I have an ubuntu 18.04 computer with a nvidia gtx1080ti card. I’ve installed 430.40 driver on it, but for some reason, the driver isn’t being used (llvmpipe is used instead). Below is the output of the terminal:
$ nvidia-smi
Mon Sep 23 13:43:16 2019
| NVIDIA-SMI 430.40 Driver Version: 430.40 CUDA Version: 10.1 |
| 0 GeForce GTX 108… Off | 00000000:03:00.0 On | N/A |
| 29% 33C P0 56W / 250W | 129MiB / 11177MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1345 G /usr/lib/xorg/Xorg 14MiB |
| 0 1864 G /usr/lib/xorg/Xorg 112MiB |
$ glxinfo |grep render
direct rendering: Yes
GLX_MESA_multithread_makecurrent, GLX_MESA_query_renderer,
GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer, GLX_MESA_query_renderer,
Extended renderer info (GLX_MESA_query_renderer):
OpenGL renderer string: llvmpipe (LLVM 8.0, 256 bits)
GL_ARB_conditional_render_inverted, GL_ARB_conservative_depth,
GL_MESA_ycbcr_texture, GL_NV_conditional_render, GL_NV_depth_clamp,
GL_NV_conditional_render, GL_NV_depth_clamp, GL_NV_fog_distance,
GL_OES_element_index_uint, GL_OES_fbo_render_mipmap,
$ sudo lshw -c video
*-display
description: VGA compatible controller
product: GP102 [GeForce GTX 1080 Ti]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:03:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:60 memory:fa000000-faffffff memory:e0000000-efffffff memory:f0000000-f1ffffff ioport:e000(size=128) memory:c0000-dffff
And in system setting->details->about, the graphcs item shows “llvmpipe (LLVM 8.0, 256 bits)”
The nvidia bug report file is also attached.
https://github.com/cbtogu/nvidiabugreport/blob/master/nvidia-bug-report.log.gz
nvidia-bug-report.log.gz (1.13 MB)
