Bug using "continue" in shaders (minimum example code included)
Using the following GLSL Fragment Shader renders strange behaviour. The second continue is never executed - even if b is GL_TRUE. (This example is a reduced version of a bigger shader, that has some code inbetween both continues.)
Driver Version 335.23; GeForce GTX 660; Windows 8.1 64 bits
#version 330
out vec4 color;
uniform bool a;
uniform bool b;
void main() {
	for (int i = 0; i < 3; ++i) {
		// a = GL_TRUE and b = GL_TRUE
		// This does not work
		// THE TRIANGLE IS NOT DRAWN
		if (!a)
			continue;
		if (b)
			continue;
		// This works
		// THE TRIANGLE IS DRAWN
		//if (!a || b)
		//	continue;
		discard;
	color = vec4(1.0, 0.0, 0.0, 1.0);
For completeness, I use the following vertex shader:
#version 330
in vec2 coords;
void main() {
	gl_Position = vec4(coords, 0.0, 1.0);
and this C++ code (using SDL2 and glLoadGen) to execute the program:
#include "gl_core_4_4.h"
#include <cstdlib>
#include <SDL.h>
#include <string>
#include <fstream>
#include <sstream>
#include <memory>
static GLint compileShader(const std::string &path, GLenum shaderType) {
	auto shader = glCreateShader(shaderType);
	std::ifstream in;
	std::string line;
	std::ostringstream shaderSourceStream;
	in.open(path);
	while (in.good()) {
		std::getline(in, line);
		shaderSourceStream << line << "\n";
	in.close();
	std::string shaderSource = shaderSourceStream.str();
	const char * shaderCStr = shaderSource.c_str();
	glShaderSource(shader, 1, &shaderCStr, nullptr);
	glCompileShader(shader);
	GLint infoLogLength;
	glGetShaderiv(shader, GL_INFO_LOG_LENGTH, &infoLogLength);
	if (infoLogLength) {
		auto infoLogCStr = std::unique_ptr<GLchar[]>(new GLchar[infoLogLength]);
		glGetShaderInfoLog(shader, infoLogLength, nullptr, infoLogCStr.get());
	GLint status;
	glGetShaderiv(shader, GL_COMPILE_STATUS, &status);
	if (status != GL_TRUE) {
		throw std::string("GL_COMPILE_STATUS for shader is not GL_TRUE: " + path);
	return shader;
int main(int, char*[]) {
	SDL_GL_SetAttribute(SDL_GL_CONTEXT_MAJOR_VERSION, 3);
	SDL_GL_SetAttribute(SDL_GL_CONTEXT_MINOR_VERSION, 3);
	auto window = SDL_CreateWindow(
		"Test",
		SDL_WINDOWPOS_CENTERED, SDL_WINDOWPOS_CENTERED,
		1024, 768,
		SDL_WINDOW_OPENGL);
	auto context = SDL_GL_CreateContext(window);
	ogl_LoadFunctions();
	auto v = compileShader("vert.glsl", GL_VERTEX_SHADER);
	auto f = compileShader("frag.glsl", GL_FRAGMENT_SHADER);
	auto prog = glCreateProgram();
	glAttachShader(prog, v);
	glAttachShader(prog, f);
	glLinkProgram(prog);
	glUseProgram(prog);
	GLint status;
	glGetProgramiv(prog, GL_LINK_STATUS, &status);
		throw std::string("...");
	glClearColor(1.0f, 1.0f, 1.0f, 1.0f);
	const float coords[] = {-0.5f, -0.5f, 0.5f, -0.5f, 0.0f, 0.5f};
	GLuint buffer;
	glGenBuffers(1, &buffer);
	glBindBuffer(GL_ARRAY_BUFFER, buffer);
	glBufferData(GL_ARRAY_BUFFER, sizeof(coords), coords, GL_STATIC_DRAW);
	GLuint vao;
	glGenVertexArrays(1, &vao);
	glBindVertexArray(vao);
	glEnableVertexAttribArray(0);
	glVertexAttribPointer(0, 2, GL_FLOAT, GL_FALSE, 0, 0);
	glUniform1i(glGetUniformLocation(prog, "a"), GL_TRUE);
	glUniform1i(glGetUniformLocation(prog, "b"), GL_TRUE);
	SDL_Event e;
	for (;;) {
		glClear(GL_COLOR_BUFFER_BIT);
		glDrawArrays(GL_TRIANGLES, 0, 6);
		SDL_GL_SwapWindow(window);
		while (SDL_PollEvent(&e))
	return EXIT_SUCCESS;
Same case with me.
After update driver 337.88, this problem is encounted.
Could you please verify if the problem is still present in the available newer beta driver 340.43?
http://www.nvidia.com/Download/Find.aspx?lang=en-us
If yes, I’ll let the OpenGL driver team know. Thanks.
Same with me. Еncountered in 340.52 and in OpenGL 4.5 340.65 beta drivers.
I reported this issue with a bug tracking ticket way back in January of 2014.
It began with the driver version released that late Dec/13 or Jan/14
When I inquired about the fix a few times they just said maybe the next driver. never fixed.
I worked around this issue with an if statement and moved-on …
I was and am kind of stunned really, that they appear not to care.
