I have a new MSI laptop with RTX 3070 Ti. Installed Ubuntu 20.04 with nvidia driver 510.60. The nvdia-smi command can be run successfully. But seems not used by other processes other than xorg.
When running the glxgears, the GPU usage is still 0%. Attached the nvidia-bug-repor nvidia-bug-report.log.gz (492.1 KB)
t.
Thanks for the quick reply.
I tried sudo prime-select nvidia (without rebooting), but seems nothing changes. I also tried to connect to an external monitor, but is was not detected by GPU either.
After I changed to “prime-select nvidia” and reboot, the built in monitor did not display. However, external monitor works with the nvidia driver rendering. Disconnect the external monitor, the built-in monitor still does not works.
The problem is your 12th gen intel gpu. The ubuntu 20.04 stock kernel is too old to drive it, please try upgrading kernel+firmware using the liquorix ppa and then manually installing updated firmware package https://packages.ubuntu.com/de/impish-updates/linux-firmware
