here (X11/Cinnamon rather than Wayland/KDE), and I’ve been able to rule out several other variables.
System:
Distro: Linux Mint 22.3 (Cinnamon, X11 — not Wayland)
Kernel: 7.0.0-30-generic (Ubuntu 24.04 base)
GPU: RTX 5070 (Blackwell)
Driver: 580.173.02, NVIDIA open kernel modules
CPU: AMD Ryzen 9 9900X
Symptoms (identical to others in this thread):
Game display freezes completely during normal gameplay
Audio already playing continues; no new audio events after the freeze
GPU utilization drops to 0% while frozen
Desktop compositor and rest of system remain fully responsive
Nothing relevant in dmesg or journalctl -k at the time of the freeze — checked specifically for NVRM/Xid entries, found none in the same boot session as the freeze
Games affected: The Elder Scrolls Online (Proton, GE-Proton10-34) and Wreckfest. Happens after extended play sessions rather than immediately on launch.
Variables ruled out before posting:
Proton version — already on GE-Proton10-34, which others in this thread report as freeze-free
ESO’s known Electron-launcher background lag issue — added the standard launch option to force-kill CrBrowserMain after startup; freeze still occurred
Thermal/power throttling — GPU temps normal (46°C) at the time of testing
USB/peripheral errors — only unrelated, harmless USB enumeration errors present in the boot log
Recovery: Alt+Tab, Meta key, and PrintScreen — all reported elsewhere in this thread as sometimes restoring rendering — did not recover the frozen game in my case. Had to force-quit via Steam’s “not responding” dialog.
Wanted to flag the X11 case specifically, since it suggests this isn’t compositor- or Wayland-specific, and the multi-game reproduction (ESO + Wreckfest, both via Proton) plus the “no Xid logged” pattern matches what’s already been reported here. Happy to grab any additional logs if there’s something specific that would help — let me know what to capture next time it happens.
Unfortunately, it’s been going on for over a year, despite Nvidia acknowledging the problem and people providing boatloads of very detailed debug info (see aforementioned GitHub issue).
I’m glad people are still bringing it up though. They literally just stopped responding on the GitHub thread.
Workaround: NVPRESENT_ENABLE_SMOOTH_MOTION=1 in launch options
Setting this env var (e.g. NVPRESENT_ENABLE_SMOOTH_MOTION=1 %command% in Steam) seems to eliminate the freezing entirely on my RTX 5080. It enables NVIDIA’s Smooth Motion Vulkan layer (VK_LAYER_NV_present), which takes over frame presentation from the game/DXVK/VKD3D-Proton and, by default, presents from a separate asynchronous compute queue instead of the game’s normal present path.
My guess is that the freeze is a stall somewhere in the standard Vulkan present/swapchain path on Blackwell, one that a window focus event happens to kick loose. Forcing presentation through this alternate layer/queue seems to route around whatever’s stalling, rather than fixing the underlying cause. Posting this in case it helps others narrow down where the actual bug lives, since it points pretty specifically at the present/swapchain handoff rather than rendering or the game engine itself.
User KartikKawalia has posted a possible solution on Github.
“ok i think i have found a permanent solution to this issue. i turned off vfr variable frame rate (not variable refresh rate which is vrr) and the problem is solved. with vfr on the system tries to save resources and stops send frames to the display which causes the game to freeze that is why opening the twitch stream and chat on the side solved the problem. it keeps forcing wayland to stay active all the time hence no freezes and stutters. i am testing this for like 1 hour and not a single freeze. letsgoooooooooooo. finally solved”.
