i have met a problem as the topic and i have struggled for days using many methods but they did not work.
nvidia-smi:
(base) server@server00:~$ nvidia-smi
Thu Apr 7 10:59:29 2022
| NVIDIA-SMI 510.60.02 Driver Version: 510.60.02 CUDA Version: 11.6 |
| | | MIG M. |
| 0 NVIDIA GeForce … Off | 00000000:18:00.0 Off | N/A |
| 50% 31C P8 16W / 250W | 5MiB / 11264MiB | 0% Default |
| | | N/A |
| 1 NVIDIA GeForce … Off | 00000000:3B:00.0 Off | N/A |
| 50% 32C P8 19W / 250W | 5MiB / 11264MiB | 0% Default |
| | | N/A |
| 2 NVIDIA GeForce … Off | 00000000:86:00.0 Off | N/A |
| 51% 32C P8 21W / 250W | 5MiB / 11264MiB | 0% Default |
| | | N/A |
| 3 NVIDIA GeForce … Off | 00000000:AF:00.0 Off | N/A |
| 52% 34C P8 17W / 250W | 5MiB / 11264MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1790 G /usr/lib/xorg/Xorg 4MiB |
| 1 N/A N/A 1790 G /usr/lib/xorg/Xorg 4MiB |
| 2 N/A N/A 1790 G /usr/lib/xorg/Xorg 4MiB |
| 3 N/A N/A 1790 G /usr/lib/xorg/Xorg 4MiB |
inxi -Gx
Graphics: Card-1: ASPEED ASPEED Graphics Family bus-ID: 04:00.0
Card-2: NVIDIA Device 1e04 bus-ID: 18:00.0
Card-3: NVIDIA Device 1e04 bus-ID: 3b:00.0
Card-4: NVIDIA Device 1e04 bus-ID: 86:00.0
Card-5: NVIDIA Device 1e04 bus-ID: af:00.0
Display Server: x11 (X.Org 1.20.8 )
drivers: (unloaded: fbdev,vesa,nouveau) FAILED: modesetting,nvidia
Resolution: 1440x900@59.90hz
OpenGL: renderer: llvmpipe (LLVM 10.0.0, 256 bits)
version: 3.3 Mesa 20.0.8 Direct Render: Yes
Please tell me if other information is needed.
thanks!!!
The Xserver is running on the Aspeed graphics.
oh that is true, thanks a lot! and could you teach me how to change it to nvidia?
i didnot find how to switch it in my nvidia-settings
You need to create a basic /etc/X11/xorg.conf
Section "Device"
Identifier "nvidia"
Driver "nvidia"
BusID "PCI:24:0:0"
EndSection
and of course connect a monitor to the specific nvidia gpu.
It seems that I have the same error. nvidia-smi works fine but OpenGL renderer is llvmpipe.
(base) zhengkr@robotics189:~$ nvidia-smi
Sun Aug 11 22:15:09 2024
| NVIDIA-SMI 535.183.06 Driver Version: 535.183.06 CUDA Version: 12.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 2080 Ti On | 00000000:18:00.0 Off | N/A |
| 22% 32C P8 18W / 250W | 6MiB / 11264MiB | 0% Default |
| | | N/A |
| 1 NVIDIA GeForce RTX 2080 Ti On | 00000000:3B:00.0 Off | N/A |
| 22% 32C P8 1W / 250W | 163MiB / 11264MiB | 0% Default |
| | | N/A |
| 2 NVIDIA GeForce RTX 2080 Ti On | 00000000:86:00.0 Off | N/A |
| 22% 33C P8 2W / 250W | 6MiB / 11264MiB | 0% Default |
| | | N/A |
| 3 NVIDIA GeForce RTX 2080 Ti On | 00000000:AF:00.0 Off | N/A |
| 22% 33C P8 5W / 250W | 6MiB / 11264MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 2237 G /usr/lib/xorg/Xorg 4MiB |
| 1 N/A N/A 2237 G /usr/lib/xorg/Xorg 150MiB |
| 1 N/A N/A 2395 G /usr/bin/gnome-shell 10MiB |
| 2 N/A N/A 2237 G /usr/lib/xorg/Xorg 4MiB |
| 3 N/A N/A 2237 G /usr/lib/xorg/Xorg 4MiB |
(base) zhengkr@robotics189:~$ glxinfo | grep "OpenGL"
OpenGL vendor string: Mesa/X.org
OpenGL renderer string: llvmpipe (LLVM 12.0.0, 256 bits)
OpenGL core profile version string: 4.5 (Core Profile) Mesa 21.2.6
OpenGL core profile shading language version string: 4.50
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 3.1 Mesa 21.2.6
OpenGL shading language version string: 1.40
OpenGL context flags: (none)
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 21.2.6
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
(base) zhengkr@robotics189:~$ inxi -Gx
Graphics:
Device-1: ASPEED Graphics Family vendor: Super Micro driver: ast v: kernel
bus ID: 04:00.0
Device-2: NVIDIA TU102 [GeForce RTX 2080 Ti] driver: nvidia v: 535.183.06
bus ID: 18:00.0
Device-3: NVIDIA TU102 [GeForce RTX 2080 Ti] driver: nvidia v: 535.183.06
bus ID: 3b:00.0
Device-4: NVIDIA TU102 [GeForce RTX 2080 Ti] driver: nvidia v: 535.183.06
bus ID: 86:00.0
Device-5: NVIDIA TU102 [GeForce RTX 2080 Ti] driver: nvidia v: 535.183.06
bus ID: af:00.0
Display: x11 server: X.Org 1.20.13 driver: nvidia
resolution: 1920x1080~50Hz
OpenGL: renderer: llvmpipe (LLVM 12.0.0 256 bits) v: 4.5 Mesa 21.2.6
direct render: Yes
And I have already set the /etc/X11/xorg.conf:
(base) zhengkr@robotics189:~$ cat /etc/X11/xorg.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 535.183.06
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BusID "PCI:59:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
But the error still exist.
Since this seems to be a server, are you logging in from remote, e.g. through rdp? Then it’s only a virtual Xserver using LLVM.
