Hello, I’m having problems with OpenGL in my system since I upgraded to 20.04 and installed an RTX 3070. I updated BIOS and chipset driver, as well as NVIDIA driver to the latest available with no success.
I’m trying KDE Plasma, and if I select OpenGL 2.0 or OpenGL 3.1 as Compositor, then the system lags A LOT in desktop effects (like desktop grid) or moving windows around. If I select XRender as compositor then everything works fine.
Also I tried to play Dota 2 on Steam (which uses OpenGL) and got 1-5 FPS, when before I was able to get 144FPS with a GTX970 and an older driver.
I attach the bug report and nvidia-smi output:
nvidia-smi
Thu Dec 3 13:57:28 2020
| NVIDIA-SMI 455.45.01 Driver Version: 455.45.01 CUDA Version: 11.1 |
| | | MIG M. |
| 0 GeForce RTX 3070 Off | 00000000:09:00.0 On | N/A |
| 0% 44C P8 21W / 220W | 210MiB / 7974MiB | 3% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1669 G /usr/lib/xorg/Xorg 208MiB |
Also glxinfo says I am not using NVIDIA to render OpenGL drivers. I saw another posts about this topic but I didn’t know how to apply the other answers to my case.
glxinfo | grep render
direct rendering: Yes
GLX_MESA_multithread_makecurrent, GLX_MESA_query_renderer,
GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer, GLX_MESA_query_renderer,
Extended renderer info (GLX_MESA_query_renderer):
OpenGL renderer string: llvmpipe (LLVM 10.0.0, 128 bits)
GL_ARB_conditional_render_inverted, GL_ARB_conservative_depth,
GL_MESA_ycbcr_texture, GL_NV_conditional_render, GL_NV_depth_clamp,
GL_NV_conditional_render, GL_NV_depth_clamp, GL_NV_fog_distance,
GL_EXT_polygon_offset_clamp, GL_EXT_read_format_bgra, GL_EXT_render_snorm,
GL_MESA_shader_integer_functions, GL_NV_conditional_render,
GL_OES_element_index_uint, GL_OES_fbo_render_mipmap,
Please help me to fix this. I am noob so if you need more information just tell me. Thanks in advanced for your time!
nvidia-bug-report.log.gz (1.1 MB)
