I have shader code that seems work on Intel GPUs and legacy NVidia cards up to 1080 but fails to bind after succesfully linking on the RTX4080. The same shader works as expected using GLFW3 on all cards.
I am using glad to load the OpenGL (4.5) and WGL symbols. Windows OS Pro 10-64bit. Have tried using the latest NVidia stable drivers as well as ones released earlier this year.
The shader program compiles and links fine:
static const char* vs_source[] = { R"_(
#version 450 core
uniform highp mat4 projection;
out vec2 texCoord;
void main(void)
// using GL_TRIANGLE_FAN
mat4 vertices = {
{-1.0, -1.0, 0.0, 1},
{-1.0, 1.0, 0.0, 1},
{ 1.0, 1.0, 0.0, 1},
{ 1.0, -1.0, 0.0, 1},
mat4x2 texCoords = {
{0.,0.},
{0.,1.},
{1.,1.},
{1.,0.}
texCoord = texCoords[gl_VertexID];
gl_Position = projection * vertices[gl_VertexID];
//gl_Position = vertices[gl_VertexID];
)_" };
static const char* fs_source[] = { R"(
#version 450 core
uniform float zoom;
uniform vec2 corner;
uniform lowp vec2 contrast_range;
layout (binding = 0) uniform sampler2D image;
layout (binding = 1) uniform sampler1D offsets;
layout (binding = 2) uniform sampler2D colormap;
in vec2 texCoord;
ivec2 getSampleCoordinates(void)
ivec2 dimensions = textureSize(image, 0);
ivec2 coordinates = ivec2(texCoord.s * dimensions.x, texCoord.t * dimensions.y);
return coordinates;
void main(void)
vec4 color = texelFetch(image, getSampleCoordinates(), 0);
color.g = color.r;
color.b = color.r;
gl_FragColor = color;
// intialize
m_program = glCreateProgram();
GLuint fs = glCreateShader(GL_FRAGMENT_SHADER);
glShaderSource(fs, 1, fs_source, NULL);
glCompileShader(fs);
CHECK_ERRORS();
GLuint vs = glCreateShader(GL_VERTEX_SHADER);
glShaderSource(vs, 1, vs_source, NULL);
glCompileShader(vs);
CHECK_ERRORS();
glAttachShader(m_program, vs);
glAttachShader(m_program, fs);
glLinkProgram(m_program);
CHECK_ERRORS();
The program fails on every draw command on the RTX4080
#define CHECK_ERRORS() { \
auto error = glGetError(); \
if (error != GL_NO_ERROR) \
stringstream ss; \
ss << __FUNCTION__ << "::" << __LINE__ << "::" << this_thread::get_id() << " OpenGL error: 0x" << std::hex << error; \
std::cerr << ss.str() << "\n"; \
void OpenGLView::OnPaint() {
// Do not call CWnd::OnPaint() for painting messages
if (!m_dirty && m_dirtyImage.empty()) return;
wglMakeCurrent(m_hdc, m_hRC);
////std::cerr << this_thread::get_id() << " - " << wglMakeCurrent(m_hdc, m_hRC) << "\n";
//CHECK_ERRORS();
glClearColor(0.0f, 0.05f, 0.8f, 1.0f);
CHECK_ERRORS();
glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
CHECK_ERRORS();
if (m_program == 0) return;
// FAILS HERE!!!!!!!!!!!!!!!!
glUseProgram(m_program);
CHECK_ERRORS();
// ERROR produces: OpenGLView::OnPaint::565::11716 OpenGL error: 0x502
// only on NVidia RTX4080
if (!m_dirtyImage.empty()) updateImage(m_dirtyImage);
CHECK_ERRORS();
SwapBuffers(m_hdc);
CHECK_ERRORS();
m_dirty = false;
glUseProgram(0);
//// Allow other rendering contexts to coexist
wglMakeCurrent(NULL, NULL);
ValidateRect(nullptr);
I have tried 3 different drivers, but all fail. CHECK_ERRORS only finds an error (see comment in code) when glUseProgram is called with the handle created by glCreateProgram.
The same approach works on RTX4080 if I use GLFW3 for the windows (i.e. same shader program works on GLFW3 but not on MFC).
I need MFC to support a legacy project. Can anyone help me figure out why this shader is failing to be activated on the 4080 and not on other models/platforms? Is there a deployment troubleshooting document? Does this indicate a bad board?
