We want run RTX3060TI on Ubuntu 20.04.3 with Intel 10th platform.
I blacklist nouveau and install nvidia 470 or 510 after reboot nvidia driver not work, just can use text mode check system status.
Debug message on below information , but RTX3060Ti can work on Windows 10 with Intel 10th platform, and Same as Ubuntu 20.04.3 with Nvidia 510 driver RTX3060Ti can work on Intel 8th platform,Is this a compatibility issue between Linux nvidia driver and intel 10th platform?
After install nvidia 510.47.03 Dmesg:
[ 3.975428] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 510.47.03 Mon Jan 24 22:51:43 UTC 2022
[ 3.980929] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 3.980931] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
[ 4.036299] nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
[ 4.038381] nvidia-uvm: Loaded the UVM driver, major device number 508.
[ 7.263590] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x26:0x56:1463)
[ 7.263643] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 7.940413] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x26:0x56:1463)
[ 7.940440] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 9.164671] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x26:0x56:1463)
[ 9.164704] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 9.845562] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x26:0x56:1463)
[ 9.845590] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
