Dear team,
There are multiple problems which I am currently facing with the NVIDIA driver 470.141.03. Please find the details of nvidia-smi.
| NVIDIA-SMI 470.141.03 Driver Version: 470.141.03 CUDA Version: 11.4 |
| | | MIG M. |
| 0 NVIDIA GeForce … Off | 00000000:01:00.0 Off | N/A |
| 0% 37C P8 11W / 220W | 1MiB / 7982MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
Problems:
- The OpenGL version is 3.1 (OpenGL version string: 3.1 Mesa 20.0.8) and I want this to be updated to 3.3+. While my research I found that this come tightly coupled with nvidia graphics. I saw 3070 can have 4.6 OpenGL version but then why it shows v3.1 for OpenGL.
- What should be the kernel version to install nvidia-470.143.03 ?
- I have installed the nvidia driver-470 which is a recommended version and when trying to reboot the system, it gets stuck with error dev/nvme0n1p2 clean and gets stuck with some files and blocks getting cleared. I had to purge nvidia and then reboot the system. This happened for 1-2 times. I can access the main PC by remote but main screen of the PC still shows the nvm0n1p2 error.
- After some tries I managed to install 470 driver from “software and updates” but there are some commands which doesn’t work such as nvidia-settings etc. These checks I am performing through remote access as the main PC still shows the nvm0n1p2 error.
- Why it shows LLVM as Graphics and not nvidia.
- nvidia-settings return ERROR: Unable to load info from any available system. “(nvidia-settings:7293): GLib-GObject-CRITICAL **: 17:23:38.776: g_object_unref: assertion ‘G_IS_OBJECT (object)’ failed
** Message: 17:23:38.778: PRIME: No offloading required. Abort
** Message: 17:23:38.778: PRIME: is it supported? no”
***Specification
OS: ubuntu 18.04.6 LTS
Processor: 12th Gen Intel Core-i7-12700 X 20
Graphics: llvmpipe(LLVM 10.0.0 256 bits
OS type: 64 bit
Kernel version: 5.4.0-131-generic.
Please find the bug reort attached.
